Question about Samsung Dryers
Wont start. tested all fuses and - Samsung Dryers
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 37 Answers
Check the door switch it will keep it from coming on
Posted on Jan 18, 2013
2005 duramax wont start replaced ficm rand one day great wont start again blew mega fuse still no start
find all ground wires in your vehicle clean and sand shiny , replace tight. will save money on parts you don't need. also older starters will begin to draw too many amps and keep blowing fuses. test starter.
Apr 06, 2017 | Cars & Trucks
No bus on 2009 patroit jeep wont start how can i fix it
no bus?
what engines, there are many.
wont crank or will not start. no
a/T tranny?
why not do the simple tests.
does car jumper cable crank off a running good car.??????????
that is test 1 after checking fuses. (always check fuses)
Jan 08, 2014 | Jeep Cars & Trucks
To cold wont start
Pull the battery, if it freezes it will be wrecked, take it to be tested or charged; re-install same battery(if fixed, charged) or new battery, if not able to fix old one. Away you go
One time for me, it was the main fuse(80 amp) in the fuse block(box) under the hood on the passenger side - the guy who boosted me blew the main fuse so nothing worked. Mazda dealership carries those fuses
Jan 25, 2013 | Mazda Cars & Trucks
1995 dodge intrepid wont start. Battery is fully charge but no power to anything. Car wont start
The alternator would not come into play unless the battery was dead.
Could be corrosion inside one of the battery cables, or a blow maxi fuse for the fuse box. Or a bad ground connection.
You would need to take a meter or test light and check for power at the starter post, and the major fuses.
Dec 22, 2012 | 1995 Dodge Intrepid
My dryer wont start or turn on at all
When the dryer wont start it is the thermal fuse that is bad, you can test it with a voltmeter before replacing. This fuse is located inside the rear panel and it cannot be reset. If the fuse tests fine then it is the main board that has gone bad & you will have to replace it to solve this issue.
Hope this will help...
Dec 31, 2010 | Dryers
Hey my 1989 l300 van wont start, it trys to start and the battery ok but it just wont turn over?
test for fuel makeing it up front check fuel pump fuses test for fire from plugs check make sure timming belt isnt broken
Dec 21, 2010 | Mitsubishi Minivan Cars & Trucks
Car wont start
test light on neg with key on power at both sides of coil ???? next test light on bat plus put to coil neg and have somone turn car over if test light flashes and still no spark coil is bad if test light no flash ignighter is most likely bad the ignighter switches ground on your coil for spark
Dec 23, 2008 | 1994 Toyota Camry
1987 toyota corolla 4 dr wont start
if its throwing a little spark,it means the coil's about to give up.
Sep 01, 2008 | 1987 Toyota Corolla 2 Door
Wont start
resistor.............tell the mehanic
Jun 27, 2008 | 2003 Dodge Caravan
Dryers Logo
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
