Question about Echo Images Contact Sheets
I want to print contact sheets - Echo Images Contact Sheets
How can I print only black and white
If you're printing the photos yourself and it's film then you have to use black and white film, chemicals and paper. Otherwise, shoot black and white film and send it to a photo lab. If you're talking digital then you're in the wrong catagory here. This is film cameras only.
Jan 29, 2014 | Photography
Black will not print
Do not open the HP 564XL cartridge until you are ready to use it
Do not touch the electrical contacts of the cartridge
To obtain best print reliability store the box with the bottom facing down
Use the HP 564XL ink up within 6 months after opening to obtain the best print quality
Refer to your users manual provided with your printer for information on how to open and install the cartridge
Store out of direct light, in a stable environment. Large temperature changes may affect the cartridge
Jan 19, 2014 | Office Equipment & Supplies
Replaced black ink cartridge, but now it only prints a very faint line, cant make out what is printing
Sir/Madam
If your printed pages have a horizontal line in the text or graphics (as shown in the illustration below) or blank text, some of the nozzles may be clogged and need to be cleaned
Go to Section 2 for instructions on how to print the Alignment Check sheet and adjust the print alignment.
Section 1: Checking the print quality and cleaning the print head
  1. Print a Print Quality Check Sheet.
    1. Press Menu.
    2. Press the UP OR DOWN ARROW key or the dial pad to choose Ink Management and press OK.
    3. Press the UP OR DOWN ARROW key or the dial pad to choose Test Print and press OK.
    4. Press the UP OR DOWN ARROW key or the dial pad to choose Print Quality/Alignment and pressOK.
    5. Press Color (Colour) Start. The machine begins printing the Print Quality Check Sheet.
  2. Closely examine the Print Quality Check Sheet. Each of the four colors is represented by a slanted square pattern made up of individual blocks. The colors should appear in the following order from left to right: Black - Yellow - Cyan - Magenta.
  3. Compare the print quality of the Check Sheet you just printed with the three examples listed below:
    (A) One or more complete blocks of colors are missing:
(B) Most of the short diagonal lines are missing from one or more color blocks:
(C)Some parts of the short diagonal lines are missing from one or more color blocks:
  1. The display will then ask you if the print quality is OK for black. Press the DOWN ARROW key or 2 to choose Nofor black with the problem.
  2. The display will then ask you if the print quality is OK for Color. Press the DOWN ARROW key or 2 to chooseNo for color with the problem.
  3. The display will then show Start Cleaning? Yes No.
    Press the UP ARROW key or 1 to choose Yes and the machine will start cleaning the color ink cartridges.
  4. When the machine completes cleaning the print head, press Color (Colour) Start. Another Print Quality Check Sheet will print.
  5. Repeat the cleaning and the quality check process following the Step 4-7.
  6. Compare the second or third Print Quality Check Sheet with the first one you printed in step1:
9. Compare the second or third Print Quality Check Sheet with the first one you printed in step1:
  • If the print quality on the first Check Sheet matched Example (A) or (B) and you do not see any improvement on the second or third Check Sheet, please contact Brother Customer Service from "Contact Us."
  • If the print quality on the first Check Sheet matched Example (A) or (B) and you see some improvement on the second or third Check Sheet but it's not perfect, repeat the cleaning and the quality check process three more times (totally five times). If you do not see any further improvement after that, please contact Brother Customer Service from "Contact Us."
  • If the print quality on the first Check Sheet matched Example (C) and you do not see any improvement on the second or third Check Sheet, repeat the cleaning and the quality check process three more times (totally five times). If you still do not see any improvement, please contact Brother Customer Service from "Contact Us."
10. Press Stop/Exit.
Section 2: Checking the Print Alignment
  1. Press Menu.
  4. Press the UP OR DOWN ARROW key or the dial pad to choose Print Quality/Alignment and press OK.
  5. Press Black (Mono) Start or Color (Colour) Start. The machine begins printing the Alignment Check Sheet.
  6. By reviewing this Check Sheet, you can determine if the alignment needs adjustment.
  7. Examine the 600 dpi and 1200 dpi test prints on the Alignment Check Sheet. If the number 5 sample of both the 600 dpi and 1200 dpi most closely matches the 0 sample, press the UP ARROW key or 1 to choose Yes.
    If one of the other samples is a better match for the 0 sample, press the DOWN ARROW key to choose No. The display will then prompt you to choose the sample that most closely matches the 0 sample for 600 dpi and then 1200 dpi.
  8. Press Stop/Exit.
If the print quality continues to be poor, go to Section 1 to clean the print head.
If your question was not answered, please check...
Improve poor print quality Brother
Or
If You Still need Brother Printer Help then I suggest You follow Us On For: Brother Printer Support
Oct 09, 2012 | Brother Ink for Dcp-6690cw and Lc-1100
Prints ok but prints additional blank sheet after each complete document
Press menu button and scroll to the right and access the Finishing menu and select NONE for Separator sheets .
