Question about Dell Dimension E310 PC Desktop
Dell dimension e310 flashing amber light very slow start up
    Novelist:
  • 250 Answers
Manage Windows Startup: Make sure that the startup programs are not many in number which unnecessarily makes system slow when it put to start.
While using PC optimizer RegInOut you can manage start up options
Posted on Jan 18, 2013
SOURCE: 4600C no power, flashing amber light
The problem is with your microwave. The Dell PC on boot has detected the radiowaves. This has in turn when booting the Dell put it in to Ultra Safe Mode. This is new to this model Dell- the advantage is that you can still cook your ready made meal with out damaging the system board capacitors. Once the micro wave has finished you will be able to boot - dont forget it may be your neighbours micro wave!!
Posted on Apr 09, 2008
pagebor
  • 2785 Answers
SOURCE: Dell Dimension 8300 flashing amber power light and dead pc
it seems *********** board is having problem plz send it for servicing
Posted on Aug 08, 2008
  • 8 Answers
SOURCE: dell dimension 8100 diagnostic lights
Green Green Green amber is a start of "POV" whatever this stands for. Dells description is "System activity subsequent to video initalization" I would start with video card replacement,
Posted on Jan 09, 2009
  • 8 Answers
SOURCE: Can't boot up Dell 5100 Dimension, amber light flashes
When you mean the amber light, is that the blinking hard drive access light or the power light? Different cases have different colors on it. Mine has blue and green lights.
If you see the boot screen (bios) and then after it goes to boot, does it blink and hang?
This could be a simple operating system issue, hard drive or hardware/motherboard issue. If you could provide more information, that would help.
Posted on Jun 28, 2009
SOURCE: Dell dimension 5150 blinking amber lights
I have similar problem these days. After normal shutting down the PC, it can not be powered up again, the amber light blinks. A temp solution for my case is by doing these steps:
1. leave all monitor, network, keyboard and mouse etc. connected
2. disconnect the power, wait until green light and amber light dim.
3. pop up the CMOS battery, then put back in (better to check its remaining voltage, if not good, change a new one)
4. power amber light flash shorter and lighter
5. disconnect any USB connections like keyboard and mouse,
6. immediately connect keyboard and mouse back into USB ports
7. my pc powers up at this point, all green lights shining. Except it displays CMOS setup warnings, give me options to click either F1 or F2
8. I click F1, it goes into normal login XP
The only problem is I could not shutdown PC again, if I do, then I have to repeat 1-8. I have to use "Standby" instead, which I usually do.
Posted on Sep 01, 2009
I have a Dell Dimension E310 with the power button flashing amber. I recently replaced the power supply due to an electrical storm, good reason to suspect the power supply. But the only way to get past...
i suggest using a PCI ethernet lan card with drivers cd. this should allow the bypass of the integrated connection to be that of the newly installed device.
Jan 17, 2011 | Dell Dimension E310 PC Desktop
Hi. I have a dell e310...and the desk top turns on but the monitor will not display anything...it has an amber light..sometimes.it will turn to green but then shuts off again Could this be a bad video...
depends . either the video card or motherboard see if the blue video connector is at the top or twords the bottom of the case and that will tell you if it's a card or integrated on the board.
May 13, 2010 | Dell Dimension E310 PC Desktop
Dell Dimension power button flashes amber and will
open up your system get a can of air and blow all dust away could be an overheating fault
May 13, 2010 | Dell Dimension™ E510 PC Desktop
That's a possibility, but have you tried checking that everything is connected behind the stack? I wouldn't go into major surgery on your computer until you rule out all the simple ideas. It could just be the monitor too.
Mar 22, 2010 | Dell Dimension E310 PC Desktop
Dell dimension e310 desk top will not power on
If the POWER Button on the TOWER is blinking AMBER (Yellow) then the most likely failure point is the POWER SUPPLY in the Tower.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817226001
Dec 21, 2009 | Dell Dimension E310 PC Desktop
Dimension e310- Black screen when powering on, 1 & 2 lights blink
Generally, the 1 and 2 Diagnostic LEDs indicate a failure of a PCI expansion card.
http://support.dell.com/support/edocs/systems/dim3100/en/sm/adtshoot.htm#wp1130520
So remove any expansion cards, see if anything changes. If it does, one of the PCI cards is suspect.
If the system has an expansion video card in the PCI-E slot, and removing the PCI cards had no effect, remove the PCI-E video card and connect to the intergrated video port (You may have to remove a black cover from the port) and see if you get video. If you do, then the Expansion video card has failed.
Nov 21, 2009 | Dell Computers & Internet
Blinking amber light and wont boot up.
if the power button was blinking amber, unplug your tower, and hold the power button for 30 seconds to 1 minute, to use any excess power stored in the capassitors in the pc. this was told to me by a dell tech, it is a small issue with the 3100=E310, and 5150=E510 Dimension desktops
Sep 24, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Amber light flashing, computer wont start up.
I have a dell 4700C and the amber light flashing, computer wont start up.
Aug 01, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Jun 28, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Dimension E310
Im not sure if you are asking for the E310 drivers or the 4600c drivers, so I'm sending you the link to download drivers for both the systems.
http://tinyurl.com/2jpgqs (Thats for E310)
http://tinyurl.com/5jzwtd (Thats for 4600c)
All the best fixing your system
Mandeep
Jun 15, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension E310 PC Desktop Logo
41 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
