Question about LG 42pa4500 42 720p Plasma Tv 42pa4500
My lg42pa4500 wont turn on after a power failure
My tv wont turn on and the blue light on the power button wont turn red
Could be an open internal fuse or power supply failure
May 16, 2017 | Televison & Video
Silvanya LC321SS9 B standby led... wont turn on
Nov 18, 2016 | Sylvania Televison & Video
Why wont dell i15rv-9762blk wont turn on
Obviously there are no error messages, so it isn't a simple failure.
Several reasons:
1. Dead or damaged battery - look for laptop battery error light or replace battery (borrow a working battery to test)
2. Dead or damaged Power Supply- look for power-on light to confirm operation. Replace PS if dead. (Borrow?)
3. System board failure. No lights/errors messages etc. Place warranty claim.
Aug 10, 2014 | Dell Computers & Internet
Compaq A900 i replaced the dc jack the laptop wont charge bought new battery and charger and still wont turn on
A battery that will not charge may be as a result of an AC adapter failure, a system board failure, or a battery failure. You should therefore try to troubleshoot the power supply, the System Board and the battery. You can read more through the following site.
Sep 22, 2013 | Computers & Internet
Why does my dell inspiron m5030 laptop give me a series of 5 beeps and wont boot when I try to turn it on?
Please read this:
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
Jan 12, 2013 | Dell Inspiron M5030 Laptop
My IBM T40 has got a liquid spillage on the keyboard while was operating !! , when I left it for some time then tried again, it powered up normally & worked very fine But once it turned off , it...
Once the liquid was spilled it was important to open and do a full clean up on the board. Now it seems there is moisture or shorting in the board due to this which can cause this malfunction.
So it is best to remove the keypad and check on the mother board. Clean the board and dry using a hair dryer. Make sure that the keyboard also is fully dry .
Reset only after the board is fully found to be dry . If the set wont power ON then some damge was done when it was powered the last time due to the spillover shorting.
Sep 20, 2011 | IBM ThinkPad T40 2373 Notebook
Power button wont turn on
Possible failure of the main power which is a SMPS or the failure of the processor in the main board.
Please check the link for tips on power supply.
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Apr 21, 2011 | Televison & Video
My 42" technika tv wont
Possible failure of the power supply in the TV. This is the SMPS type and so the failure of the driver must be checked. Please find the link below for tips.
Feb 02, 2011 | Televison & Video
Acer aspire 4930 wont turn on
If the power LED on the Notebook is blinking but not turning ON then the issue is related to the power supply unit and service is required.
Nov 03, 2009 | Acer Aspire 4930-6862 Laptop
LG 42pa4500 42 720p Plasma Tv 42pa4500 Logo
73 people viewed this question
Computer Repairing
Computer Repairing
