Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
My hotpoint dishwasher is stopping mid cycle and flashing A10
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 66 Answers
Thermostat or element or pc board
Posted on Jan 18, 2013
  • 3 Answers
SOURCE: DISHWASHER IS LEAKING A LOT OF WATER
I had the same problem with my machine - ie lots of water coming out front about two thirds of the way through the cycle - engineer (local and very reliable) knew as soon as he came in that I had started bying Powerball 5 dishwasher tablets - they produce too much foam (try opening the door during the cycle and see the amount of foam) and it therefore comes out of the overflow parts on the door. I tried Magnum 5 and got the same problem. Now I stick to either Asda's own basic (not the 5) or I buy the Magnum ones and cut them in half. Has never leaked since!
Posted on Aug 25, 2007
Poohs
  • 4 Answers
SOURCE: BF162 Hotpoint intergrated dishwasher
When you switch it on can you still select the wash type ?
If you can, when you shut the door does it start the cycle normally by pumping out the sump, but then when the wash pump (the cause of the main noise during the cycle) would normally start it stops and beeps - opening the door then shows the flashing error code ?
If your symptoms are the same as above or similar, suspect the heater is stuffed. My BFI62 did the above and it turned out to be a faulty (open circuit) heater. As I had no knowledge of dishwashers at the time, I called in a repair guy. As soon as he saw the fault code he suspected the heater - seems a batch of heaters (from the USA) had proved very unreliable (apparently Hotpoint got compensation from the manufacturers because of the number of problems it caused them). The replacement was made in Germany and the repair guy said he'd not known one of those to go faulty !
The repair guy diagnosed the heater open circuit from the control panel inside the door without even removing the dishwasher from it's location. Unfortunately, I didn't have a chance to note which wires ran off the board to the heater. Changing the heater needed it out and on it's side (be prepared for quite a lot of water on the floor).
Finally, when he'd fitted the new heater, it took him two goes to get the pipes either side of it to seal properly - quite common apparently and the source of even more water on the floor !
Hope this helps.
Posted on Jan 01, 2008
SOURCE: hotpoint FDW80( A10 Appears ondisplay half way through cycle)
here are the fault codes for your machine...
Fault codes for LCD Dishwasher Models
  • A01 - Float switch operated - Book a service engineer.
  • A02 - Open/Short circuit heater relay - Book a service engineer.
  • A03 - Short circuit on thermistor - Book a service engineer.
  • A04 - Unable to reach or sense temperature within 70 minutes - Book service engineer.
  • A05 - Pressure switch has not been reset - Book a service engineer.
  • A07 - Open/Short circuit wash motor triac - Book a service engineer.
  • A08 - Open/Short circuit auxiliary wash motor triac - Book a service engineer.
  • A09 - Open/Short circuit with main wash traic - Book a service engineer.
  • A10 - Open/Short circuit fill valve traic - Book a service engineer.
  • A11 - Half load valve traic or alternating motor action - Book a service engineer.
  • A12 - Open circuit heater rely - Book a service engineer.
  • A13 - Open/Short circuit dispenser traic - Book a service engineer.
  • A14 - Drain hose too low causing syphoning. Check drain hose and re-adjust.
  • H20 - Check tap and pressure of incoming water
  • Hope this helps?
    Posted on Feb 05, 2008
    SOURCE: hotpoint fdw20p dishwasher
    You need the control panel to reset before anything else can happen. To do this TURN OFF THE PLUG SOCKET FIRST AND UNPLUG. Then you need to drain ALL the water from the machine. Turn off the water supply feed and place the wastage pipe as low to the floor as poss ( 1-2" off floor). Water will gush out so use a large shallow tray and keep emptying the tray. Tilt the dishwasher over slightly to make sure all the water is out.
    This will allow the control panel to reset itself which wouldn't normally happen if the base of the dishwasher was holding even a small amount of water.
    Re connect the water, plug back in , select the RESET setting on the dial and close the door and switch on.
    Leave for about 20 seconds and then turn off.
    Rotate the selector switch to "A" Intensive wash and switch
    I found this on another site and it really did work for me
    Posted on Feb 23, 2008
    SOURCE: HOTPOINT DISHWASHER FDW60
    I have just had my dishwasher fixed by Hotpoint, as the heater was working and the dishwasher only stopped with the fast and delicate lights just before the drying process he replaced the main control board. This has solved the problem, I suspected the fault to be the thermistor as the heater seemed to be getting to hot but I had no idea where it was.
    It turns out the thermistor is attached to the main control board and hangs down behind the front door that gives just a rough temperature level for the main control board.
    As it's soldered directly onto the control board I would suggest replacing the whole control pcb for anyone with this fault unless you can find any spec details for the thermistor.
    Posted on Mar 23, 2008
    Dishwasher not finishing cycle
    A10 4 + 6 Heating circuit Heating element, connections, module,
    relay, pressure switch
    A10 Open circuit in heating circuit.
    • Check the circuit of the heating element (26 ohms).
    • Check for an open circuit heater cut-out.
    • Check pressure switch open circuit (connections 11-14).
    • Check wiring and connections between module card, pressure switch and heater.
    • If all above is OK, replace module card.
    Sep 18, 2014 | Hotpoint 24 in. FDW60 Free-standing...
    Dishwasher starts to work but after 30 seconds stops and two lights start flashing on pannel
    Ok so your dishwasher won't do anything... it justs sits there and "Hums" you can't make it respond to any controls, and the ONLY way to Stop it. is to unplug the unit, replugging back in it simply "Hums" again and will do nothing.
    Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle. This should NOT be done. You shouldNEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
    Now, the FIX. Take the Dishwasher, out, and tip over on it's side, tip to about a 45' angle. Water will come out from underneath, this is from a small "Overflow" reservoir. this reservoir has an "Anti-Flood" switch. The removing of this water will "Reset" this Switch, and allow the dishwasher to work again.
    So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method.Service manual below, if the above doesn't help. http://appliancejunk.com/ge/dishwasher/31-9137.pdf
    Jun 24, 2010 | Hotpoint 24 in. FDW60 Free-standing...
    Hotpoint aquarius fdw20 fault lights
    take base plate off and check for debris in the wash pump
    Jan 11, 2009 | Dishwashers
    Hotpoint sdw dishwasher
    It is possible drain pump blocked, you need to empty d/washer manually, check inside drain pump which is at end of drain hose, always isolate d/washer from power before attempting any work on it.
    Aug 14, 2008 | Neff 24 in. S5456 Built-in Dishwasher
    FDW40
    This is a blocked pump,Strip down pump and remove blockage.
    Jul 24, 2008 | Hotpoint 24 in. FDW60 Free-standing...
    Hotpoint a10 error message
    Dishwasher starts water runs ok then stops and flashes A10 ???
    what does this mean,, Ian . iandavison2004@msn.com
    Jun 29, 2008 | Hotpoint Dishwashers
    Hotpoint fdw80 dishwasher
    Faulty heating element. Had the same error and got Hotpoint to replace the element. Error was also confirmed by their engineer.
    Apr 13, 2008 | Hotpoint 24 in. DWF32P Free-standing...
    Hotpoint Aquarius+ FDW70 Error Codes
    i have the same on my dishwasher and have just been looking on the net. Found out that the error code A10 means open/short circuit fill value traic. Whatever that means!!! and to book a service engineer. Hope that helps
    May 04, 2007 | Hotpoint 24 in. FDW60 Free-standing...
    Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
    115 people viewed this question
    Top Hotpoint Dishwashers Experts
    Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
