Question about Onkyo TX-SR304 Receiver
Power won't stay on my onkyo tx sr304
Onkyo tx-sr304 got slightly wet. I immediately turned the power off, unplugged it, disconnected all the wires, removed the top plate/encasement, dried it with a hair dryer and waited 1 hour. Following the instruction manual, plugged just the power cord in, turned it on and set the volume to max. It stayed on about 3 seconds then the protection/ standby kicked on. What next or is it even worth it?
  • Nathan Oliver Jan 18, 2013
    Thanks and it's working except for the right rear surround. I will be putting a multi meter to it in the AM.r to it
heyitsmiked
SOURCE: What remote control code does the Onkyo TX-SR304 use?
1) Tap AUX
2) Press & Hold Setup (1 then 2 blinks)
3) Enter 30842 or 0842 (The remote should blink twice)
4) Press & Hold Setup (1 then 2 blinks)
5) Enter 994 (2 blinks)
6) Tap Setup (1 blink)
7) Enter "00051" (1 blink per number)
8) Tap Power (not All On, just "power") (The remote should blink twice)
9) Tap AUX
10) Press & Hold Setup (1 then 2 blinks)
11) Enter 30135 or 0135
Posted on Apr 08, 2012
techman
  • 3130 Answers
SOURCE: Onkyo TX-SV434 "Protect" light
The protect mode is a built in safety message, indicating that theres a fault somewhere with-in the unit, and it wont let the unit come on fully or more damage will occour. This unit is a solid state device, and you should not attempt to use it or open it or try any self repair as it will cause more damage. If this unit is more then a few years old , it might just be the time to start looking around at all the back to school sales on electronics, as to have this unit serviced will cost an estimate fee as well as parts and labor. If you want to invest a few bucks into this machince , then go for it, but its most likly will cost 1/2 or more then the cost of the entire unit did when it was new to have it repaired. It is up to you. Good Luck
Posted on Aug 09, 2006
  • 3422 Answers
SOURCE: Onkyo AV Receiver TX-SR503 While sleeping
HI,
Did you try reseting it?There must be a reset button at the back of your reciever.
Posted on Jul 03, 2008
  • 4234 Answers
SOURCE: Onkyo TX-NR905 Protection Circuit Activated
The problem is not with the inputs. This unit is in protect because a problem has been detected in the output section. Try disconnecting the speaker wires and turning it on. If the unit remains on, there is a short in one of the speaker wires. If the unit still shuts down, there is an internal problem that will require repair. It sounds like this is a new piece. If so, it should be covered under warranty.
Keep us posted,
Dan
Posted on Jul 28, 2008
freetek
  • 5568 Answers
SOURCE: Onkyo TX-DS989 not staying on
This sounds like the action of some protection circuit that is monitoring some condition or voltage that isn't within its design limits. If it was mine, I'd look for an Onkyo forum to see if others have experienced the same problem.
Posted on Jan 08, 2009
My Onkyo TX-SR606 won't turn on
The reference to Zone 2 means that your Onkyo receiver is set to be remotely controlled from another location. Normally, this arrangement would be initiated at the time of set up but could be done later. You may have to repeat the initial set up routine to get things back to normal
Feb 22, 2013 | Onkyo TX-SR605 Receiver
Tip
Download Onkyo TX-SR304 Manual
Download Onkyo TX-SR304 Receiver Users Manual
Have you misplaced your Pioneer Download Onkyo TX-SR304 Receiver Owners Manual?
Would you like a digital, searchable, pdf version of the Download Onkyo TX-SR304 Receiver Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
on Apr 20, 2010 | Onkyo TX-SR304 Receiver
My onkyo tx-sr605 7.1 a/v tuner will not switch from game/tv to cable/sat or any other mode. I can't even get into the setup moder It won't power on even if I press the power button manually.
You have this all backwards. So essentially it won't power on. THAT must happen before setup or anything else.
http://www.retrevo.com/support/Onkyo-TX-SR605-Receivers-manual/id/2526bh742/t/2/
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Aug 21, 2011 | Onkyo TX-SR605 Receiver
I lost my owners manual for my onkyo av receiver tx sr304. Can you please send me one.
Here is the pdf http://63.148.251.135/redirect_service.cfm?type=own_manuals&file=TX-SR304_En_0124.pdf . I found it on Onkyo's support page http://www.onkyousa.com/download/own_manuals.cfm?cat=Receiver
Feb 28, 2011 | Onkyo TX-SR304 Receiver
How to program remote control?
Your Onkyo TX-SR304 receivers remote (RC-645S) is not capable of controlling devices by other manufacturers. It controls only Onkyo devices.
Other Onkyo remotes do have universal remote functionality and you can download Onkyo remote codes here.
I hope that helps.
________________________________________
Download Onkyo TX-SR304 users manual here.
Mar 26, 2010 | Onkyo TX-SR304 Receiver
I have a onkyo tx sr304 and a onkyo 6 disc player dx-c390.When my cd gets to disc 4 and 5 it shuts the receiver down.Whats up with this?
The only possibility that comes to mind is that it may be causing a short somehow when the carousel gets to that position, maybe a broken solder joint. Another possibility is that there may be a foreign object stuck inside the player such as another disc that lost it's position.
Feb 19, 2010 | Onkyo TX-SR304 Receiver
TX-SR304 AV receiver
If you put DVD with Dolby Digital soundtruck it will show on your TX-SR304 Dolby Digital mode, and if you have DVD with DTS mode it will show DTS
Jan 17, 2009 | Onkyo TX-SR304 Receiver
Need codes for universal remote
Not sure if this helps, but I just called Onkyo with a request for codes for the SR304. They said the only codes they have are for THEIR remote. Maybe they will work with yours. Here they are:
0276 0476 0810 1187 1376.
I tried these in the Comcast remote (adding a 3 in front of the numbers) but that didn't work. Still trying to get my Comcast remote to program the Onkyo SR304 adequately, since their published codes only partially work.
Dec 30, 2008 | Onkyo TX-SR304 Receiver
Onkyo TX-SR304 Receiver Logo
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
