Question about Jensen JXM900CMB Satellite Radio Receiver
Sirus radio the signal on my sirius radio fads in and out. sometimes it is aquiring signal but most of the time it quits playing but the screen shows the song and artist. it quits for 5 minutes or 5 seconds. I'll be sitting at a stop light and it will quit. other people in my area have no trouble and I have not had trouble in the 3 years I've had the radio.
  • Anonymous Dec 15, 2007
    With the antenna outside of our little ranch home, the Sirus signal dropps out alot. I have XM also, no problems --what's with Sirus? Paul, Chicago
  • Anonymous Apr 27, 2008
    I have the same problem. It goes out for 5 seconds every now and then.
I had to replace my Sportster because it was overheating and caused it to loose signal.
Posted on Jul 13, 2007
Aquiring Signal displays for 5-10 minutes before hearing audio
It's a bad Sirius tuner. You can find them on ebay for 50 or so rebuilt and they are better than new. It's cold solder joints on the antenna input plug. Hope this helps
Jun 17, 2010 | JVC KT-SR2000 SIRIUS Radio Receiver with...
Unit shows 3 bars for signal strength yet the
This is a very old radio, and your antenna could be shot too. Try another antenna first.
Mar 01, 2010 | Audiovox SIRPNP2 SIRIUS Radio Receiver
My sirus radio displays "aquiring signal" it has worked perfectly for 2 years and now I can't get anything
I had the same problem. If your radio is a kit and not factory installed in your vehicle it could be the magnetic antenna on top of your car. I had mine for about two years and from moving the radio around, or docking and undocking it, the wire from the antenna broke. It was not cut all the way through but it was enough to cause it to loose the signal. Check your antenna where it plugs into the back of the unit.
Oct 03, 2009 | Sirius Satellite Radio Receiver
My sirius radio sportster works sometimes and others doesn't
Buy radio shack electronic contact cleaner (in a can) and spray a small amount on the male connector from the antenna wire, and spray a small amount on the male connector in the base of the Sportster that the sportster interfaces with. Place the antenna connector onto the base unit and remove it several times and swirl it while connected. Place the sportster into and remove it from the base several times. This usually will fix the issue. Sat signals are extremely sensitive to the slightest oxidation or dirt or whaterver on that tiny antenna connection point.
Oct 01, 2009 | Sirius Satellite Radio Sirius Sportster...
I keep getting ''Acquiring Signal'', but a signal is never aquired
Try moving your Sirius radio antenna to a window that faces west. Signal goes through windows better than walls.
Aug 23, 2009 | Sirius Satellite Radio Audio Players &...
Connecting Sirus audio to Onkyo HT-R500
Carl- If you are sending a Line Level Audio signal to your ONKYO RECEVER, from your Sirus RCA cable Output, IE, the CD input, the VCR input, the AUX in, ETC. No Need to have the RECEIVER in the FM mode, you are just needing amplificaton of the sound signal or Sirus signal sound.
Feb 28, 2009 | Onkyo HTR500 Receiver
2006 factory dodge radio sat quit working
soft reset. get in turn on truck with door shut turn on sat radio on ch 184. turn off radio turn off truck and take keys out. next open door fully for 90 seconds. shut door. turn on truck. turn on radio and have sirius reset it. its called a soft reset.
Dec 25, 2008 | Eclipse SIR-ECL1 SIRIUS Radio Receiver
Sirus radio
I had the same problem and I replaced my car antenna. That resulted in immediate signal improvement. But three months later, the same thing. So, another dot micro car antenna. Three months later, the signal went out again. The home kit worked perfectly. In my case, I bought a Sirius outdoor home antenna and replaced the standard indoor/outdoor antenna that came with the home kit. I took the home kit antenna and connected it to my S50 car kit and positioned the antenna on the front of the dash. No problems since then. Not one. Those dot antennas are horrible. I'd check that before getting a new radio.
Jan 13, 2008 | Sirius Satellite Radio S50-TK1 Satellite...
Asquiring signal
yes everyone is getting "aquiring signal" problem, why isn't sirius radio taking responsibilty ???? it's thier satttelite ??????
glenn
Nov 10, 2007 | Sirius Satellite Radio Sirius Sportster...
Jensen JXM900CMB Satellite Radio Receiver Logo
382 people viewed this question
Top Jensen Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Jensen Audio Player and Recorder Expert? Answer questions, earn points and help others
