Need DT-1860 Tweeter
I am looking for 2 of these. If you have them available, please get in contact with me.
Who owned the 1860 Army Colt #7957
Sorry this site has no means of looking up this type of information, please contact a local gunsmith, they may be able to assist you
Nov 27, 2016 | The Optics
Where is the amp and how do i check it in 98 cadillac
Radio Amplifier
Left hand rear of the passenger compartment, behind the rear seat back.
Check the connections , check power an ground .
Connector Part Information
12110088
24 Way F Micro-Pack 100 Series (GRY)
Pin
Wire Color
Circuit No.
Function
A1
PPL
1952
RH Front Tweeter Output -
A2
LT GRN
1852
RH Front Tweeter Output +
A3
BLK
1856
LH Front Tweeter Output +
A4
YEL
1956
LH Front Tweeter Output -
A5
DK BLU/WHT
346
Rear Shelf Subwoofer Coil 1 Output +
A6
LT GRN/BLK
1794
Rear Shelf Subwoofer Coil 1 Output -
A7
YEL
1860
Center I/P Midrange Output +
A8
LT BLU
1960
Center I/P Midrange Output -
A9
DK GRN
1795
Rear Shelf Subwoofer Coil 2 Output +
A10
LT BLU/BLK
315
Rear Shelf Subwoofer Coil 2 Output -
A11-A12
Not Used
B1
DK GRN/WHT
368
Right CD Changer Input
B2
BLK/WHT
372
CD Changer Common
B3
BRN/WHT
367
Left CD Changer Input
B4
LT GRN
1948
Right Audio Input -
B5
LT GRN/BLK
512
Right Audio Input +
B6
DK GRN
1947
Left Audio Input -
B7
TAN
511
Left Audio Input +
B8
DK BLU/WHT
653
Chime Input/Return
B9
PPL/WHT
652
Chime Input +
B10
Not Used
B11
PPL
1807
Class 2 Serial Data Line
B12
PPL
1807
Radio Amplifier (UX8) C3
showgif.do?image=35456
12064749
2 Way F Metri-Pack 480 Series (BLK)
Pin
Wire Color
Circuit No.
Function
A
BLK/WHT
651
Ground
B
RED
1242
Battery Positive Voltage (B+)
Check
Mar 22, 2016 | 1998 Cadillac Seville
Headlight blowing out
Hi, Jerry if your headlight is not working, only one beam works, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
1. Faulty ground or power supply wire to headlight bulb socket.
2. Worn down solder contacts or loose fit of the bulb base in the socket due to vibration.
3. Worn, chaffed, or broken wires in the light circuit.
4. Corroded, broken, or loose pins/sockets in wire connectors.
5. Faulty hi/lo beam switch.
6. Faulty ignition switch.
7. Fuse is good but no continuity on both sides.
8. Faulty wiring between battery positive and headlight bulb socket.
9. Weak charging alternator/generator.
10. Faulty voltage regulator/rectifier ground or overcharging.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Vintage Enduro Discussions Forums
https://yamahaclub.com/forums/topic/15855-1975-dt-175-headlight-not-working-please-help
DOWNLOAD NOW Yamaha DT250 DT360 DT 250 360 Service Repair Workshop Manual...
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-dt
Jun 16, 2013 | 1974 Yamaha DT 360
I need to buy a tweeter for my speaker can you help me.
hi,
As it hve a horn tweeter no need to replace the whole unit. You will get the diaphragm. go the following page check the third item. Its the diaphragm for JBL EON 15-G2. An the order code is
DT-004.
http://www.goodhifi.com/MyDias/Diaphragms.htm
ok
Aug 03, 2011 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Need a replacement tweeter for mackie srm 450 where can i find one
Go to the link below to either locate a dealer near you for the part or to contact Mackie directly for the part. Please note that the diaphragm may be available as a separate part. Do you need the entire tweeter or just hte diaphragm?
Dan
Link: http://www.mackie.com/support/
Aug 01, 2010 | Mackie SRM-450 System
Hi. I have just purchased a used IBM Thinkpad
Hi, I've found your user manual, you can download whatever you want from this link..
