Question about Music
How do I keep the Yamaha MS514U snare strainer from falling off?
I have a Yamaha dtexpress. Very old, but works great. Except the snare sound. It is stuck on bongos. Is there a factory reset for the dtxpress?
1) Press the [UTIL] button.
2) Press the [PAGE DOWN] button until the 'Factory Set' screen appears. The message 'Factory Set' will begin flashing on the LCD.
3) Press the [SAVE/ENT] button. The LCD will display the message prompt, 'All data will be lost, Are You Sure?'.
4) Press the [SAVE/ENT] button again to complete the Factory Reset procedure.
Dec 31, 2017 | Yamaha Music
Snare stops working after 3 or 4 min. to fix I have to switch sets over and over again.
sounds like you have a wire connection problem check your switches make sure they are connected properly.
Nov 05, 2013 | Yamaha Dtxpress Iv Special Electronic Drum...
Yamaha Snare Throw
Please give model number and what problem you are having
Feb 07, 2013 | Music
Dt express snare sound changes
Check your snare and the red knob next to it, if you turn this knob it will turn off the snare, it could even have a short or etc.
Sep 17, 2012 | Yamaha Dtxpress Iv Special Electronic Drum...
Two of the pads on my Yamaha DD55c drum machine do not seem to be triggering properly. For example, if I hit the snare pad it seems to always be triggering at a low velocity, but if I strike it flat with...
A weak snare is a characteristic of these... The triggers are typically piezo discs that were often used in musical cards but those have now gone to using very flat little speakers... You may find some have been dislodged or broken loose... worth a look inside.
Apr 11, 2011 | Yamaha DD55 7 Pad General MIDI Digital...
Every time i hit it anywhere on the front the snares shake, whats wrong?
Absolutely NOTHING is wrong. The snare drum resonates. The only solution is to NOT let th snare drum "hear" the Cajon... This is a common problem... Other instruments can also trigger the snares... SOME people add clearance of the snares to the drum to avoid some of the problem.
Jan 10, 2011 | Toca Cajon Bordeaux
The snare connectors on my premier snare drum are loose. how tight should they be?
It should be adjusted just tight enough so the snare doesn't rattle when it is not on.
Feb 07, 2010 | NRS GMS G28 Acrylic Snare Drum, 6.5X14...
Yamaha dtxpress iv standard
try a wooden snare, a light kick drum, the most natural hi hat you can find, some soft cymbals and a selection of wooden and metal percussion instruments.
Dec 25, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
Music Logo
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
