Need Carrier Part Number Cross Reference
Hot Surface Igniter is bad on a 3 year old Carrier 58STA Furnace. It is getting cold. I cannot find the exact part number, or a cross reference number. Most online sources do not do model drill-down to part. Those that do use their own numbering system and the one vender I Iooked at wanted $163.00 for what should be about a $30.00 part. I am assuming it is part number LH33ZS004 from the general searches which state this is the most popular part number and fits most all Carriers made in the last 10 years.
  • jeffery_carl Jan 28, 2009
    Thanks for the help. I tried the web site you mentioned above and ran into the same problem. Their diagrams and illustrations did not have anything close to my part. I did, however, get the problem resolved. I learned of and went to store called Fix-it in the greater Dallas area. As I was suspecting in my original post, the part number was LH33ZS004 and could also be about 10 other part numbers. They did an exact match-up--cost $42.00. I picked it up yesterday and installed it--just in time as it hit a low of 25 degrees last night and crippled most of Dallas traffic.
  • 306 Answers
Try these guys I live where they are and they have everything and they ship anywhere also. And you are right the part is only about 30 bucks I know a guy that bought one off of ebay also.
Posted on Jan 25, 2009
Carrier 58STA/STX furnace false starts even when off or temperature set lower than current.
Is it possible the drain is plugged? The newer furnaces have a moisture drain and will shut down if they are blocked., shutting them down and restarting will reset fault, but will come right back if not fixed.
Dec 24, 2014 | Carrier Heating & Cooling
Ignition failure.
if furnace fires up then immediatly shuts off check the flame sensor. make sure it is sitting far enough inside the burner box and has proper continuity. if ur getting ignition failure without having furnace fire up, check proper voltage to hot surface igniter, continuity within igniter
Dec 05, 2013 | Heating & Cooling
Tempstar pilot turns off
Based on your model number this furnace does not have a pilot light,instead it uses a hot surface igniter.typically it glows and when it gets hot enough the gas valve will open and the burners will light.When the igniter starts to go bad it will glow but not get hot enough to open the gas valve.If your furnace lights and the quickly goes out the flame sensor maybe dirty.
Oct 07, 2012 | Goodman GMS90703BXA Heater
Carrier 58STA furnace code 33, no ignition blower stays on. I have a Carrier 58STA furnace. It's getting a code 33 and never trying to ignite. The blower constantly stays on. It is pushing good air...
33 is a limit switch open take your furnace doors off and there should be a wiring diagram. on this furnace the blower will run if this is open. check rool out swict and linits. it sounds like you have a problem with over heating. how does the fire look ? is the vent blocked ? things like that i think page 9 has falt codes
Feb 11, 2011 | Heating & Cooling
My carrier 58sta furncace is blowing cold air constantly
Code 33 is "limit is open or flame switch is open"
FIRST make sure the filter is clean. Turn off unit then turn back on.
if it works but then later gives you a 33 code then you might have a dirty a/c coil (if you have a/c) that will cause the limit to open. 1st try that
Mar 21, 2010 | Carrier Heating & Cooling
Gas valve lockout
It means that the furnace isn't igniting and for safety the control board is preventing the gas valve from opening. Turn off the power to the furnace for a few seconds then observe what the furnace does in heat mode. Some furnaces will run the blower for a minute after you power it back up. After that see if the furnace tries to come on. If you are still getting the code then one of you high temp limit or roll out switches has tripped. Now is the time for a service tech. Make sure that you check you filter and air flow too. Low air flow means the furnace may be over heating.
The other thing is the hot surface igniter. Look closely at it with the power off. Do you see a white spot on the element or a crack. If so the HSI is bad. It's an easy replacement but DO NOT touch the carbon element with your fingers and be very careful handling it as it is EXTREMELY fragile.
Mar 17, 2009 | Carrier 38BRC048 Air Conditioner
Using alot of hot surface ignitors
don't touch the surface of the igniter when handling it, and don't bind the mounting bracket when you tighten the capscrews, the bracket and igniter should be firm and no loose/movement if you try to move the bracket. also make sure the igniter is going back off after the burners light
Feb 28, 2009 | Tools & Hardware - Others
Carrier Furnace Model 58STA/STX not firing
Have you checked the gas valve on the unit.. is it set to on? also check the gas valve going to the unit on?
Jan 21, 2009 | Heating & Cooling
Furnace will turn on, but will  not ignite.  I have a Honeywell S86F module that I think is bad.
Is your furnace a hot surface or spark ignition. If you have a hot surface igniter you can check it with a multimeter or pull it out and check to see if igniter has a break in it . Check igniter first even if you have a spark igniter. Some brands of furnaces you have to turn off the thermostat to reset. If you need anymore help send me the make and model# of your furnace
Nov 28, 2008 | Heating & Cooling
Carrier Weathermaker gas 8000 will not ignite
Your hot surface igniter may be bad. It may be cracked which would prevent it from starting the burner flame.
May 21, 2008 | Heating & Cooling
Heating & Cooling Logo
2,800 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