Ibm ThinkPad R52 1860 Y1S User Manuals and Guides
Open the link and select from the available lists...and download.
Good luck
Thanks for using FixYa.
Jun 23, 2010 | Computers & Internet
Can't get wharfedale melton 2 tweeter to work. Looked inside cabinet and need advice on internal wiring please. These are very old but one works perfectly and the 12'' bass driver on the problem speaker is...
The tweeter has burned out and cannot be salvaged. I also own a pair of (ex) Melton 2s. In the beginning Wharfedale were good at supplying spares (see www.wharfedale.co.uk for contact info and advice). A few years ago after my cat destroyed the 12 inch unit in one, i invested in new insides, including state of the art 12 inch woofers, 4 inch mid range and 1inch tweeters with a good 3 way crossover. The cabinet is great so consider asking a techie friend to do this for you. Please don't just cut out and connect to amp speaker wires! You will get terrible sound and risk ruining both amp and speakers! Best regards Karl (karl@simpson.nom.fr)
May 12, 2010 | Audio Players & Recorders
Tweeter not working
Check the continuity of the removed tweeter with a VOM meter (I use an original Heatkit MM-1 available on eBay for $20) and do the 1.5 volt battery click & scratch test mentioned above.
Celestion A3 tweeters (also used in the A1 and A2 speakers) or the replacement diaphragms are no longer available from Celestion. A1 speakers show up regularly on the United Kingdom eBay website for $300 or less and are small enough to economically ship to the USA. You would also end up with a midrange spare speaker (assuming it is the same as in the A3 cabinets)
The part number for the A series 3 bar tweeter is T4969/P. The 3 bars refers to the 3 bars in the casting to protect the dome. I got this number from the box of my spare tweeter I have the earlier 1 bar castings in my A3's.
Go to www.ersatzteil-versand.at do an "artikelsuche" (article search) for the number T4969/P and something extremeley similar shows up except that they list the manufacturer as Onkyo. The part number and description are so similar to what is printed on my spare tweeter box it would be worth 81 euros to see what shows up.
I have designed an adapter plate for either a Scan-Speak Revelator Tweeter D2904/710002 4 ohm, 1" soft dome, 70 mm diameter magnet, $220 or a Vifa D27TG35-06 6 ohms, 72 mm diameter magnet, 91 db, $37.50..Both are available from:
http://www.speakercity.com/ in Burbank, CA
I only modeled the front flange of the tweeter to save time. I have not built any of these yet but the price would probably be $400 for a pair of adapter plates and speaker flange modifications. But when you are done you would have replaceable tweeter for a long time to come. The 2 protective bars are drawer handles available for $3 each.
Other possibilities are:
http://www.audioloudspeakers.co.uk/boultons.shtml voice coil rewinding in the uk
http://www.speaker-repairs.com.au/coils.htm voice coil rewinding in australia
http://www.speakerex.com/diaphragms_new.html in Florida can rebuild the woofer and replace the midrange but no longer have the 4 ohm diaphragm for the tweeter.
If you want the drawings (and 3D geometry file necessary for the machinist to make the curved edges) for the adapter plate and tweeter flange modification contact me at mercedes280se-4@yahoo.com
Feb 11, 2010 | Celestion A3 Speaker
KEF KHT6000ACE TWEETER DIED. HOW CAN I GET A NEW SPEAKER?
if the original KEF tweeter is no longer available there are other brand tweeters that should fit as a replacement option. just contact a repair center (us) and you can get options.
cathy@speakerex.com
Jun 13, 2009 | KEF Audio KHT6000 Speaker
Not available in INDIA
That exact model has a region code and a voltage rating specification that is not compatible in India, therefore that model will not ever be available in India.
Speak with a Philips representative
1860-180-1111 Monday to Saturday 09.00 - 21.00 "Standard call rates apply" Sunday 09.00 - 18.00 011-6600-1111 www.philips.co.in/support
Feb 13, 2009 | Philips Magnavox DVD/VCR Dual Player
27 people viewed this question
 Grubhead
Grubhead
