Question about HP Photosmart D7460 Printer
Hp d7460 ink cartridge expired. replaced istill have error message
SOURCE: HP Photosmart D7460 problem
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone.
/Putte
Posted on Oct 05, 2008
SOURCE: officejet d135 - "Supply Expired" error message
HP, in order to sell more ink, monitors the expiration date of the cartridges installed. Solution is either to buy a new unexpired cartridge from HP or to disable the date monitoring built in to the printer. This latter is done by removing the button cell located inside the D135 printer on the left hand side or by simply slipping a thin piece of plastic between button cell and metal contact. You will no longer have date function on printer, but it won't object to expired cartridges either.
Posted on Oct 18, 2008
SOURCE: 8250 HP INK EXPIRED MESSAGE
I had same problem, and i solved it.
I opened my hp 8250 and removed it`s battery. It is located on left side of the printer, on the main board. You need to remove plastic covers , and then remove 3 screws holding board. You can move board just enough to get damn battery out of there. Now it works perfect!
I can send you some piccs if you need help.
Regards
Sasa
Posted on Nov 02, 2008
leroyal
  • 2120 Answers
SOURCE: supply expired
You can't. Cartridges have a date bomb built in, they may be expired.
Posted on Jan 20, 2009
SOURCE: Expire dates on ink cartridge
I've found a site that has the photos for disassembly!
http://hpphotosmart8250.blogspot.com/
Regards,
Louis
Posted on Mar 02, 2009
How to fix Ink System Failure Oxc18a0206 error message?
Hi John,
Please do check this link which will give you the detailed steps about the HP Cartridge Printer issue that you have
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00786043&cc=us&lc=en&dlc=en&product=439491&tmp_track_link=ot_search
Jul 13, 2014 | HP for D7355 D7360 D7460 D7355 12 Pack 02...
Printer error message
Is this an OEM ink jet cartridge -meaning was it made by HP and not a refill. There is a microchip on the ink cartridge that the printer logs how many times it has used that cartridge and how many times the print head is cleaned. If this chip gets dirty or if the mating side has ink or paper dust on that side you can clean it with isopropyl alcohol. If it was a refill or a generic cartridge the chip might not be programmed or it is dead. There is no sensor that detects how much ink is in a cartridge.
Mar 29, 2014 | HP Office Equipment & Supplies
I bought a black ink for my hp photosmart c5 180 and the when i turn on the printer it says the ink has expired. Can i still use it or will i damage my printer. Thanks regards Anita
Hello
according to HP
Each ink cartridge has an expiration date. The purpose of expiration is to protect the printing system and to ensure ink quality. When you receive an ink cartridge(s) are expired message, remove and replace the expired ink cartridge, and then close the message. You can also continue printing without replacing the ink cartridge, by following the instructions on the HP All-in-One or the ink cartridge expiration message on your computer screen. HP recommends replacing the expired ink cartridges. HP cannot guarantee the quality or reliability of expired ink cartridges. Device service or repairs required as a result of using expired ink will not be covered under warranty.
You can get more detail from here
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00819032&dlc=en&product=1153481
Hope this helps, if so do rate the solution
Dec 31, 2010 | HP Photosmart C5180 All-In-One InkJet...
Run out ink error warning message
are using a refilled cartridge?
if yes, install an actual brand new one.
are you using an official cartridge that you've had laying around for a while?
the cartridges expire so check if your cartridge has expired and replaced accordingly.
Mar 29, 2010 | HP Photosmart C7280 Laser Printer
Hp photosmart d7200 erro Oxc18a0001
Filling your cartridge with non-HP ink won't cause an error. There are basically two reasons for ink system failure, The cartridge is no good or the ink system has failed. Some of these machines can be reset. But, try replacing cartridge first.
Jul 16, 2009 | HP Photosmart D7460 Printer
Supply expired
Jan 20, 2009 | HP OfficeJet d145 InkJet Printer
Officejet d135 - "Supply Expired" error message
Aug 07, 2008 | HP OfficeJet D135 All-In-One InkJet...
/Putte
May 15, 2008 | HP Photosmart D7460 Printer
Hp Officejet 7110 Not Printing From Computer
HP 7110 Printer
The problem with the printer is it does not work, there are flashing lights and the message it gives you is to turn the power on and turn it back on. Needless to say when I reboot the system and unplug the printer and plug it back up, I get the same message, does anyone have any solutions to this problem????
Sep 07, 2007 | HP OfficeJet 7110 All-In-One Thermal...
HP Photosmart D7460 Printer Logo
41 people viewed this question
Seeker5211
Seeker5211
