Question about Home Security
Change combination on sentry 1380 - Home Security
SOURCE: lost combination for Sentry 1250
Lost your sentry safe combination. First, find your safe’s Serial Number. The Serial Number is printed on the small label on the right side of safe ( on paper tag near hinge) or under handle. just note your model # and the serial#. sentry safe lost combination and the opening instructions.
Posted on Aug 07, 2010
SOURCE: 1380 Sentry
You can call a locksmith with the model # and serial #
Posted on Aug 09, 2010
SOURCE: Change the combination to a Sentry 2260 safe.
Safe and vault techs would advise you
1. Press the Program key.
2. Press it a second time.
3. Enter your 5-digit User Code. The green LED remains ON.
4. Enter the 5-digit Password of your choice (any combination
except 00000.) After 5 digits are entered, the green LED
turns OFF.
(To enter a new Password, repeat these steps. To erase the
Password, press Program twice, enter your User Code and then
enter 00000.)
carriesharee
  • 8 Answers
SOURCE: I lost the combination to
If you registered your safe when you purchased it go here to recover your combination.
If you did not register your safe after you purchased it click here and follow instructions on recovering your combination.
After recovering your combination be sure and register it here so next time you will have easy access in case you forget it again.
If none of the above options have helped you will need to Email or Call customer service directly.
Let me know if this helps!
Carrie
Posted on May 15, 2011
SOURCE: How to creeate a new combination for a sentry 1310 valueguard saf
Have a 1310 Sentry Valueguard safe and cannot remember the combination nor can i remember where i put the paper that i once wrote the combination down on....need help!
Posted on Aug 31, 2011
Combination for sentry 1380 safe
Now how in the heck would we know the combination?????????
Jun 07, 2017 | Sentry Home Security
Have a old safe lost the combination
Contact a locksmith. Most likely it will need to be drilled.
Jan 29, 2017 | Sentry Home Security
Aug 01, 2010 | Sentry FIRE-SAFE Combination Safe DS3431,...
I WANT TO CHANGE COMBINATION ON MY SENTRY FIREPROOF SAFE HOW?
I have a sentry safe csw 4747 Idont no tha combination
how do I do the safe a key and electronic key pad
Jan 11, 2010 | Sentry Fireproof Safe
I have a Sentry 1380. I DO have the combo, but I guess from moving it too many times, It will not open. Any ideas.? Ive tried the combo standard direction and reverse. Thank you for any help.
As a Safe and Vault Tech I would recommend adding or subtracting 1 number at a time to the combination numbers. Just I case the locked got bumped when you moved it . For example if the sentry safe combo was 60-20-40 you would try 61-21-41 or 59-19-39 then try 62-22-42 or 58-18-38 and so on.
Jan 02, 2010 | Sentry Fireproof Safe
Sentry safe v260 . have both keys but forgot the combination. how can i over write it?
If you have a "3 number combination" or have a "4 number combination you that you have NOT changed", you can send in your serial number in a notarized letter and $8 to: Sentry Group, Dept 200, 882 Linden Ave., Rochester, NY 14625-2784. (this info is in your Owners Manual under Lost Keys or Combination) If you don't have your Owners Manual you can download it from: http://www.sentrysafe.com/products/productDetail.aspx?s=130
If you have a "4 number combination" and you HAVE changed it from the original cobmination, the only solution you have is a locksmith.
Jun 13, 2009 | Sentry Fireproof Safe
Need to open a Sentry keyless combination safe
First, has the factory combination been changed? Sentry has the code for the factory combination that they can supply you.
If the factory combination has been changed to something else, then Sentry won't have it.
In that case you need to ask Sentry for a 'reset' code combination. There is (at least) one back door to your safe -- a reset code.
The reset code will not tell you what your combination is, it will simply reset the combination to the factory combination.
You can take it from there.
Now, this isn't as hard as it may sound. There is an actual department that handles this at Sentry because you aren't the only one that cannot open his safe.
They'll want some proof of ownership, some $$ for the service, the safe serial number, and probably a notarized form claiming that the safe is yours.
Get 'hold of Sentry on the web and the rest is just process.
BTW -- this is exactly what the locksmith would do.
Apr 10, 2009 | Sentry Fireproof Safe
Changing the combination
These sentry safes dial combinations are not built to be changed as they have no key change hole. Switching the order of the tumblers could be done by a trained locksmith. I would suggest buying the electronic sentry safes as these safes can be reprogramed.
Jan 04, 2009 | Sentry Fireproof Safe
1380 Sentry
Oct 29, 2008 | Sentry Fireproof Safe
Home Security Logo
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
