Question about Health & Beauty
Where can i get hand straps for the oster hand held massager
The straps are actually springs
4 Suggested Answers
  • 2712 Answers
SOURCE: hand held massagers question
The unit is not a toy and should not be used by children without adult supervision. Also, it is unsafe to use this product on adults and children while they sleep. You should NEVER use the massagers while you are asleep.
Posted on Aug 27, 2008
SOURCE: Can't disassemble massager.
I don't have the Homedics programmable, but I have taken apart my Brookstone programmable (and lots of old Homedics massagers).
I'm going to guess the screws concealment method is similar. On the under side of the massager, look for small oval-shaped outlines that are the same color as the rest of the body. Mine had four. These are little plastic plugs that you can pry out with a tiny flat screwdriver or a razor blade. The screws are hidden under these plastic plugs.
I hope this helps
Posted on May 25, 2009
s_s_m_o_k_i_
  • 162 Answers
SOURCE: are your hand held massagers ok to use in
that would depend on how you are using them...lol
sorry couldn't resist...
yes it's ok to use them during pregnancy
Posted on Jul 29, 2009
Massager service manuals
If you go to Homedics website you should be able to find downloads for the manual you require.
Nov 05, 2014 | Homedics Health & Beauty
It seems to have power going thru it..but no vibration...help
The small sping has come out of the shaft from the motor.If you open the unit you will see that the motor has a little impeller and a shaft with a slot in it. The little spring inside of the massager head is suppose to ride inside of that motor shaft with the little tab on the spring lining up in the slot. It's really flimsy and after I fixed mine it fell out again after 5 minutes of use. It needed a stiffer spring or a different way of engaging the motor shaft. I'm still working on this...
Apr 09, 2011 | Hitachi Magic Wand Hv250r Hand Held...
Hand held rechargable masager recharges but doesn't not vibrate when the button is pressed, the red light does not turn on either. The red light only goes on when it's recharging
Possible that the supply to the motor is cut or the motor is faulty or the switch has failed.
you have to remove and check the three possible faults, perhaps inthe process of vibration this can make wires break off contacts.
Sep 21, 2010 | Homedics Rc Quad Quad Extreme Rechargeable...
I need a hand held control for a HTT-9cb massage chair can you help me email: tsten61@aol.com thanks Tony
i SOLVED THE PROBLEM BY REPLACING THE CORD ON THE HAND HELD CONTROL THAT I HAVE.
Dec 23, 2009 | Health & Beauty
Are your hand held massagers ok to use in pregnancy?
Jul 29, 2009 | Health & Beauty
Instruction manual
Hi SJ, I don't think you need to worry too much about using the massager; you pretty much just plug it in and go from there (assuming you're in the US). Don't use it more than 20 minutes and don't use it while bathing. Additionally, should not use the massager on
  1. sensitive or inflamed skin
  2. varicose veins
  3. the front of your neck
  4. **** areas
  5. sleeping people
You can also check out their attachments and see what they're used for at their website: http://consumer.wahl.com/product.cfm?sid=13&ID=30. If you still would like the booklet, message me at jjones at thesexsite dot com and I'll scan it for you. Hope this helps, Johnathan
Jan 19, 2009 | Wahl 2 Speed Hand Held All Body Massager...
Hand held massagers question
Aug 27, 2008 | Homedics PA-4H Programmable Percussion...
Health & Beauty Logo
95 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
