Question about Tools & Hardware - Others
I have a Craftsman 15 amp 3.5 hp router model 315.275110, and am looking for the 1/2 inch collet which is obsolete and discontinued. I have looked everywhere to no avail. Any ideas?
Need 1/2 inch collet
    New Friend:
I have a few 1/2" collets, email at martik777@gmail.com
Posted on Mar 07, 2018
    Top Expert:
  • Tools & Hard... Master
  • 43,059 Answers
The half-inch collet probably was not unique to your Craftsman router but used by other router manufacturers as well. A little "comparison shopping" could turn up something that will work
Posted on Sep 25, 2013
Change a router bit in a black and decker router
Should be a collet nut on shaft. grasp shaft with vicegrips and loosen collet nut with wrench.
Jan 09, 2016 | Black and Decker USA Vintage Black &...
How do I change a router bit on a craftsman router model number 315.174700
lock the collet by turning the on-off switch to off, push the button under the on-off switch to lock the collet then use the supplied wrench to loosen the collet.
Jan 19, 2013 | Craftsman 315.174710 Routers
Router bits wont fit on my router collet nut is to small.
The two sizes (in the US) for router bit shanks (and collets) are 1/4 inch and 1/2 inch. Some routers use only a 1/4 inch collet. Routers with a 1/2 inch collet also come with a 1/4 inch collet. You need a 1/2 inch collet to hold a 1/2 inch shank. Good luck.
Jan 16, 2013 | Tools & Hardware - Others
I have an old router Sears 315.17400 with 1/4 inch bits but no collet, nut, or manual. I'd like to get this working as it is mounted on my new router table and I would like to use my new one as a plunge...
have you tried sears for the collet and nut, should be able to get it there , on on line from there., As far as manual, what questions did you have., I can help.
Mar 25, 2011 | Craftsman Tools & Hardware - Others
Can the 1/2 collet be replaced with a 1/4?
A collet reducer or 1/4" collet may be available from service centers
Feb 26, 2011 | Porter Cable 7519 Speedmatic 3 1/4 Peak Hp...
How to connect 1/2 inch router bit into dewalt router
Are you asking how to put a router bit with a 1/2 inch shank into a router with a 1/4 inch collet? You need a 1/2 inch collet. Most routers with a 1/2 inch collet can also use a 1/4 inch collet. But smaller routers cannot use a 1/2 inch collet.
If this isn't clear, please ask again.
Thanks for using FixYa.
Al K
Mar 29, 2010 | Dewalt DW621 Routers
How do i change the bit on router?
On my older Sears router there is a lever on the base near the collet nut that you slide to engage the motor shaft to lock the motor shaft for bit changes. On newer models you may have a button or different mechanism to lock the shaft. After the shaft is locked you can use a small wrench to loosen the collet nut, usually by turning it counter-clockwise (viewed from the base). Once the nut is loose the bit should slide out (sometimes the bit is stuck in the collet and the nut may need to come all the way off to get them apart). Just replace the bit with a new bit with the same shaft diameter, tighten the nut, and you are set. If the new bit has a different shaft diameter than the old bit you may need to change the collet also (in general, different collets are used with different bit shaft diameters).
Oct 03, 2009 | Craftsman Tools & Hardware - Others
Ive got a kenzo router and the router bits do not fit . ive got quarter inche cutters and when the collet is done up tight the cuters are still not tight. its not a half inch router as ive measured it. any...
Your router bits must have a 6mm shaft, whereas your router with the collet closes down on a 1/4" or 6.4mm shaft. You will need to get a metric collet for your router spindle, or get a new set of 1/4" bits
Sep 28, 2009 | Freud FT2000E 3 Router
Need router for table sears 25479 what new routers fit this table
Hi there. You will find that all of the non-plunging routers will fit. I recommend that you buy the most powerful one you can find for the money you want to spend and one that has a 1/2 inch collet, or ideally both 1/2 and 1/4 inch collets. Enjoy your new router.
Apr 12, 2009 | Craftsman Tools & Hardware - Others
Tools & Hardware - Others Logo
426 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
