Question about Harmon Kardon Used Harman Kardon Avr 225 Av Receiver
Harmon Kardon 225 left chanel hum
Left channel hum in analog
Whats wrong with my stereo
How old is your HK receiver? The power supply capacitors can get old and tired, and cause the hum and shutoff. Repair is an option.
May 03, 2015 | Harmon Kardon Harman Kardon AVR1600 50W/CH...
Trying to connect samsung smart tv to harmon kardon avr 330 with toslink cable, but i'm not gettting any sound through the receiver to speakers
The inputs may be assignable on the Harman Kardon. Make sure you have selected the proper analog or digital input type for the cable you are using. For more information, or should you have further questions, please visit my website at audioserviceclinic.com. You may contact me directly through the website. Thank you.
Dec 14, 2013 | Harmon Kardon Harman Kardon Avr 330 5.1...
Harmon/Kardon AVR 146 wont stay on when hit power
Probably was damage buy a power surge, Internal damage to (Reciever)
Nov 03, 2012 | Harmon Kardon Harman Kardon Avr 146 5.1...
Humming noise
Usually Humming noises come from frequency interferance.  In this case it is being caused by your input sources.  A smiply solution is to replace the cables and or seperate the source cables away from any electircal cords or sources.
Jan 07, 2009 | Harman Kardon AVR 225 Receiver
Harmon Kardon and Infinity Modulus
I got the answer for No-1.
The balance was turned on the Right Channel. That is why Left Channel was not working during the Channel test.
For Channel test the Balance should be in the middle so that both Right and Left Would be heard.
I am working on my Subwoofer Isuue.
I opened the Back Panel and Yet I could ot figure out any issues.
I will open the front panel and see if any connection is loose.
Dec 29, 2008 | Televison & Video
Was using the harmon kardon avr 225 receiver and the front panel went out. .... screen display of the channel number, volume, or menu item does not work. ...
Try hooking up a yellow video wire from the back of the AVR 225 Monitor out. Should be at the end of the 7 or 8 yellow video ports on the back of the stereo. Next plug the other end into a yellow video in on a t.v. Get your remote, (Harmon/Kardon) and make sure the t.v. is on the correct video input and hit the OSD(on screen display) button on your harmon remote. There should be a setting in there that says VFD under ADVANCED menu option that allows for turning the front of your stereo lights on and off and dimming them half way also. OFF/HALF/FULL are the 3 options I believe.
If this doesnt solve it your display may have crapped out on you.
Jan 22, 2008 | Harman Kardon AVR 225 Receiver
HK AVR 225 front display not working
thats not good power transformers in it went bad do u have it on a nice power strip or direct to wall
Jan 19, 2008 | Harman Kardon AVR 225 Receiver
Harmon Kardon avr 225
i'm the last person that posted wanted to add that we heard a pop in the speakers when the system went out. We'll be taking the box apart soon to see if we can diagnose it...(fuse?)
Jan 01, 2008 | Audio Players & Recorders
Harmon Kardon Used Harman Kardon Avr 225 Av Receiver Logo
29 people viewed this question
Top Harmon Kardon Audio Players & Recorders Experts
Lawrence Oravetz
 Grubhead
Grubhead
Ngoro
Ngoro
Are you a Harmon Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
