Question about Teac AG-V1050 Receiver
TURNTABLE PROBLEM I HAVE AN AUDIO-TECHNICA TURNTABLE AT-PL120 WITH A BUILT IN PRE-AMP. MY TEAC AG-V 1050 HAS THE PHONO INPUT. FOLLOWING THE INSTRUCTIONS I CAN ONLY GET MINIMAL VOLUME FROM THE RECEIVER. TURNTABLE HAS A PHONO OUT OR LINE OUT SWITCH WHICH I USED THE PHONO OUT. RUNNING THE TURNTABLE WITH THE LINE OUT THROUGH AN AUX I GET THE SAME RESULTS. VOLUME IS ON A QUARTER OF WHAT IT SHOULD BE WITH VOLUME CONTROL TURNED ALL THE WAY UP. I'M STUMPED.
  • 1 more comment
  • Timothy Matthews Jul 13, 2007
    OK, tried all of that and still the results are the same. I can plug it into every input I have and pretty much get the same result. The difference between the cartridges make sense as I do see a smaller signal coming out. The troubleshooter from Audio-Technica wanted me to switch the MM (moveable magnet) on of which I don't have (I think-don't see any thing like that). So now I'm thinking, my receiver is not compatible for a magnetic cartridge Would switching to a ceramic cartridge make a difference? Any help would be appreciated
  • Timothy Matthews Jul 18, 2007
    I think I figured out the problem. I had narrowed it down to either the pre-amp or the needle/cartridge and after taking the cartirdge unit off and inspecting it with a magnifyinh glass I found the needle to be broken, actually bent causing the needle not to track correctly, thereby reducing the output. I straightened out the needle the best I could and noticed a definite improvment immediatley. My next step is to replace this needle with a replacement. Any suggestions of a decent cartridge or should I stick with the same needle/cartridge which is a ATP-2.
    Thanks to all that helped on this problem. This was an eye-opening experience for me. Never thought a needle would make the difference.
  • 20 Answers
You have a VERY nice turntable! TWO quick questions: 1) How do you define "minimal" volume? It is not NECESSARILY unusual that your turntable / receiver combination will have lower volume than your tuner, CD or DVD player. What happens when you CRANK IT UP?! Don't worry about the position of the volume control! 2)Are you changing the turntables output settings via the switch under the platter? Please post a reply and we'll go to the next step! Note: Ceramic cartridges are pretty much extinct. They were strictly low-end, low-cost, low-fidelity devices used in cheap audio systems of "yesteryear". Have you ever seen a BSR or Garrard turntable? Or your grandad's Magnavox Console Stereo? THAT'S where you'd find a ceramic cartridge!
Posted on Jul 18, 2007
  • Mark Michener Jul 18, 2007
    CONGRATULATIONS! That's good news!
    As for a replacement, the simplest (and most cost-effective) thing to do is replace the stylus - assuming one is readily-available. Some are not.
    IF you must replace the entire cartridge, there are many good ones out there. In order to get something of quality that is on par with your turntable, you're going to spend between $70 and $100. My personal recommendation is a SHURE M97 series. The latest rendition is the M97xe, a $140 list that you can buy from Amazon.com for $70 bucks. It is PERFECT for your tonearm, which is not a "low mass" design - NOT a criticism, by the way.
    Do NOT buy a "DJ"-type cartridge, which are designed to enhance bass and/or treble for a "BIG" - but not natural - sound.
    Congrats again!
  • Sue Kay Aug 09, 2018
    Ceramic cartridges aren't extinct. You can buy them still. You mean out of favor with some people.
    Novelist:
    Champion:
  • 219 Answers
Use the line out jacks and then you should be able to go into an aux. in jack on your Teac or a tape in or something like that. If you have a phono input and it is a new amp and new turntable then it is most likely a "magnetic" phono. If either unit is an older style then it is most likely a "ceramic" phono they expect. The magnetic signal is much, much, much smaller of a signal coming from the cartridge then the ceramic signal type. If your turntable has a preamp then switch it to line out setting and then you can use any general input jack (AUX. or TAPE or CD) to input your turntable and not have to figure out which type of phono cartridge you have. I'd hazzard to guess that you have a magnetic cartridge if I had to guess. Good luck.
Posted on Jul 13, 2007
Do you need a pre-amp to connect this turntable to a receiver that has no Phono input jack?
Yes, a TurnTable can be connected to any of the Analog Audio Input ports on the Sony STRDH130 Receiver. However, the turntable signal will need amplification from an external pre-amplifier (or an inline amplifier) as this Receiver does not have a PHONO input.
Feb 16, 2018 | Sony Audio Players & Recorders
Using turntable (audio technica at-lp 120) with built in pre amp the sound is distorted and broken up. the turntable requests phono turned on to use. Does the receiver have a pre amp or boost signal...
A turn table produces sound voltage in the millivolt range. If you have it connected to a receiver that has a phono input and the turn table is pre-amplified, you are overdriving the receiver and it is clipping the audio and making it sound bad.
Jan 17, 2015 | Yamaha RX-V592 5.1 Channels Receiver
Can I hook a turntable to a Teac AG-D8900. Where do I input?
only if the unit has a PHONO input never plug a turntable into any other jack as teh voltage is different.
