Question about Digital Check CheXpress CX30 Check Scanner [N-CX30]
Checks always jam in track in the digital check cx30
My 2006 Saturn inon massager window will not roll up,,I am hearing motor,,and have checked fuse
if you hear motor either jammed track broken track window sticking in jam bad motor gear -gear jam remove door panel to check out motor and track
Sep 21, 2015 | Saturn Cars & Trucks
Small personal check has caused jam. How do I get it out without seeing it?
most devices have some type of way to pull something through the "feed path" obviously you've looked and maybe you got "some" of it out. repairing printers and copiers for 30years there is always a way it usually requires steps that the client is prepared to do or wants it to be someone else to break it if its going to break. Part of the service techs experience is knowing what screws to pull out which ones to leave alone. a red or blue nail polish looking substance across a screw usually means ..."you crack this screw and change the position of whats underneath be very sure you can get it back..." so when one is removing screws and brackets and good memory is handy ( I knew a tech that took pictures as he went...pretty unprofessional in someones office but ya do what ya gotta do...) at any rate if you feel uncomfortable join the crowd...if you feel terrified don't commence repairs! no really if you were in front of me I'd be reading your body language to see if you were the "take it apart and be the office hero type or not. if you are then go slow and work your way to the rubber feed rollers there's usually a spring or two keeping them together. slightly overcome the roller tension and work your newly found jam outward. Some have a wheel for simple jams, use it also. usually sensors before and after the scanning lens. if a tuft as we call it has torn off and remains blocking the sensor it will be bi hove of you to test it before you put it COMPLETELY together. Hopefully the power cord was removed before trying any of this. take some canned air while you have it apart and a damp NOT dripping water rag to the rubber rollers that got you in this mess. Air first damp rag second. hope this helps a smidge~~~~~SC
Oct 16, 2014 | Digital Check CheXpress CX30 Check Scanner...
Passenger seat in 1999 Pontiac sunfire is jammed forward
normally the seat tracks are bolted to the floor or riser. It is possible that when the seat was moved forward the track moved over the head of a mounting bolt and will not return. check for interference between track and rail while trying to return seat.
Jan 06, 2013 | 1999 Pontiac Sunfire
Printer keeps saying i got a jammed paper there is no jammed paper
There are many places in a printer where a small piece of paper can get stuck. It's not always a sheet of paper. Open all the access panels and check the roller track for pieces of paper. If it is clear, unplug the printer for a few seconds and the plug it back in. This should clear the problem if it was in error. Also check the paper feed for too many sheets stuck together jamming the feed. Before loading paper always "fan" the paper first to avoid sheets being stuck together.
Apr 14, 2011 | Canon Office Equipment & Supplies
Sliding shade is stuck and won't slide. Glass is down in 1 corner, not flush with roof
the shade may be related to sunroof not closeing completely, the most common reason is the track is broken , this is the most common reason for when the sun roof doesnt close or jams when opening or closing its always the track breaks, the way to check this is to easy the headliner needs to be dropped and removed and then the glass from sunroof removed then unbolt track and drop down into car and check the track linkage and arms and track and see whats broken, note there are no replacement parts only motor or cable, as far as the parts that always break like an arm on the track this is not replaceable the track needs to be replaced, hope this helps , good luck.
Feb 06, 2011 | 2005 Chrysler 300
I keep getting the message "Out of Paper" or alternatively, "Carriage Jam" The printer is not out of paper - I have removed, straightened, added paper and it's the type I have always used. There is...
It will be good to have the printer mechanism jammed or the paper tracks jammed with paper struck in the roller.
Remove all connections when the mechanism is taken out cleaned and drives checked manually with the motor removed and the drive turned to see that the movements are smooth.
make sure the input sensors are intact , the paper detection sensors.
Sep 24, 2010 | HP PSC 1610 All-In-One InkJet Printer
1994 cavalier z24, right window stuck down, going to rain tomorrow. has been acting up, but could always get it up before now.
check the wires on the driver side door maybe one wire is broken in the harnes inbetween the door where the door hinges are if not the window motor needs replacing
Dec 02, 2009 | 1994 Chevrolet Cavalier
When printing, the sheet of paper always gets jammed.
check the wheels that pull the paper through. sounds like only 1 is grabbing. see if it fell off track
Jul 11, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Front passenger seat jammed
I would guess that something might be jammed in the tracks or it is an electrical issue. Sometimes the connections to the switches are bad, sometimes the switch itself is bad, and sometimes the moter is burned out. Listen to hear if the motor is running, if so, check the track and see if it is jammed. If you don't hear anything you have some electrical tracking to do.
May 15, 2008 | 2005 Lexus LS
Digital Check CheXpress CX30 Check Scanner [N-CX30] Logo
313 people viewed this question
Top Digital Check Office Equipment & Supplies Experts
k24674
Are you a Digital Check Office Equipment and Supply Expert? Answer questions, earn points and help others
