Question about Whirlpool Dishwashers
Help me put my door back togeher
Help me get my door back together
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 66 Answers
Wat have u done
Posted on Jan 18, 2013
Will not start ran hot then replaced head gasket with new head set put back togeher would not start. Put new camshaft sensor on where should I start next?
Have it towed to the nearest ASE certified repair shop ! What's missing Tammy ? Is there spark ,Is there fuel pressure ? Did you have to take timing chain off to replace head gaskets ? are the timing marks set right ? Why did you replace cam sensor ? You need to find out what is missing first.
Oct 26, 2015 | Cars & Trucks
Oven door glass slid down, how to refit
take off stove then look around outer edge for screws .have laying flat when you do this on a good table .the door has 2 halves that clamshell together . a bit of silicone calk will help prevent it from happening again . put screws back and put door back on oven
Oct 08, 2015 | Ovens
"How do I put this back together Door lock latch diagrams"
does it look anything like this , sorry hav'nt got the item list , get a workshop manual if this is not helpful , keep me posted if you wish
Jun 02, 2014 | 2001 Chrysler PT Cruiser
Dryer door switch assembly. how do I put it back together
All the terminals should be different in size with the big terminal wire being common which goes in the middle the other 2 wires make the light come on and make the motor go so if you get em backwards she will run with the door open and the light will come on with the door closed..
Aug 29, 2012 | Maytag Dryers
My dryer is a whirlpool, 5 cycle, 3 temp and does not come on, when you go to trun it on, it does not make any noise or anything.
check to make you have 220 volts of electricity,if you do make sure door is closed all the way,try to start dryer,still not working look at the door switch press it with your fingers while holding it down reach and press start button,still not working there are 2 wires that go to that switch you either have to pop the top up or take the front of dryer off to get to them you can tape the 2 wires togeher press start it should work,if not you have a thermal fuse in the back of the dryer under back panel next to dryer vent its white with two wires hooked to it you can tie these two wires together press start should work kenny 832 620 8626 i use a tester for all this
Jan 23, 2011 | Whirlpool LER4634J Electric Dryer
I AM CHANGING THE DRIVER DOOR ON MY HONDA ACCORD AND I HAD TO CUT THE WIRES AND I NEED HELP PUTTING IT BACK TOGEHER
You will need a soldering iron and some acid core solder. Skin back about 1/2-3/4 inch of wire on each wire, add a peice of shrink tube, twist the wires together and solder them together, side the shrink tube over the soldered area and heat the tube to shrink, or use some electrical tape. Make sure everything is taped up well to keep water out.
Mar 11, 2010 | Honda Accord Cars & Trucks
Parts are missing for The Impex Powerhouse
Wore out and the maufacturer cannot replace a tech rod unit for an impex TR-2 home gym.Need complete unit of 2-50lb,2-25lb,4-10lb,2-5lb rods on a plastic base.Can anyone help?
Feb 06, 2010 | Exercise & Fitness
Need help putting GE oven door back together again
they're called towers. They go on the 2 long screws once you've put the screws through - so they go between the two panels. They are used to space the 2 panels so that they line up flush when they are back together.
Jan 09, 2008 | Kitchen Ranges
Dishwashers Logo
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
