Question about Aftermarket Volvo 740 Turbo A/C Condenser 1990-1991
What size battery cca for a 1991 volvo 740 turbo?
Recomended col cranking amps
I need diagram for belts for 1991 Volvo 740 turbo ?
42387355
  1. Crankshaft pulley
  2. Alternator
  3. Cooling fan
  4. Power steering pump
  5. AC Compressor
Feb 25, 2011 | 1991 Volvo 740
I have a volvo 740, 1991 and i do not have the owners manual so the question is what is the facturer's recomendete gap for the spark? experiences welcome>>>
I don't happen to have that info but if you call any local auto parts store and ask them the same question I bet they can give you an answer faster than I could.
You need to give them your engine size though.
Dec 02, 2010 | 1991 Volvo 740
Where is the fuse box located on a volvo 740 1991 model
on the 1991 740 the fuse box is located behind the black ashtray, unless you have a 740se, in which case it can be located on the side near the door, like in the 760turbo and 780bertone turbo. good luck :)
Aug 08, 2010 | 1991 Volvo 740
How do i replace the turbo in my 1991 740 volvo?
You bring it to me along with the new turbo. OR you take it to another mechanic. It will require a full set of mechanics tools and careful attention to detail.
Mar 09, 2010 | 1991 Volvo 740
1989 volvo 740 turbo no start problem car will
Try replacing your fuel pump relay,
Jun 16, 2009 | 1989 Volvo 760
What is the Cranking Power for the Battery
Right way to do this is to match the post position & case size, then buy the battery with the highest cca you can afford. Don't use less than the one that's in the car now. Turbo does not require more cca than non turbo...it creates no extra drag on the engine when starting. Higher cca will help with cold starts and hot weather, generally not being "worked hard" will also extend it's life.
Apr 07, 2009 | 1998 Isuzu Trooper
Aftermarket Volvo 740 Turbo A/C Condenser 1990-1991 Logo
18 people viewed this question
Top Aftermarket Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you an Aftermarket Heating and Cooling Expert? Answer questions, earn points and help others
