Question about Karcher X-Series K3.540 1800psi Electric Pressure Washer - -
How to remove wheel clip k3.540
Wheel clip is off center need to remove. how?
Removing rear bumper cover for 2007 uplander
Lift the tail gate. There are clips or screws along the top edge. Remove this. The clips all you do is pull the center pin with a panel tool or pliers then the rest will come out. Then you will need to remove the clips holding the rear side of each of the back wheel wells in. Under that will be more clips, screws or bolts that hold the side edges of the bumper cover on.
Aug 19, 2016 | 2007 Chevrolet Uplander
Rear axle removal 98 gmc 2500 four wheel drive
the 2500 had two different axle housing the hd version had bolts in the center of the wheel under the hub cap the light duty you need to remove the cover in the center of the housing in the middle of the rear end then remove the 5/16 bolt the holds the center pin in the diff case then push the axle in and remove the large c clip then the axle shaft will pull out
Jun 30, 2012 | Cars & Trucks
I purchased a older MTD 12 HP lawn tractor. How do I remove the rear wheels in order to replace the tires? Do I need a special tool. I can not see anything to put a wrench to.
theres a screw and a bell washer in the center of the rear wheel , maybe covered by a cap, check this link for a breakdown on that machine as its what I located with the specs you gave http://www.searspartsdirect.com/partsdirect/part-model/Mtd-Parts/Riding-mower-tractor-Parts/Model-33925A/0736/1509200/WL000275/00009
http://c.searspartsdirect.com/lis_png/PLDM/WL000275-00009.png thats the rear wheels diagram
Jul 11, 2011 | Garden
Stearingwheel removeal
After the wheel center is removed, remove the clip (If it has one) then the nut, and then you need a steering wheel puller! Make sure you mark where the wheel is to re-install it.
Sep 18, 2010 | Dodge Neon Cars & Trucks
How to install a horn button in a chevrolet impala
HELLO THERE
fIrst you will need to take off the center section on the steeringwheel usually it is clipped into place it also may have 2 screws on the back side of the steering wheel. once this is done
using a flat tip screwdriver lightly pry up from one side of the center piece and lift the section out now you should be able to see or axcess the horn button simply remove the holding screws and remove the horn button install the new piece and screw into place and replace the steering wheel center piece and make sure that it clips into
place and test ok?
best regards michael
Nov 16, 2009 | 1992 Honda Civic
How can i replace the key switch in a 01 Grand AM and will i need to replace the security mod too?
It depends if you want to change the key barrel or the tumblers, to remove the tumbler set put key in the switch, remove the beauty ring it just snaps on then stick a paper clip into the hole where you removed the ring or on the bottom of the barrel turn the key in reverse past accessories and pull tumbler set out. if you need to remove the barrel you will have unhook the battery then take horn cover off, pull the protective plastic tabs off the rear of the steering wheel and remove the safety tork screws and remove the air bag disconnect the air bag plug. next remove the three screws holding the horn ground ring and the plastic piece that separates it from ground put them in order next remove the center bolt using a steering wheel puller pull steering wheel next compress the plastic cover with the U shaped steering wheel clap and push the plastic dust cover down 1/4 inch next remove the center c cer-clip slide the clip off of the steering wheel shaft remove the dust cover remove the copper tangs on the right side of shaft and you will see a #6 tork screw remove that one screw and the barrel will come out, on some models it's the only way to get the barrel out. If this helps plese rate me. I am a better mechanic than a typest.
Aug 07, 2009 | 2001 Pontiac Grand Am SE
1992 Oldsmobile cutlass sierra
First you need to go to the local parts store and get a steering wheel puller and a clock spring compressor tool. You can rent them but just cheaper to buy it and return it. I got mind like 35 bucks together.
You will remove the horn button just by pulling it towards you be careful not to rip the horn wire out. Next there may be a retainer clip remove it with a pair of needle nose pliers. Next get a breaker bar or a impact gun to back the center nut off. Once off use the steering wheel puller by inserting the threaded bolts into the threaded holes directly beside the center pin. ease the puller onto the center pin and tighten down until the steering wheel starts to move back towards you continue until off. On some trucks there is a steel plate covering the housing to the left side and towards the top are two small torx screws remove them and remove the cover. Next grab your clock spring compressor and install it similar to the way you did the wheel puller you will tighten down the center bolt slightly decompressing the clock spring. as you compress the clock spring look to the center there is a small retainer clip that looks like it is made into the center pin pry the clip off making sure not to damage it and remove the compressor tool, remove the clock spring making sure to pay attention on how it comes apart you can put it all back together. Remove the turn signal switch should be 3 phillips head screws. You may need to disconnect the horn wire at this point it just turns slightly and pulls out. After you remove the clock spring you will see the lock cylinder body, follow the body towards the center pin. There will be a small torx bit or a phillips screw to it will be silver and very shinny at the end of the lock housing remove it and slide the lock cylinder out. Install the new one and reverse the steps.
hope this helps...........good luck!
Dec 29, 2008 | 1996 Oldsmobile Cutlass Ciera
Ignition
You will remove the horn button just by pulling it towards you be careful not to rip the horn wire out. Next there may be a retainer clip remove it with a pair of needle nose pliers. Next get a breaker bar or a impact gun to back the center nut off. Once off use the steering wheel puller by inserting the threaded bolts into the threaded holes directly beside the center pin. ease the puller onto the center pin and tighten down until the steering wheel starts to move back towards you continue until off. On some trucks there is a steel plate covering the housing to the left side and towards the top are two small torx screws remove them and remove the cover. Next grab your clock spring compressor and install it similar to the way you did the wheel puller you will tighten down the center bolt slightly decompressing the clock spring. as you compress the clock spring look to the center there is a small retainer clip that looks like it is made into the center pin pry the clip off making sure not to damage it and remove the compressor tool, remove the clock spring making sure to pay attention on how it comes apart you can put it all back together. Remove the turn signal switch should be 3 phillips head screws. You may need to disconnect the horn wire at this point it just turns slightly and pulls out. After you remove the clock spring you will see the lock cylinder body, follow the body towards the center pin. There will be a small torx bit to it will be silver and very shinny at the end of the lock housing remove it and slide the lock cylinder out. Install the new one and reverse the steps.
hope this helps.....good luck!
Oct 07, 2008 | 1996 Oldsmobile Cutlass Ciera
Rear end
remove the wheels center pin and bolt your best to heat the bolt a little and push the axles together and you will see the c clip
Sep 27, 2008 | 1996 Ford Explorer
I am replacing an ignition in my 94 silverado. I took off the stearing wheel and now i am confused on what to do next to get to the ignition lock.
Jul 15, 2008 | 1998 Chevrolet K1500
Karcher X-Series K3.540 1800psi Electric Pressure Washer - - Logo
62 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
