I have an Elecrolux 7kg Eco Wash EWF1074 washing mashine. It is only 3 years old. The washer starts normaly, control panel shows time of the cycle, but in about 2 mins water stops, drum does about 5 q
    Master:
  • Washing Mach... Master
  • 480 Answers
I suggest you first to check if there is any errors memorised in your washing machine, then we will know what is, a malfunction or improper use of the machine.
So, how to make a rapid reading of alarm codes, see below:
First, appliance must be in normal operating mode (e.g. during the execution of the washing programme, I suggest reading the alarm exactly in 2 minutes when the washing machine working).
Press START/PAUSE and SKIP/RESET buttons simultaneously for at least 2 seconds:
the LEDs switch off and then display the sequence of flashes indicating the alarm.
The alarm sequence is displayed for the time in which the buttons are hold down.
Let me know exactly error code (Could be: first digit always "E", than following two numbers) if you read the alarm on display.
Dado
Posted on Jul 19, 2015
    Scholar:
  • 197 Answers
More than likely is the Timing Board.It controls all the functions that are predetermined to make your washer do it's job.
Posted on Jan 18, 2013
SOURCE: Washer not completing cycle
I HAD THE SAME PROBLEM ON A 4 MONTH OLD MACHINE AND I CALLED A SERVICE PERSON. HE SAID THAT I CAN THROW IT AWAY. THIS IS A PROBLEM THAT NOBODY CAN FIX.
Posted on Feb 15, 2007
dididsaythat
  • 291 Answers
SOURCE: Washer knocks half way thru wash cycle and never gets going in spin cycle
What kind of washer and do u have a model #
Posted on Aug 28, 2007
SOURCE: Kenmore Oasis washer HE
How about the LD error message, I am Tried of having to bow out the drain hose
Posted on May 31, 2008
SOURCE: washing machine displaying E90 error
an E90 fault is a problem relating to the main control module found behind the front facia. it could just be a bad connection on the board connections though
Posted on Dec 13, 2008
  • 86 Answers
SOURCE: Control panel reads E61 at wash cycle and E66 and drain and spin
Can you tell me what make this machine is? As it sounds like a heater problem??
Posted on Dec 28, 2008
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
Repair manual for 7kg eco wash system ewf1074?
Replacing the bearings is a comprehensive job and requires expertise and a lot of time.
First of all should estimate which parts should be replaced.
These are certainly the following parts: "Ball bearing - 25x52x15",
"Ball bearing - 30x62x16", Seal of drum shaft - 35-62 and besides them should be reviewed the state of drum shaft.
After a thorough review, you should estimate whether the repair cost or cheaper to buy a new washing machine.
First of all, I recommend that you look the tutorials on the following links:
How to Replace Washing Machine Bearings
http://www.how-to-repair.com/help/how-to-change-bearings-on-a-washing-machine-2-of-4
Dado
May 03, 2015 | Electrolux Washing Machines
Electrolux EWF1074 7kg washer stuck on drain cycle
The first thing I would check is the drain line, not for a blockage but to see if the drain line isn't pushed down in the drain so far that its below the level of the pump. If it is you'll have a siphon effect going and the machine will never advance past rinse
Apr 26, 2012 | Electrolux Washing Machines
My new omega washing mashine shows an E2 error code 5 miniutes into the wash how do I fix this?
Manufactured by omega washing mashine have an electronic controlpanel that must be unlocked in order to set or make changes to your washingcycle.
E2 indicates a water leak. When a leak occurs, it trips thefloat device by dumping water into the dishwasher's base. The incoming watervalve will be switched off, and the drain pump will turn on until the sump isempty
However, if an error light is blinking on your dishwasher'scontrol panel, the panel must be reset before you can gain access. Blinkinglights on your washer control panel may signal a mechanical problem that needsto be repaired. If the lights continue to blink after you've reset the controlpanel, contact Sears to service omega washing mashine or considertroubleshooting the appliance yourself carefully.Instructions
1 Press and hold the "Heated Dry" button onyour omega washing mashine for four seconds to unlock the dishwasher controlpanel.
2 Press the "Heated Dry," "Normal Wash,""Heated Dry" and "Normal Wash" buttons one after theother, in fairly quick succession.
3 Wait for the washer to run a short diagnostic test.
4 Press the "Cancel/Drain" button at the endof the diagnostic test cycle. This should reset the control panel on your omegawashing mashine. Thankfor using fixya.
Jul 30, 2011 | Washing Machines
Not spinning when on Regular wash mode.
sounds like the agitator is damaged and needs to be replaced
Jun 21, 2009 | Washing Machines
Duet washer stopped during wash cycle.
take off the panel below the door three screws and look for the tech sheet located on the right side. It will coach yoou thru the codes and common problems. Sounds like it may be the door swithch does it lock when you push the start? If not the door switch my guess would be a machine control. 877-262-1479 parts.
May 30, 2009 | Maytag EPIC MFW9700S Front Load Washer
Washing machine displaying E90 error
Dec 12, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Kleenmaid KAW 693W-3050 7KG Washer
open the control panel use pliers on the back of the timer shaft then try to remove the knob
Aug 15, 2008 | Washing Machines
Washing Machines Logo
162 people viewed this question
Top Washing Machines Experts
