Question about Ryobi Cultivator
Ryobi ry60514 is frozen.
Tiller froze up while running. Blades will not move.
    Sergeant:
  • 322 Answers
Does the engine turn over? If not then it has most likely seized. If the engine turns but the blades won't then make sure you didn't wrap something around the tines causing it to bind up
Posted on Jan 17, 2013
2 Suggested Answers
pranaclimbin
  • 50 Answers
SOURCE: Ryobi ry60514 tines won't turn
there are shear bolts that hold the tines on. they are designed to snap when u hit something big such as a big rock or pipe or something like that. they are designed to snap at so much pounds of pressure so u dont break any gears or gearshafts. a lot of times people dont realize this and put regular screws or bolts in it and run it. when they hit something they ussually snap the gearshaft inside the tiller. i have replaced this on my fathers tiller cause he did the same thing. so either u might need to put new shear bolts in or if u had a regular bolt in u probably snapped a gear shaft or a gear.
Posted on Dec 04, 2008
Oil to gas ratio of ry60514 ryobi roto tiller?
50 to 1
http://www.manualagent.com/ryobi/ry60514/owners-manual
Apr 02, 2015 | Ryobi Garden
Ryobi ry64400 tiller tines won't move engine runs fine
then you need to open the gear box and find out why if it has a forward and reverse the the shifting linkage it could be stuck in one gear and adding the other will lock it up as well
Apr 17, 2012 | Ryobi Cultivator
My tiller was working fine. Then it acted like something had jammed the blades. I removed the blades and nothing is wedged. The engine runs but bogs down because the shaft is not spinning. It acts like...
Sorry Bob, it needs shop time. The part under the motor and between the two blade sets is the transmission. The input shaft from the motor is geared to turn the blade shaft; either may be frozen if there wasn't enough grease in the trans or it's possible a gear tooth broke and jammed the system. You have to remove the trans, take off the blades and get inside it to see if the grease is contaminated or if it even has any in it. Check for peices that may have jammed in the gears also. If all of the parts are intact, clean out all of the old grease and pack as much new grease in as you can get in it.
Oct 28, 2010 | Mantis 2-Cycle Tiller
Mower blades froze up
Have you greased the bearings on the mower deck recently? Is there something jamming the blades?
Remove the deck and see if you can move the blades by hand. If you insist on not removing the deck to do this ... make sure the belt that drives the deck is not on the drive shaft of the motor to prevent accidental starting of the motor and instant mangling of your hand. If you can move all the blades, look for a faulty or worn out pulley on the deck. If the blades are frozen in their bearings, get replacement towers at your John Deere dealer or from a FixYa.com advertiser. If one is faulty or rusted ... replace them all ... as they are probably at or near the same condition. Do this job one time and do it correctly.
Thanks for your support.
Thanks for your interest in FixYa.com
Please evaluate this response.
Thanks
Good luck with your repair.
Jul 05, 2010 | John Deere 24HP VTwin Hydrostatic 48"...
Ryobi rht266oda 26cc petrol hedge trimmer. runs well blades move but will not cut very well, only got last year and went well, nut and boult came loose this year first time out was mended but will not cut,...
You may need to take it to a professional to sharpen. It may have some trash in between the blades keeping it from not cutting. Plus when you use it try spraying some WD40 on the blades to help them move and cut.
Sep 29, 2009 | Ryobi Garden
My B & D electric hedge trimmer blades are frozen
spray liberally with wd40, let side and hour spray rag with wd40 and clean blades and look for any bent teeth in blade that maybe binding them as u clean use pliers and screwdriver to move if any found, it is likely that wither sap dried or rust formed and is creating too much friction for blades to move wd40 will help free up blades
Jul 09, 2009 | Black & Decker Black Decker 16" Hedge...
Which small ''mini'' tiller to purchase
Definitely stay away from Ryobi, Troy Bilt, Bolens and Yard Machines by MTD. They are all Ryobi with different brand names on them. (goes for trimmers too) MTD owns them all. The best small tiller, IMHO, is Mantis. (2-cycle) I think Sears sells them now. I have one and it will run circles around the rest.
Jun 14, 2009 | Ardisam Inc Earthquake Mini Cultivator
Motor run but blades don't
mine is doing the same thing
May 14, 2009 | Mantis Tiller
Nov 23, 2008 | Ryobi Cultivator
Ryobi Cultivator Logo
389 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
