Question about Playrix Call of Atlantis
Call of Atlantis in Egypt level 6; how do i get the puzzle pieces out?
  • crkrdrs
    crkrdrs Jan 18, 2013
    Its Babylon level 6 not Egypt my mistake.
  • crkrdrs
    My mistake its Babylon level 6 not Egypt.
Sculpture puzzle answers or solutions
If you can see a four digit code on each piece, the second number tells you in what part of the puzzle the piece should be. Example: All pieces with second number a three should be in the same "part" or area. Then You should take the two last numbers from the code and minus the first number, example 13-6=7 then this piece is the seventh piece in the third module. You will get for all modules pieces with numbers from 1 to 30 after some calculation. Put the pieces in order smallest most under and bigger higher up. And start with "module" 1.
This was at least how the puzzle should be assembled. I hope this helped you!!!
Jan 21, 2018 | Toys
How to solve a moon shaped 3d crystal puzzle
23 20 21 3 post 14 18 10 15 17 7 8 1 16 12 11 9 6 5 2 19 4 22 13 then 13 22 4 19 2 5 6 9 11 12 16 1 8 7 17 15 10 18 14 3 21 20 23. Good luck (especially telling 6 and 9 apart)
Jul 07, 2012 | Puzzle Toys
Got gift-One Tough Puzzle 9 pieces-one solution. what is the solution?
I wrote some JavaScript code to solve the puzzle that let's you watch the progress on the screen.
http://www.codersrevolution.com/index.cfm/2012/9/29/My-One-Tough-Puzzle-JavaScript-Brute-Force-Solution
Jan 18, 2012 | Puzzle Video Game Consoles & Games
I'm having trouble beating level 34 in the hacking section of the Code Lyoko DS game. I've pretty much tried almost every possible way, but I'm stuck. Can you help me please?
This guide suggests the following:
"Place the first piece on the left against the left edge of the puzzle. Put the first piece on the right against the top edge, against the first piece you put in. Put the third piece on the left int the bottom right corner of the puzzle, then put the fourth piece on the left against that one. Now put the second piece on the left in the remaining space."
Jul 20, 2011 | Atlus Code Lyoko for DS
Can we buy replacement parts for a Charles Wysocki jigsaw puzzle? It is a 1000 piece puzzle called "Uncle Jack's Topiary tendencies". We need three pieces. Thank you
Hi jmcginnity
PLEASE RATE MY ANSWER IF YOU FIND IT HELPFUL !
Q: I have a missing puzzle piece. How can I get a replacement puzzle?
A: The Charles Wysocki Gallery does not make the puzzles. We buy them from Hasbro. Please visit Hasbro's website at www.hasbro.com and click on their customer service link for help with missing puzzle pieces.
Jan 30, 2011 | Milton Bradley Charles Wysocki Americana...
My son is stuck on level 6 or 7 of Crazy Chicken: Atlantis Quest. It's one of the water levels and when he swims down to the bottom there is a gate that he can't figure out how to open. Any suggestions?
he just has to punch the lg things that look like quarell, they spit out air bubbles if u hit them. then just keep eye on ur o2 levels, and either go up for air or hit anothjer quarrel. hope that helps. i cant get passed fighting the guy on lvl 17?
Jan 02, 2011 | MumboJumbo Crazy Chicken Atlantis Quest...
I have no instructions for an MB sculpture puzzle called Rodin the kiss can you help me please? Regards Dee
Hi DEEHARDY,
I bought tge same puzzle (I think) from a fleemarket yesterday!
It was very old and had been there for a long time I think, but the box was unopened!! In it all instructions were in all other languages but not in english. But I know some German so I managed to understand! The thing with the puzzle is to try yourself first how You think it is supposed to be. But in the intstructions there is given a hint with "mirror text" if You can not get started. Here I give You the hint: If it is the same puzzle, You can see a four digit code on each piece. The second number tells You in what part of the puzzle the piece should be. Example: All pieces with second number a three should be in the same "part" or area. Then You should take the two last numbers from the code and minus the first number, example 13-6=7 then this piece is the seventh piece in the third module. You will get for all modules pieces with numbers from 1 to 30 after some calculation. Put the pieces in order smallest most under and bigger higher up. And start with "module" 1.
This was at least how my puzzle should be assemblied. I hope this helped You!!!
Greetings from Finland!
Jun 29, 2010 | Toys
Passat car stop suddenly while moving
I would ask your company to replace your car for you. I would also take it back to where they fixed it and have them fix it again.
Jul 04, 2009 | 2007 Volkswagen Passat Sedan
I bought Atlantis Quest from Best Buy, it installed fine, but it
Looking around online, I'm seeing only a game called Atlantis Quest that's a puzzle game. Check the game's instruction manual for the name of the publisher. You can contact them for support. If they're unable to help you, Best Buy should be able to give you a refund or exchange. Good luck!
Jan 03, 2009 | Got Game Atlantis Quest for Windows
Jeep tj carpet
I don't think there is a diagram for this... Really... You can't put together a five or six piece puzzle??? Use the seat bolt holes& stuff as guides. The front piece can only fit there, and then you only have four or five pieces left!!!
Sep 14, 2008 | 1997 Jeep Tj
Playrix Call of Atlantis Logo
Top Playrix Apps Experts
Bill Boyd
ray gallant
Are you a Playrix App Expert? Answer questions, earn points and help others
