Question about Olympus VN-3100PC Digital Voice Recorder
Had chk error, now screen shows gibberish
Had chk error. Before I could fix it, the screen now shows gibberish, random lcd characters, chick a block all over the screen. I can't reset. Tried new batteries. Na da. Just a screen loaded with various display icons and labels, all at once.
Please help!
Need instructions
Posted on Jan 27, 2009
Display screen flashes "CHK" repeatedly
Hello.
From FixYa Support: The "ERR" message reportedly means a memory error.
Please NOTE: This solution will wipe out the memory.
Press the STOP and DISP/MENU buttons at the same time for about 2 seconds, and then the display should show "FOR". It will supposedly erase the whole memory, but will at least make the device usable again.
Hope this helps.
Apr 03, 2010 | Olympus VN-3100PC Digital Voice Recorder
Tip
Secret Codes For SGH-600/SGH-2100
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} These are the secret Codes for SGH-600 / SGH 2100
  • *#06# -> Show IMEI
  • *#9999# -> Show Software Version
  • *#0837# -> Show Software Version (instructions)
  • *#0001# -> Show Serial Parameters
  • *#9125# -> Activates the smiley when charging.
  • *#9998*228# -> Battery status (capacity, voltage, temperature)
  • *#9998*246# -> Program status
  • *#9998*289# -> Change Alarm Buzzer Frequency
  • *#9998*324# -> Debug screens
  • *#9998*364# -> Watchdog
  • *#9998*377# -> EEPROM Error Stack - Use side keys to select values. Cancel and ok.
  • *#9998*427# -> Trace Watchdog
  • *#9998*523# -> Change LCD contrast - Only with version G60RL01W
  • *#9998*544# -> Jig detect
  • *#9998*636# -> Memory status
  • *#9998*746# -> SIM File Size
  • *#9998*778# -> SIM Service Table
  • *#9998*785# -> RTK (Run Time Kernel) errors - if ok then phn is reset, info is put in memory error. *#9998*786# -> Run, Last UP, Last DOWN
  • *#9998*837# -> Software Version
  • *#9998*842# -> Test ******** - Flash the screenligth during 10 seconds and vibration activated.
  • *#9998*862# -> Vocoder Reg - Normal, Earphone or carkit can be selected
  • *#9998*872# -> Diag
  • *#9998*947# -> Reset On Fatal Error
  • *#9998*999# -> Last/Chk
  • *#9998*9266# -> Yann debug screen (=Debug Screens?)
  • *#9998*9999# -> Software version
Enjoy. :)
on Dec 11, 2009 | Cell Phones
Devant LCD TV: Characters appearing on the screen while watching
I have 2 Devant TV 32CL900 and 32DX850 but I've never experience this kind of problem. What kind of character appears?
Mar 08, 2010 | Televison & Video
"Delimited" gibberish in Excel
You could try to change the whole workbook font to a known good one or do it a sheet at a time by doing a "select all" then setting the font.
It sounds as if though you are trying to import a web page including the HTML code which may well cause the problem you see.
I prefer to do that type of thing with a
"Get External Data"
"new web query"
which will put things into a sheet in such a way as you can use them in other calculations
Whenever you open the sheet it will go and get the latest information for you automatically so you can then select what you want and copy that to another sheet. to use to keep track of things.
Oct 17, 2009 | Microsoft Excel 2003 (065-03992) for PC
Gibberish + won't finish loading Windows
remove the new memory first. if that does not help you may have some a virus, indicated by safe mode workng fine. One other thing i found would do that is a damaged Hard drive, not to likely here because safe mode works.
Apr 28, 2009 | Dell Dimension E521 PC Desktop
Prints gibberish
You need to ensure you have the correct drivers for your computer. Adobe uses PostScript drivers to print out .pdf files. Some drivers are Printer Control Language (PCL) and do not work well with .pdf.
Dec 25, 2008 | Brother HL 2700CN Laser Printer
Printing gibberish
gibberish printing is normally a sign of outdated print drivers. Try going to HP's support site and download the latest PCL driver.
Sep 22, 2008 | HP LaserJet 4100 Printer
"chk" error on screen olympus vn-4100 pc
I had a similar sounding problem my Olympus VN-5000. I would turn it on, it would show "CHK" for a few seconds, and then "ERR." This persisted despite fresh batteries. The "ERR" message reportedly means a memory error. I found a solution, which appears to reformat the memory. Try to press the STOP and DISP/MENU buttons at the same time for about 2 seconds, and then the display should show "FOR". It will supposedly erase the whole memory, but will at least make the device usable again! I hope this solution works for your model...
Jul 20, 2008 | Olympus VN-3100PC Digital Voice Recorder
Gateway laptop vertical dotted lines across the screen
Sounds like a problem with the LCD assembly or cable. You may want to reseat the LCD cable at the LCD end. It could be a loose internal connector in the LCD assembly.
Ron-
Dec 13, 2007 | Computers & Internet
Olympus VN-3100PC Digital Voice Recorder Logo
283 people viewed this question
Top Olympus Audio Players & Recorders Experts
pankaj rautela
pankaj rautela
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
