Question about Spidem Trevi Digital Coffee Maker, Espresso Machine
Water leak When i put the water in the container the water leaks out from the button. i don't know if i'm missing a washer of some sort.  i've never used it before.
Good chance its leaking from the boiler if has been descaled or used for a period of time.
Just had the same problem with mine.
Posted on Apr 01, 2009
Leaking faucet connection
Although it looks like the leak is coming from the hose side, it might still be coming from the swivel nut. Snug it up no more than 1/8th of a turn. If leak persists, snug it again. If still leaking, replace the supply flex.
Mar 24, 2017 | Fluidmaster Plumbing
My Maytag Ensignia washer is leaking water from the pump area of the washer. I've eliminated the drain hose and I've traced the leak up to the area of the plastic casing around what looks to be the...
Look for broken plastic casing of the pump. A hairline crack would also leak water. Check for proper fitting of flexible hoses to & from pump. Another thing is to check for loose filter cap. A loose filter cap or broken O ring of the filter cap can leak water.
Sep 18, 2011 | Washing Machines
Don't know how to get detergent into the ultimate x pressure washer (1500psi)
To the right of the Brass fitting where your garden hose attaches there is a small round plastic cover piece, pull on that and it will pull out a clear tube with it which goes into any container containing your detergent, it will pull the detergent as you use the pressure washer. Push the tube back in after you are done using it. You can also buy a replacement detergent bottle for other pressure washers if you wanted to.
Jun 05, 2011 | Garden
Have 97 Ford T bird. I sprayed with a power washer not thinking and since the pcv rattled. I took it out and replaced. Check engine is flashing and missed @1500-2000 rpm and I think it sounds like an...
more and likely water has gotten drowned out one of you coils . this was a problem for ford with water getting around the boots and killing the coil. you can have you check engine light scan at a advance or autozone for free. it should come up with a cylinder miss fire code. post back and let me know.
Apr 08, 2010 | 1999 Ford Expedition
Water leaking from the group
You can buy a service kit for your machine at www.theespressoshop.co.uk and that contains all replacable gaskets and washers and gives you an exploded diagram and sachet of grease and descaler to get your machine back in as new working order. The service kit you require is the "old group service kit" and is about £20. If you go to the website above and click on the la pavoni machine on the right hand side of the home page it will give you the full parts list.
All the best
LaPavoniBoy
Feb 18, 2009 | La Pavoni PC-16 Espresso Machine
Water not draining, how should the switch be set?
Hi There,
I am not an expert, but I have the same dish washer. The washer motor may not run in reverse. I had the same problem and a couple of the timer switches and the started relay were bad.
Fixed it but two years later it has the same problem. BTW, my unit still has a timer relays, the new once don’t'
Also don't switch on the delime switch, this will hold the cycle until you switch it off again.
Regards,
Thomas
Nov 23, 2008 | Moyer Diebel 24 in. 501HT Built-in...
Yesterday I was reheating a non metallic coffee mug of water in my GE Spacemaker microwave. When I hit the cancel button a weird pressure explosion of some sort occurred. The door came flying open at me...
Microwaves do not use or generate ionizing radiation, so there's no worry there.
A burn is the real worry, and it's good that didn't happen.
While rare, this can be pretty dangerous.
There's a very helpful and comprehensive article about this phenomenon here.
Prevention is as simple as putting a non-metallic straw or coffee stirrer in the container before you heat it.
Aug 06, 2008 | GE Microwave Ovens
Bosch tumble dryer
I've sorted mine this morning. First, disconnect from the mains - VERY important! Pull out the metal condenser unit at the bottom, and behind it, there's a small hatch in the bottom to the reservoir. This can get gunked up with water, and is very difficult to clean - HOWEVER - I've found a really easy way of cleaning it. I've got a VAX carpet washer with a hose attachment, and I simply sucked all the water out using that. If you don't own a carpet cleaner maybe borrow one. I did this this morning, and my tumble-dryer's still running happily after an hour! It is possible to clean it out without vacuum, but it takes a LOT longer, and the vacuum of the cleaner pulls out gunk that is hard to access. Another place where gunk collects is behind that hatch right at the back - there's a tube up to the right. I pulled out quite a long chunk of lint. However, that wasn't the solution on it's own, I still had to clean out the reservoir as above.
Jul 03, 2008 | Bosch Axxis WTA 3510 Electric Dryer
BUNN BX-B Coffee Maker Leaking
is it the water container that leaking the best thing to do is open it maybe is a loose pipe or dry pipe connected to water container and if it the water container use 5 or 1minute epoxy cheers
Jan 29, 2008 | Hamilton Beach BrewStation Deluxe 47474...
Spidem Trevi Digital Coffee Maker, Espresso Machine Logo
90 people viewed this question
Top Spidem Coffee Makers & Espresso Machines Experts
Michael Galve
Michael Galve
Mike
Mike
ray gallant
Are you a Spidem Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
