Question about Samsung DV218AEW Electric Dryer
Heat is gone - Samsung DV218AEW Electric Dryer
    Scholar:
  • 197 Answers
Check the Circuit Breaker. It is a double Breaker Switch. one side is for the heat one for the motor. If that is good then it's possibly the Heating Element or one of the two heat sensors.
Posted on Jan 18, 2013
Kenmore model #110.64952300
heating element gone or temperature sensor gone
Dec 12, 2013 | Dryers
I have a Bosch Nexxt 500 series dryer. It runs but has no heat. I have cleaned the exhaust system thoroughly and cleaned the heat sensor. Now I think the problem may be in the heating element? Is this a...
probably not the heating element but one of the toc's has gone(temperature overload cut out)if you are handy with a multimeter test it and if it shows the symbol 'ol' youll know which one is gone
Aug 18, 2013 | Bosch Dryers
My fans wont come on when car heats up
Heat sensor has gone bad or fan has gone bad. Turn on defrost and fan should come on and if so have heat sensor that control fan replaced....hope this info helps and if so please leave rating on this post and good luck.
Aug 15, 2012 | 1999 Pontiac Grand Am GT
My amplifier is geetting very hot and shutting off
Hi gordog239,
This symptoms indicated that your sound output IC was already shorted. It heats up while on operation but the heat depends upon the volume and the load speakers(normal operation). If the unit gone to excessive heat even the volume is set to min, this was a clear indication that the fault came from the output IC (mounted in the heat sink. You may confirm it by opening the cover of the unit and touch the heat sink.
Once confirmed that the heat sink gone to excessive heat, replace the output IC and all electrolytic capacitor around this section, this will solve the issue.
Let me know if you need further assistance.
Hope I helped you.
Have a nice day!
Thanks for using Fixya
May 23, 2011 | Car Audio & Video
My Kenmore 66512690 dryer will not heat up or dry cloths. The drom rotates and the motor seems fine.
check your fuses in your panel. If one is gone the dryer won,t run if the other is gone it just won't heat
Oct 27, 2010 | Dryers
Front panel has gone yellow with the heat
it will not clean you will need a new front panel
Jun 30, 2010 | Heating & Cooling
Drum turns but has no heat
seems to me the heating elemint may be gone. You may have one or two in your unit but if your getting NO heat both may be gone.
Nov 28, 2009 | Dryers
ASUS K8V-MX motherboards IC's are gone by heat
buy a new motherboard. IT shold be cheap enough. You should be able to buy one for 30 bucks or less.
Nov 30, 2008 | ASUS K8V-MX Motherboard
Got a Diplomat ADP8322. Starts Cycle then starts bleeping 3 flashes which is a heating error. No hot water at all. Had a look and cleaned watr pressure switch still not working. Any ideas has the heating...
possibly heating element - only way to find out is to check continuity with a multimeter.
there is also a thermal cutout in series with the heater which could also have gone
Jun 24, 2008 | Dishwashers
No heat
It can be both the heat fuse that gone or your pilot light has gone out, check to see if you see a flame while it is functioning, to do this turn on your dryer and watch in the dark so that you can actually see the flame coming on and off or check behind the little door that houses the pilot light to see if you see a flame if no flame relight, this should start your dryer producing heat again
Jun 22, 2008 | Sharp R-353 Microwave Oven
Samsung DV218AEW Electric Dryer Logo
42 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
