Question about Garden
I need to open my travel smith 4 digit lock the # on it is 5715709
  • laura carmona Jan 24, 2013
    Thank you. I will do that.
    Sergeant:
  • 391 Answers
Laura:
You may need to go to http://www.travelsmith.com and contact their customer support.
Posted on Jan 19, 2013
How to change the 3 digit code of my samsonite ?
Luggage manufacturer Samsonite offers a variety of business, personal, travel products and accessories. Many Samsonite pieces such as attaches and other bags include a three-digit, built-in combination lock. When purchased, the locks are set on a factory default combination that you can change as often as you wish.
STEP 1
Turn the number dials to the previously set combination, or to "0-0-0", the factory default combination for Samsonite luggage.
STEP 2
Locate the reset button, usually placed to the side of the combination dials.
STEP 3
Press the reset button and hold it while rotating the number dials to the desired combination. Set this to a sequence easy for you to remember but hard for others to figure out.
STEP 4
Release the reset button after you set the numbers to the new combination.
STEP 5
Test the combination by turning the dials to the new code to open the lock. If the combination does not open the lock, repeat Steps 1 through 4 and test the lock again. If you still can't open the lock, contact Samsonite Customer Service at 800-765-2247.
Aug 28, 2016 | Luggage & Travel
Have a smith and Wesson revolver with the #e13673 can you give me any info on this
Shari, Check the attached links and get all the info. on your firearm. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Smith Wesson
Revolvers Smith Wesson
Classics Revolvers Smith Wesson
Smith Wesson 38 Special and 357 Mag Revolvers Guide
Apr 10, 2016 | Optics
I cannot open my Sentry Safe with key model H4300
if you have keys make sure they are the correct keys and they slide in smoothly and all the way . If still wont turn try to wiggle the key while turning you may need to pull it out very little to make it turn . I had to do this with my safe and it worked . Later after I opened it I took it to a lock smith to have the lock replaced . Sometimes the tumblers in lock are slightly miss aligned and need replacing . Cost for lock smith to change lock was quite reasonable. Good Luck
Jan 12, 2016 | Sentry Fireproof Safe
My keys are locked in my trunk. AAA was able to open the door but the alarm is on so there is no power in the car. vw says new key will take 3 or 4 days. I need my car!!! 2013 passat
Ther is a lock at the driver door. The plastic cover where the key insert slot should be pulls off. A lock smith will have a master slide set that would be able to unlock the car. You can access the boot by opening the split fold down rear seats.
Jun 27, 2014 | 2013 Volkswagen Passat
Cannot lock
Pick your number. Look at the inside of the lock. There should be a little "slider". Slide that - it sets your number and then your lock should function normally.
Nov 12, 2013 | Samsonite Silhouette 12 Travel/luggage...
How to unlock broken trunk latch for suzuki reno
(the key is dead? or the remote lever?) why not say>?
i know of only these tricks. (all cars not yours)
1: crawl true rear set , hole,behind seat.
2: if electric latch, hot wire it.
3: if cable latch. find a way to get to cable and yank the casing
hard, while person 2 tries to open the trunk.
4: drill out the key hole, then usiing a screw driver open the trunk.
5: drive to any lock shop smith. and ask em. its trivial.
A; they (smith) have working keys, or can make keys or can pick the lock
or failing all that do #4.
Jan 29, 2013 | 2005 Suzuki Reno
Door locked on safe
Brian We can't give advise on the safe but you can call the manufacture of the safe and if you have registered it they will help you otherwise federal law requires a lock smith to identify you and your information and your ownership of the safe before they will unlock it for you. This is to protect you or the safe owner and the lock smith from being sued and losing his licence.. There should be a sticker on the safe with a 800 number for you to call to get help. But you must have registered it first. They may have a way to verify it some other way but am not sure.
Nov 22, 2009 | Kitchen Appliances - Others
My typewriter keeps binding up and will not go far enough across
Most likely, the problem is not with the margins. The most common fault (loosing margins) is caused by the carrier binding on the shaft that it travels on. Solution:
Turn off the power
Locate the shaft that the carrier travels on (usually about 1/2 to 3/4 in. diameter, chrome shaft in the middle or lower/rear of the open area that the printer travels back-and-forth in).
Apply a few drops of 10 weight oil acroos the shaft and wipe with a cloth. Move the carrier manually to the right side of machine and repeat the prosess on the left side of shaft. Lubricate some more and repeat the process. NOTE: 3 in 1 oil is OK. . WD 40 IS NOT
Nov 11, 2009 | Smith Corona Office Equipment & Supplies
Need battery
is this for a Norcent Camera..?? I can help.
veronicaacs@gmail.com
Mar 04, 2009 | Norcent Technologies Xias DCS-760 Digital...
Garden Logo
53 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
