Question about Kenmore Washing Machines
My kenmore elite calypso washer won't fill up enough to get clothes completely wet.
It does recirculate the water. it agitates and spins and runs through all the proper cycles but the clothes are barely wet therefore not getting clean. please help...
  • Kenmore Master
  • 17,129 Answers
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Posted on Jan 18, 2013
  • 10 Answers
SOURCE: Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Posted on Dec 15, 2007
hotuna
  • 288 Answers
SOURCE: Kenmore 20702 Top Load Washer Problem
First check the lid switch. Its a little slot inside the top panel and when the door is closed it has a prong that pushes the switch down when closed. It is a safety feature. If you can find this press the slot with a screwdriver or something and listen for a clicking sound.It is also possible that one of the wires has come off, so that may need to be looked at too. Also check the lid to see if the prong has been broken off. If you have both of these things checking good, then it may be a more complicated issue like power to the wig wag coils, or a timer. We can however eliminate the motor, belt and water pump as these all work. I would put my money on a simple lid switch problem though.
Posted on Dec 19, 2007
  • 96 Answers
SOURCE: series 70 kenmore elite washing machine
If it goes through the complete cycle o.k. except for the slow spin then the motor itself needs to be checked.
Posted on Mar 20, 2008
  • 1122 Answers
SOURCE: kenmore washer spin cycle doesn't leave clothes dry
SOUNDS LIKE THE TRANSMISSION IS NOT ALWAYS SHIFTING INTO HIGH SPEED MODE,TRY A MED. SIZE LOAD AND SEE WHAT THAT DOES,TRANSMISSION MIGHT JUST BE GETTING OLD WHIH IS NORMAL-MIKE
Posted on Dec 06, 2008
SOURCE: Kenmore Calypso washer Ld code?
I just had the same problem. I borrowed my neighbors wet vac. The hose of the wet vac fit right over the end of the drain hose and I sucked out all the remaining water. My hope was that if the hose was clogged that it would clear it out. It seems that it worked. I put the drain hose back in the drain and turned on the extended spin cycle. It was working, so I put the water logged clothes back in the washer on the extended spin cycle and it took the water out. I am now in the process of washing another load to see if it really fixed the problem. I hope this helps.
Posted on Jan 25, 2009
Kenmore Elite HE4T washing machine diagnostic test not completing - getting stuck on C05
http://www.managemylife.com/images/6975/original/346.jpg?1303498921
According to this it could be either the Computer (don't think so but don't rule it out just yet.), the fill valve, or the heater. Appliance Repair Forums
This link will help you test the fill valves.
This will link you to a service manual for the HE3T washer which is very similar to yours and the diagnostics and tests will be the same. https://www.ifixit.com/Document/1074/.pdf
Jan 20, 2017 | Kenmore Washing Machines
Whirlpool Calypso Washer Mdl#30942 gets stuck during rinse cycle. Machine runs, then stops, but does not rinse completely. Last 35-38 min cycle is problematic. What is wrong and how to fix it?
It's hard to tell by your description of the problem, but it sounds like it could be the timer If it's not running while in spin mode, or as simple as a belt if it's running and not spinning fast enough.
Nov 28, 2014 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite Top Load..Rinse water keeps running in Spin Cycle. Clothes are soaking wet when spin cylce is complete
the fill valve is an electric magnet valve and sounds like it is stuck unplug machine disconnect water lines plug in and when u turn on does it click, if yes then unplug try to slide a long qtip in and if it goes in replace valve
Jul 06, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Washer 110.24992300 spin problems
The pressure switch is mis-reporting the water level to the ECU.
Test/replace the pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore elite calypso top loader clothes still wet after spin
more than likely the machine has a bad clutch or motor.. in most cases it is cheaper to just buy another top loader.
Mar 06, 2009 | Kenmore 24032\24036 Top Load Washer
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Calypso kenmore elite water level low sometimes
something is clogging recirculating pump inspected both pump that should fix
Nov 30, 2008 | Kenmore Elite 45986 Front Load Washer
Washer calypso
Unplug your machine for 5 min then turn on spin to remove water. If water won't go you have a bad water pump. Code FL refers to a low water flow problem ( won't fill fast enough ) or old water still in tub.
Next you need to turn off the water ot the unit and remove the water lines. Look into the water inlets on the washer to see if the dirt screens are clogged and not letting water into you unit at a fast enough pace.
Your unit has a water level sensor and should agitate when full, but I believe your machine might be "timing out" i.e. not filling as fast as your unit expects so even though it doesn't fill all the way it begins agitating because it has taken too long to fill. Good Luck!
barneyluc
Oct 03, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore elite calipso was motion
calyso is a low water use machine similar to front loads only enough water enters machine to get clothes soaking wet water is recirculated through tube on back right corner of tub to insure clothes are soaked if pressure switch determines minum water level not reached it will add more
Apr 26, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite Calypso washer won't fill with water!
i assume that the warer is turn on at the warer valves if so then do you have voltage at the water valve if not then water pressure switch could be bad or main control board could be bad
Apr 24, 2008 | Kenmore Elite HE4 Electric Dryer
Washing Machines Logo
65 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
