Question about Edirol UA-25 External Sound System
Edirol not able to record on Cubase essentials
I am able to hear my audio through edirol, but am unable to register a recordable sound on cubase.
  • 86 Answers
This interface works fine with other hosts but with cubase is more tricky. But you can fix it.
You need to disable the onboard sound card, also use the UA25 Asio drivers, go to programs/Steinberg cubase/ ASIO multimedia setup and you should see the UA25 outports are active and that the sync ref "YES" also that the UA25 Input ports are active. the next bit is a bit of fun select the Advanced options and select Detect buffer size, when thats finished select Check Buffers and Sync, press the start button and the test will run,if everything is ok you should have zero "Sync lost" and zero "Buffer lost"
Depending on how lower you want to get your latency , you may have to tweek the UA25 driver settings and re-run the setup above.
Posted on Jan 25, 2009
Will this work with cubase le4?
cubase le is a learning series. you can try in cubase sx or nuendo for good result.
Apr 06, 2010 | Steinberg Cubase System 4 USB Audio...
Do not get MIDI signal via EDIROL UA25
Midi is data only, there is no actual sound to the midi tracks themselves. They need to be assigned to either a software synth or an external synth to actually make the sounds you want to hear.
For instance if you load a demo of a midi sequance you will need to add a software synth such as the TTS-1 or Roland sound canvas which are general midi compatable and will play the instruments sounds assigned to the demo's midi channels. Use the Synth Rack feature in Sonar to open one of them. Then you will need to assign the output of each of the midi tracks to that particular synth and you will get sound. Make sure to assing the synth's audio track to you UA-25 as its audio output.
I would suggest reading in the manual and following the tutorials included in the manual to get yourself familier with how this is all done. spacer.gif
May 25, 2008 | Edirol UA-25 External Sound System
Digital in out
The ada800 gives out 8 channels of ADAT, the edirol UA-25 are only stereo opticals and not compatible with the ADA8000 as it does not have any adat inputs or outputs.
Hope this helps
Jan 31, 2010 | Edirol UA-25 External Sound System
Problems recording on acid pro 7 with edirol ua4-fx
point nr 1:
when you record midi, you are not recording sound but a key code and time info it was pressed.
point nr 2:
the midi keyboard may be seen as a remote controller.
check the midi configuration on your software host
Jan 22, 2009 | Edirol UA-4FX External Sound System
Cannot record
Im having the same probz, got a Hp Pavilion Vista using mobile pre amp usb when i record using a condenser mic XLR nothing is picked up from the channels in Cubase or Nuendo. Im trying to record vocals but the Mic is not picked up and i cannot hear myself in the headphones and it wont transfere to cubase.
It has worked before when i had a desktop, but this only worked with a separate m-audio sound card inside the desktop and i plug in the output jax leads from the desktop (soundcard) to the m-audio usb pre amp
Is this why it is not working for the laptop do i need a Jax connection and where is this audacity
Sep 15, 2008 | M-Audio M AUDIO MOBILE PRE - USB MIC...
No sound being picked up by Edirol
I discoverd the the digital in button had been pressed in. This was the mic was not picking up any sound.
Jul 09, 2008 | Edirol UA-25 External Sound System
Tascam us 144 sync problems with cubase le
Hey lea,
i have a similar setup (Cubase LE & Tascam 144) and each time i start up Cubase i have to make sure there is no digital input going to the tascam. once cubase is started up but no project loaded i plug in my spdif from my DAT machine and then open my project and all is fine. does that answer part of your question?
i have a different problem though, i'm trying to record my DAT tapes which are recorded at 32khz and cubase doesn't recognize that sample rate properly. it'll record no problem, and play them back fine, but exporting always creates mismatched sample rates in the exported file. sucks big time and i have got no idea on how to fix it either.
Mar 04, 2008 | Tascam US-144 Sound Card
Latency and EDIROL PC-50
The main cause of latency is your hardware. What kind of soundcard do you have? If you are using the one that came with your computer then that is your problem, no matter how good or new your PC is, manufacturers like to save costs by using cheap motherboard mounted soundcards, I had exactly the same problem as you when I started using a MIDI keyboard with cubase.
I'd suggest buying a soundcard designed for audio applications, I use the M-Audio Fasttrack which you can pick up very cheaply nowadays. I have my latency down to around 1/20 second and as an added bonus I get a 1/4 input and an XLR input as well for recording.
Dec 03, 2007 | Edirol Virtual Sound Canvas (EDIVSCMP12)...
Saving preset in Cubase
again i have the same problem. if anyone knows PLEASE TELL ME..
Aug 15, 2006 | Edirol HQ Orchestral (hqor)
Edirol UA-25 External Sound System Logo
714 people viewed this question
Top Edirol Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
David
David
Ben Armstrong
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