Please contact Lexmark Technical Support for further assistance.
Aug 19, 2011 | Lexmark Optra T610 Laser Printer
The colour not sharp and got vertical line when print
A reason for the non-sharp collorcould be that the ink is not dried correctly, so open the printer settings andclick at the Slow Drying Paper in the Basic tab. Thus, theprinter will let the paper to dry better.
Regarding the vertical line (and not sharp color) we could check the printquality and then align the nozzles:
Checking the print quality: 1. Print a Print Quality Check Sheet.a. Press the Ink or InkManagement key on the control panel of the machine.b. Press the up or down arrow keyto choose Test Print and press OK. c. Press the up or down arrow keyto choose Print Quality and press OK. d. Press Color (Colour) start.The machine begins printing the Print Quality Check Sheet. 2. Closely examine the Print QualityCheck Sheet. Each of the four colors is represented by a slanted square patternmade up of individual blocks. The colors should appear in the following orderfrom left to right: Black - Yellow - Cyan - Magenta. 3. Compare the print quality of theCheck Sheet you just printed with the three examples listed below:
(B) Most of the short diagonal lines are missing from one or more colorblocks
(C)Some parts of the short diagonal lines are missing from one or more colorblocks4. The display will then ask you if theprint quality is OK for black. Press the down arrow key or 2 or "-" to choose No for black with the problem. 5. The display will then ask you if theprint quality is OK for Color. Press down the arrow key or 2 or "-" to choose No for color with the problem. 6. The display will then show StartCleaning? Yes No.
Press the up arrow key or 1 or "+" to choose Yes andthe machine will start cleaning the color ink cartridges. 7. When the machine completes cleaningthe print head, press Color(Colour) Start. Another Print Quality CheckSheet will print. 8. Repeat thecleaning and the quality check process following the Step 4-7. 9. Compare thesecond or third Print Quality Check Sheet with the first one you printedin step1:o If the print quality on the firstCheck Sheet matched Example (A) or (B) and you do not see anyimprovement on the second or third Check Sheet, please contact BrotherCustomer Service from "Contact Us".o If the print quality on the firstCheck Sheet matched Example (A) or (B) and you see some improvementon the second or third Check Sheet but it's not perfect, repeat thecleaning and the quality check process three more times (totally five times).If you do not see any further improvement after that, please contact BrotherCustomer Service from "Contact Us".o If the print quality on the firstCheck Sheet matched Example (C) and you do not see any improvement onthe second or third Check Sheet, repeat the cleaning and the quality checkprocess three more times (totally five times). If you stilldo not see any improvement,, please contact Brother Customer Servicefrom "Contact Us".10. Press Stop/Exit.Setting the Alignment:1. Press the Ink or InkManagement key on the control panel. 2. Press the up or down arrow keyto choose Test Print and press OK. 3. Press the up or down arrow keyto choose Alignment and press OK. 4. Press Black (Mono) or Color(Colour) start. The machine begins printing the Alignment CheckSheet. 5. By reviewing this Check Sheet,you can determine if the alignment needs adjustment. 6. Examine the 600 dpi and1200 dpi test prints on the Alignment Check Sheet. If the number 5 sampleof both the 600 dpi and 1200 dpi most closely matches the 0 sample,press the up arrow key or 1 or "+" to choose Yes.
If one of the other samples is a better match for the 0 sample, press the downarrow key or "-" to choose No. The display will thenprompt you to choose the sample that most closely matches the 0 samplefor 600 dpi and then 1200 dpi. 7. Press Stop/Exit.
Aug 04, 2011 | Brother MFC-5860CN InkJet Printer
Every 10 prints or so a single sheet of paper will come out printed but will crunch up as it is feeding to the output tray. Nothing seems to be blocking it because not every page does it.
If you are getting blank pages between print jobs or between page or each print job, separator sheet must be turn off. By default NONE is the factory settings for separator sheet. You may restore factory defaults. to do this click on menu>settings>general setting>factory defaults.
For further assistance, please contact Lexmark Technical Support
Mar 08, 2011 | Lexmark C540N PROD SPECS TBD Printer
This is happening like every other few sheets of print!
We would like to verify what happens to every sheets of print? please provide us more information.
For further assistance, you may contact Lexmark Technical Support
Feb 09, 2011 | Lexmark C522n Laser Printer
It wont print anything all I get is a blank sheet of paper
U maybe out of ink or your cartridge would have dried!! try to replace it with a new cartridge!!
Dec 26, 2009 | Dell A960 All-In-One InkJet Printer
Black won't print
will print blank? try to do this, remove the cartridge and the printhead, put it back again. perform a deep clean by press menu>clean printhead>deep clean
print a demo sheet by pressing menu>print demo sheet
if it fails then contact kodak..
Mar 30, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Computers & Internet Logo
14 people viewed this question
Top Echo Images Computers & Internet Experts
David Payne
David Payne
Are you an Echo Images Computer and Internet Expert? Answer questions, earn points and help others
