Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Bottom dishwasher of fisher and paykel wont drain
  • Fisher and P... Master
  • 3,247 Answers
Check the filter sump is clear and there are no blockages in the rotor cavity. If you hear the rotor noise when it is in drain cycle then blockage is inside the rotor or filter sump cavity. Assuming the top drawer is working ok, the drain hose at kitchen end might be ok. The drain hose within the drawer could also be an issue. Try to run the dishwasher with a Finish dishwasher cleaning kit (from super market) after following the instructions on the kit. First empty dishwasher with a small cup.
If the rotor is silent during drain cycle then you have a bigger problem - faulty rotor circuit.
Posted on Jan 21, 2013
  • 11 Answers
SOURCE: fisher paykel dishwasher not draining
Check the drain hoses by removing the dishdrawers from the machine and pulling on the hoses. I installed a Fisher Paykel DD602 about a month ago and the bottom drawer was not draining. I removed the drawer and freed up the drain hose and the machine worked fine.
Comment posted on Feb 07, 2009 there should be tabs on the sides of the drawers at the sliders near the front of the machine.
Posted on Feb 07, 2009
  • 784 Answers
SOURCE: Fisher Paykel dishwasher drawer won't stop.
Let's go to diagnostic test mode to see if you can retrieve the the actuator hence the tube out.
1- Press Lock button and start/pause key until the display showing up.
2- Press Power to show HO.
3- Press start button to advance the display until you see P2 for draining, if you pass, keep doing it to get it back in a loop.
4- When at P2, press lock to turn on, press a again to turn off.
5- Listen to the sound of the pump. If you hear nothing that means the pump is dead or stuck.
6- The Motor has 2 directions: one for, Rinse and one for Drain. When you done with the diagnostic, press the power button to get out of the mode.
7- If this is the case, unplug the power then remove the rack, the bottom stanless steel plate with holes then take out the rotor to clean up. It is a good design the stator is outside of the tube, so you don't have to worry too much about the complication.
8- Make a note of all the positions so you can put them back the same as they were. Good luck
Posted on Sep 09, 2009
  • 784 Answers
SOURCE: I have a Fisher Paykel dishwasher with water in top drawer
You need a Air gap kit designed by Fisher and Paykel to address this problem. It is pricey but it is worthy. I used this and very happy with it since no back flow problem from one while other running. Here is a link to order it.http://www.fisherpaykelparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/
Posted on Dec 29, 2009
jyackle5
  • 8197 Answers
SOURCE: Fisher and Paykel dishwasher DD603 manual
You can get the manual below for free..
http://www.fisherpaykel.com/admin/pdfs/pdf_usecares/527971B_DD_user_guide_USw.pdf
Good Luck and please rate 4 thumbs for the free answer
Posted on May 15, 2010
  • 251 Answers
SOURCE: How to reset the flood switch on a fisher & paykel
Hi - unfortunately my good friend it cannot be reset as one would like quite easily anyhow... water has found its way to the base of the drwaers and have activated the flooding switch - one could pull it apart to dry it - tip the water out from the base but if the leaks not repaired you will have the same problem later and will be on-going.
5 Fault Codes
Fault Code LED Display Fault Possible Causes
F1 ----#
The flood switch has been activated.
A leak has occurred in the base of the dishwasher.
Cause
 The fill valve has failed open.
 The flood switch is faulty.
 Excessive water has been added to a wash sub cycle, indicating leaking seal or siphoning.
hope this is useful tp you - let me know if you require further asspstance...
Posted on Jul 17, 2011
How do I get the bottom drawer of the fisher paykel dishwasher to drain
Not Draining - Most common Fault is the rota motor.
look on u-tube for easy removal.
clean and retry, might work now but be noisey.
Best place I have found for replacement part is Paykel £50.00 ish
Oct 30, 2014 | Fisher and Paykel Dishwashers
Why wont it drain?
most likely the rota motor is stuck.
check u-tube for easy removal, clean tips
on checking for best deal for replacement part, I found Fisher & Paykel the best price, £50.00 ish
Jun 29, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & Paykel dishwasher top drawer is filling up with water when bottom drawer is ran.
It is the drain water from bottom drawer that is finding its way to the top drawer. This could be due to incorrect drain hose height. Check in installation manual. Alternatively you will have to buy an air gap kit and connect the two drain hoses separately to the kitchen sink.
http://www.genuineapplianceparts.net/ecart/item.php?item_id=250&category_id=58
Mar 22, 2014 | Fisher and Paykel Dishwashers
Fisher paykel cross draining
As the drawers share a common outlet to the kitchen sink drain, it is the drain water from bottom drawer going to top drawer. Can happen if the drain hoses are not following the correct specifications for installation. An air gap kit is available to solve the problems.
Refer
http://www.genuineapplianceparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/?preadd=action&key=WT50
Fisher and paykel nautilus dishwasher
Does it fill with water? I would guess a fill/ drain/ heating problem. See if you can eliminate any of those.
Apr 12, 2013 | Fisher and Paykel Dishwashers
Drawer wont drain and motor noisey
Remove the bottom strainers and make sure that there is nothing obstructing the outlet pipe and the pump. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Feb 19, 2011 | Fisher and Paykel DD605SS Stainless Steel...
My fisher paykel DD S03SS dishwasher leaks from the top, & drain
The drawers should not leak unless there is a problem with the vacuum seal. Try cleaning the edges of the doors and operate. You should feel the vacuum is holding the doors. The seals could be faulty or vacuum system may be faulty.
About not draining completely - a possibility is the common drain hose after the U adapter being clogged. Remove the clamp and pass a flexible wire coat hanger towards the main drain pipe. If both drawers are not draining then it is unlikely the drain hose between the U clamp and the dishwasher is clogged. Also make sure the height of inlet water pipe and drain outlet is as specified in the installation manual
Nov 09, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher&Paykel DW60 drain pump is blocked.
Feb 07, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher paykel dishwasher not draining well
Feb 01, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & Paykel Dishwasher leaked
From what you describe, drain water from the top drawer is getting into the bottom drawer or waste water from the disposer is backing up into the bottom drawer.
1. Each drawer has its own drain hose. Each hose should terminate at the drain point with a 'Y' adapter.
2. Inspect the drain point (under the sink where the drain pipes are) to make sure this 'Y' adapter is present. (you should see two drain hoses from the DW). If not present, then the DW drain lines are not installed properly. (Someone took a shortcut and installed the 'Y' adapter behind the DW)
3. If terminated properly, make sure the drain hoses extend upward as they leave the drain point.
It is important the drain lines are connected properly to ensure proper drainage from the DW. Consult the installation manual for complete details.
Jun 08, 2008 | Fisher DD603B / DD603W / DD603H Dishwasher
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
75 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