I have seen an adapter so that you can plug a turntable into an ordinary input I believe Radio Shack but that was along time ago try ebay
Jan 08, 2010 | Teac AG-D8900 Receiver
I have a new Yamaha RX-V365 receiver and an older technics turntable, regardless of input setup I cannot get any volume from the turntable, yet all other inputs like CD, Tuner are fine....amp issues in...
Some turn tables do not have a built in amp, especially the older ones, the sound goes from the needle to the output. If the amp your are using does not have a designated phono, turn table, input it may not have the turn table pre-amp built in. Some turn tables have to be grounded to the amp to work properly.
Aug 30, 2009 | Teac DC-D2800 Shelf System
Distorted sounds
The AT-PL120 uses a magnetic cartridge to extract a music signal from the record. Magnetic cartridges all put out a very weak electric signal, and so their output must be strengthened, or amplified, to where it is as strong as the input from, say, a CD player. This amplification is provided by a pre-amp. If your receiver has dedicated "phono" inputs the pre-amp circuits are already in the receiver. If you do not have dedicated phono inputs you must either buy a pre-amp, or buy a magnetic cartridge turntable with a pre-amp built into itself. The AT-PL120 has a built in pre-amp. You can switch the AT-PL120's preamp on or off. The switch is located under the platter at the back side of the turntable. Take the platter mat off and turn one of the platter's holes to the back and you should see the switch through the hole. If you push the switch to LINE OUT the preamp is turned on and the turntable sends an amplified cartridge signal out the cables which MUST be connected to a receiver inout suitable for a CD player (a "high level" input). If you push the pre-amp selector switch to PHONO OUT the turntable sends the weak unstrengthened cartridge signal out the cables which MUST be connected to the receiver's dedicated PHONO inputs so the signal can be amplified with the receiver's own pre-amp circuits.
If everything is set wrong (i.e. LINE OUT (pre-amp on), and connected to phono inputs) you are applying two steps of strengthening to the turntable's signal which is too much. The resultant sound will be garbled. Try not to do this!
The other way to do everything wrong is set the pre-amp switch to PHONO OUT (pre-amp off) and connect the turntable's cables to a high level input. If this happens the turntable signal receives no amplification and the resultant sound will be thin and weak.
May 09, 2009 | Audio Technica AT-PL120 Turntable
New receiver, now no sound from turntable
hi, i think theres is no problem in your situation, first
1ST TURNTABLE---->2ND PHONO PRE AMP-----
>3RD YAMAHA HTR RECEIVER (AUDIO L&R) PLEASE DOUBLE CHECK. U
Dec 17, 2008 | Teac AG-V1050 Receiver
No sound from my record turntable into my computer.
If you're certain there is no sound going out of the TT...
Setting the Pre-amp Switch
For increased flexibility of use, this turntable has an internal
stereo phono pre-amplifier. The Pre-amp Selector Switch
is located under the turntable platter, in the rear-center
(Fig. 1). If the system amplifier you are using has a PHONO
input, set the Pre-amp Selector Switch to the “OFF”
position. If your amplifier does not have a PHONO input,
set the Pre-amp Selector Switch to the “ON” position and
connect the turntable’s output cables to the AUX or other
high-level input on the amplifier (described later).
Turntable operates, but no sound at all
1. The stylus guard is still in place.
2. The tone arm Lift button is pressed in.
3. Amplifier controls set incorrectly: wrong input selected,
tape monitor on, speakers switched off, etc.
4. Check the stylus on phono cartridge for correct placement.
Refer to the instructions for replacing the stylus
on page 5.
Turntable operates, but no sound, or sound not loud
enough
1. If the turntable is connected to an AUX (high-level)
input: The Pre-amp Selector Switch may be set to the
“OFF” position (phono-input level).
2. The input gain of the amplified speaker or similar
device may be too low.
3. The stylus assembly may not be fully seated in the
cartridge body.
You could also isolate the problem to either the TT or the PC by trying the TT on some other sound device like a receiver. Make sure the PreAmp Selector switch is ON and plug the TT into any AUX, CD or TAPE input.
Sep 02, 2008 | Nakamichi AV-7 Receiver
Not a good sound
you can't...the technics need to be pluged into phono..because the signal has to be amplified for it to play...phono channels on amps and dj mixers have an amp built in....
Apr 06, 2008 | Technics SL-1200MK2 Turntable
Background huming
How does it sound when you just play straight vinyl through your system? If you still get that hum, issue might also be faulty RCA cables, and even cartridge. So you would need to test everything out.
You don't really need a pre-amp unless you are connecting straight into your pc from your turntable. In that case, yes you will need a pre-amp, and this actually might be the cause of everything. If you are going into a DJ Mixer or a receiver, and your turntable is connected to the PHONO INPUT connection, you do not need a phono pre-amp.
Here are some inexpensive PHONO PRE-AMPS.
Hope this helps some.
- TWEAK AV LAB
Nov 25, 2007 | Audio Technica AT-PL50 Turntable
Very low audio output
Make sure your receiver has a PHONO input. If you are connecting it to a LINE or AUX input, then there is not enough signal to boost the sound coming from the turntable. Turntables require a PHONO input, because phono input's have a pre-amp on them, which boost the turntable signal. If you do not have a PHONO input on your receiver, you will need to buy a Phono Pre-Amp.
If you have a phono input, then you might have an issue with the turntable's RCA cables, or your cartridge may be at fault.
- TWEAK AV LAV
Nov 22, 2007 | Audio Technica AT-PL120 Turntable
703 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
