Amana top load washer leaves water in drum - Washing Machines
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 66 Answers
Hose might be kinked or something in pump
Posted on Jan 18, 2013
SOURCE: Amana ALW480DAW Top Load Washer
sometimes the pump becomes stripped where the motor shaft goes into it.
Posted on Jan 30, 2008
  • 105 Answers
SOURCE: Crosley caw5923mqd Top Load washer spins but leaves A LOT of water in the clothes
have you checked the pump out of the maachine
the pump may be blocked restricting water flow
if that is ok maybe you need to give the n
machine a hot wash the seals may be draging the spin down
Posted on Mar 16, 2008
  • 1122 Answers
SOURCE: I have water coming from the bottom. How do I take
remove the 2 bottom front panel screws-mike
Posted on Jul 29, 2009
  • 574 Answers
SOURCE: not enough water in the drum during the washing cycle
If its a High efficiency washer it doesn't use much water. Usually the front load washers are HE washers
Posted on Aug 30, 2009
mpcheeseman1
  • 1400 Answers
SOURCE: The washer leaves water remaining in drum after
Hello
Check the drain tube,it needs to be 30 inches above the floor.
Also if the drain tube from the washer is too far into the drain the washer will not drain completly.The drain tube should be 1 inch into the wall drain.
Also check for kinks or obstructions in the washer drain tube.
Posted on May 13, 2010
Amana NTW4700YQ Top Load Washer will not drain
Hopefully you have it under warranty. You will probably need another wire harness. Double check your outlet to make sure it is grounded properly because they will 'nit pick' and tell you it is your fault for not having a properly grounded outlet.
Jul 20, 2014 | Amana NTW4700YQ Top Load Washer NTW4700YQ
When starting spin cycle, water overflows the top of the drum.
Find the water level switch inside the control panel and make sure the hose going to it is secure and clear of any sediment in the tub. THEN pump it out before retrying.themobilian_1086.jpg
More here
Jan 27, 2011 | Amana ALW480DA Top Load Washer
Washer wont stop filling
Your washer ahs a float stop switch that controls the water level in your washing machine located behind the drum please replace it
Sep 24, 2010 | Amana NAV5800A Top Load Washer
Amana washer model# nav4800aww leaks water on the floor while washing large loads. Now it does it on all loads.
firstly remove rear cover and check during running if any hose is leak?
or-
water seal inside drum is leak for this drum has to be open. mostly bearing are damager due to water entering bearings. so bearing are needs replacement.
Nov 05, 2009 | Amana Washing Machines
Amana nav5800aww water on floor after spin cycle
Sounds very similar to having something such as a sock or small article of clothing that is too large to be sucked down the drain hose into the pump. So what happens is it hangs around between the inner and outer drums and sometimes gets itself lodged over the drum drain hole, and can allow water to be centrifically flung over the top of the drum. Most times when the spin cycle stops, the article of clothing will dislodge and float around inside the drum only to do it again later....
If you can remove the top of the machine, you can usually see the gap between the two drums and use a piece of coathanger wire with a small hook on the end and "go fishing in the area between the two drums and close to the drain hole location... bet you'll find something in there... Let me know how it goes... and if I can help .. ken
May 10, 2009 | Amana NAV5800A Top Load Washer
The drum wont hold water. it goes right out the draim
The drain needs to be above the actual water level or it will run out, the pvc should be above this point in order for the hose to get air and not act like trap and run out all that comes in,< woud suggest going to hardware store and getting piece to add on to 4 inch section with a coupler and washer drain cap>. they will cut to length, < take measurement of pipe size and length needed to get just bellow height of washer top, pvc goes together by cleaning and glueing, if the 4 inch piece has angle cut then it will have to be cut to strait line for good seal.
Apr 22, 2009 | Amana NAV3330E Top Load Washer
Belt amana washer replace mod lw6501w2
I have a similar amana top load washer and just changed the belt. Here are the steps I used to change the belt:
1) Unplug the washer
2) Slide the washer away from the wall about 12"
3) Remove two screws from the bottom of the front panel, slide the front panel down (there are 2 metal tabs that slide into slots on the top of the front panel - observe how they slide into/out of the slots). Set the panel aside.
4) Remove the electrical connector (upper left of motor). Press down on the top of the plastic connector - this will undo the catch hook holding the connection in place). Observe how the belt is routed before proceeding.
5) Remove 4 bolts holding the motor in place. You can remove the motor - even with the water pump and hoses in place - they will flex.
6) Remove the water pump from the motor. There are 3 torx - head screws to remove. Note: You will need a star shaped (torx) head driver (Looks like a screwdriver but with a "star" head on it. The one I used measured just under 3/16 in diameter.
7) carefully remove the water pump. - remove the old belt from main pulley under washer drum and also from the water pump. Insert the new belt - be sure to put the tension pulley on the outside of the belt.
8) Reinstall the water pump to the motor. Reinstall the motor. Route the belt correctly in the water pump body area first - them slide the belt around the left side of the main drum pulley - rotate the pulley counter-clockwise and the pulley will tug the belt onto the pulley. Once in place - check bolts and belt - then reattach the electrical connector (remember to press the plastic lever on top of the plastic connector before sliding it in place). Reattach front panel - slide the top of the panel onto the metal tabs - then attach screws at the bottom.
Feb 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
AMANA DISTINCTIONS FABRIC CONDITIONER RELEASE
Hello Daddy 2,
Welcome to fixya
I'm Huuum and happy to assist you,
What is the model number and the year of the washer?
Front load or top?
A waiting your response!
Huuum
Dec 10, 2007 | Amana 3.2 cu. ft. Top-Load Washer
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
