Question about Brookstone Big Blue Live Wireless Bluetooth Speaker
Big blue will not sync with my iphone - Brookstone Big Blue Live Wireless Bluetooth Speaker
How to fix iPhone 6s with blue screen
It is a quite frustrating thing that your iPhone turns into blue color and your phone reboots when you are using one of iPhone apps. The "iPhone Blue Screen of *****" issue leads to our iPhone irresponsible and will affect our normal mobile life a lot. It seems that it's most frequent to U.S. T-Mobile users. iPhone 6, 6 Plus, 5S and others are affected, so there doesn't seem any device related problem. If you are also faced with the "iPhone Blue Screen of *****" issue unfortunately, no worries, here are several solutions for you to fix it.
  1. Update or Delete the Apps
  2. Hard Reset Your iPhone
  3. Update to the Latest iOS Version
  4. Restore iPhone to Factory Settings
  5. Turn off iCloud Sync
Please click the following link to see more details about the solutions.
How to Fix IPhone Blue Screen of *****
Jun 11, 2016 | Cell Phones
How to transfer music from laptop to phone
What kind of phone is it?
If it's an android, you can transfer music by simply connecting your phone to your computer with a cable.
If you're on an iPhone, you may need iTunes installed on your laptop. Of course, a 3rd party tool can also help.
How to Transfer Music from Computer to iPhone 5s
Mar 11, 2015 | Cell Phones
Big Ble / iphone 5s pairing
clear any past stored passwords. reset unit and put into discovery mode. Usually holding the pair button for a few seconds puts the LED blue into fast flashing - discvery mode
Apr 09, 2014 | Brookstone Big Blue Live Wireless...
Iphone won't turn on, just blue screen
Did it get wet. that sounds like something that would happen if it got wet. if you don't know that it got wet you could shine a light into the headphone jack and look for a white sticker. if wet the white sticker will have turned reddish
Jan 24, 2013 | Apple iPhone 4S
How to play music in my iPhone 4 via blue tooth
first you must add your iphone in your blue tooth devices.
play your music on your ipnone.
go into the sync menu and make sure it is on blue tooth audio
if not change it to that and it should play.
Apr 28, 2011 | 2010 Hyundai Genesis Coupe
Transfer itunes purchases to iphone
HI,
this site has the guide how to do it.since its a big procedure i am pasting the link for you.///
this will guide you to how to sync it..It will automatically show up you have to do it manually..
http://www.ilounge.com/index.php/articles/comments/the-complete-guide-to-itunes-audiobooks-podcasts-itunes-u/
Jul 24, 2010 | Apple iPhone 3G
Problem loading itune to iphone 3G
ok you need to connect your iphone to your computer using your usb lead then open up itunes and in the middle on the left of the itunes program under devices should be your iphone.
click through all of the blue tabs at the top centre of the screen that has a pic of your iphone in and tick all the boxes you want to sync with and send to your iphone and from your iphone to your comp. after that click the sync key at the bottom right this will then upload your music and other stuff.
could you please rate my soloutin and if it worked aswell
thanks Nick
Jan 28, 2009 | Apple iPhone 3G
Copy all contacts from iphone to computer
open up itunes and then in the middle left of the itunes program click your iphone make sure its connected via usb lead and click on your iphone under devices
you should get the screen like the pic below. Now at the top middle of itunes you will see a number of blue tabs click the one saying info.
make sure "sync contacts with" is ticked then click on the box next to it and select windows contacts from the drop down list.
then the line of text directly under sync contacts with that says all contacts click the circle to the left of it so it has a black dot there.
now at the bottom right of your itunes program is a button sayin sync click that.
after the sync is complete all of your contacts will be on your computer
click the start button on your comp and then all programs and there should be a windows contacts there click that and you will see all of your iphone's contacts there.
PLEASE RATE THIS SOLUTION AFTER YOU HAVE FINISHED
thanks
nick
Jan 27, 2009 | Apple iPhone 3G
Syncing the HFBLU-10K with the iphone
for iphone : set your phone to scan for wireless device
1 unlock
2 settings icon
3 general
4 bluetooth ON
the hold the big button on the blue tooth once it flashes blue DO NOT LET GO! keep holding it till it flashs red and blue red and blue then let go and it should find it instantly then press on the BK-600 word and enter the 0000 code and you should be all set.
Jan 06, 2009 | Cellular Innovations HFBLU-CX1 Wireless...
Sync my contacts and calendar from outlook to iphone
You are on the right track.
You need to install the SBS 2003 SP2 package.
It contains Windows Server 2003 SP2 and Exchange 2003 SP2 along with other important updates. (It is a big download.)
Install all of the updates staring with Windows Server SP2.
Once you complete the install of Exchange SP2 your iPhone should sync.
FYI: If you use Remote Web Workplace you will need to forward TCP port 4125 on your firewall to your SBS server after this update or RWW won't work properly.
I hope this helps.
Oct 14, 2008 | Apple iPhone Smartphone
Brookstone Big Blue Live Wireless Bluetooth Speaker Logo
207 people viewed this question
Top Brookstone Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Carlos L. Burgos
Carlos L. Burgos
Are you a Brookstone Audio Player and Recorder Expert? Answer questions, earn points and help others
