Question about Water Heaters
Ideal logic + gas boiler pump overrun ignition lockout problem. No heat or water, burner light staying blue. Please help.
  • 659 Answers
SOURCE: hot water boiler will not ignite
Check all your limit switches on this unit. One of them is either tripped or bad.
Posted on Apr 07, 2009
  • 171 Answers
SOURCE: instructions for my Ideal Mexico CF60P Propane boiler
Hi tessajoe,
I'm Harvey, the master plumber. You asked where you can
download instructions/user manual/installation guide for
Ideal Mexico CF60P Water Heaters. I believe this is the correct link:
http://www.chspares.com/partselect.php?test=121
Some Companies will e-mail it, others will respond if you call them on the phone and they will fax it or mail it. Contact info on the link that you requested form me.
I'm happy to help you!
Feel free to contact me.
Harvey the Master Plumber
Posted on Sep 09, 2008
Da Brain
  • 11 Answers
SOURCE: Pilot light has gone out onmy Ideal Elan 2 Boiler
TAKE A SHPO VAC AND CLEAN AREA. MAKE SURE YOU PAY SPECIAL ATT. TO THE PILOT LIGHT. FIND BUTTON HOLD IN AND IGNITE DONT LET GO WHEN IT LIGHTS FOR AT LEAST FIFTEEN SEC.. YOU MIGHT ALSO HAVE TO TURN THE THERMASTAT OR KNOB TO PILOT FIRST. AFTER IT HAS LIT TURN UP FLAME
Posted on Oct 27, 2008
  • 234 Answers
SOURCE: vokera mynute 14se lockout reset button on
Has the boiler cool down? Try turn the power off for a few minutes and see if that will work.
Posted on Mar 15, 2009
mrhotandcold
  • 248 Answers
SOURCE: hi, my ideal combi boiler mini HE C24 has lights
could be your microswitch check overheat stat and fan are o.k. best of luck
Posted on Oct 21, 2009
My ideal logic combi 30+ is saying ignition lockout and my radiatiors arent heating up as well as my water not turning hot. How can i fix this please?
Lockout is a safety feature. Usually a latching condition and needs to be investigated rather than blindly reset. (The Combi has a bit more intelligence.) With the ignition locked out, you can't hi-fire the boiler, so no hot water of either type. The 'L' should also show a code number - check your user manual (google) for more guidance.
I've had a lockout on a non-combi: it was caused by lack of circulation of central heating water through the boiler.... The system boiled and the trip tripped. The pump WAS running, but wear in a valve actuator resulted in the valve feedback saying valve open while it was physically shut.
Dec 31, 2016 | Water Water Heaters
Hot water runs but heating wont. Pump continously overunning.
What do you mean when you say that 'hot water runs but heating won't' ? Do you mean that water is coming out of the hot water faucet, but that it is cold? When you say pump continuously overrunning, what pump and what do you mean by overrunning? I would like to help you, but I'm not sure what you are asking. Also, is this a water heater, or a boiler?
May 26, 2016 | Water Water Heaters
I have a halstead finest gold combi when I turn the boiler on the boiler goes into its ignition sequence when it comes to ignite the boiler fires but after the igniter stops the boiler cuts out completely...
Difficult to get too specific without knowing if you have gas or oil. Also, I am going under the assumption you mean the burner shuts down, not the whole heating system. That being said, all heating appliances have whats called a safety curcuit. Each control has the ability to shut down if certain critera are not met. There is a sensor that senses light down the blast tube. If no light is sensed in a predetermined time period, then the sensor cuts power to the burner. This stops delivery of fuel so if it does ignite you wont blow up.
(I suspect that the ignitor and burner shut down simultainously.)
It may be the sensor (cad cell eye) is doing its job, however why is the question. Could be a number of things including the fuel delivery, ignition, improper air adjustment, etc.
No qualified professional should diagnose a problem unless they are in front of the appliance. I recommend you find a licensed qualified heating techician. Hope this helps.
Feb 04, 2013 | Water Heaters
On the ideal c95ff the boiler the red neon lockout
overheat stat , does it come back on with reset ?best of luck
Jul 23, 2009 | Water Heaters
Combi boiler problem
most have an overrun built in for a few minutes. if much longer have you got a room thermostat anywhere to turn down
If it never turns off check the switch which controls ON/TIMED/OFF and turn to timed or off. if it still continues on timed then it's the timer
Jan 22, 2009 | Whirlpool Aquatic Millennium VII -...
Oct 25, 2008 | Water Heaters
Water Heaters Logo
1,309 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
