Lghs2655kpo INTERFACE CONTROL
UNABLE TO SET TEMPERaTURES
  • Washing Mach... Master
  • 17,130 Answers
Possible that the fault relates to fault in the panel board. Remove the panel and reset all connection before confirming the case.
Posted on Jan 18, 2013
What does manufacturer control auxiliary input auxiliary output mean
set level of input and output for audio .. similar to line in and line out of a stereo amplifier. This means you cannot alter the level of the signal out put or input to your audio system. It is set by the manufacturer. For a 1996 Ciera I assume you are adding some type of interface so you can either input or output a signal for a device. It is probably a set level on the interface. Some interfaces have tiny knobs where you can control the gain for input or output orthers are set by the manufacturer of the interface.
Aug 03, 2015 | 1996 Oldsmobile Cutlass Ciera
We are having problems with the control panel on the front of our frigidaire refrigerator. the freezer temp is supposed to be a reading of -2 but it is now on 4 . we have tried to reset it but it wont...
I appreciate your inquiry, Marcy!
I understand that you are having issues with the temperature of your Frigidaire refrigerator. The best way to reset your refrigerator is disconnecting power. You can do that by unplugging or flipping your household circuit breaker off for roughly ten minutes. If you continue to experience issues with your refrigerator it could be a possible issue with your control panel, thermostat, or user interface board. I would then recommend having a technician out. They will be able to pinpoint which component is faulty. Hope this information helps. -Matt
Feb 28, 2015 | Frigidaire Refrigerators
TOYOTA HIGHLANDER A/C CLIMATE CONTROL NOT FUNCTIONING
Based on the limited information provided, it would appear you have a bad climate control control board. This controls all heater/AC functions including climate control. If you're unable to change temperatures and/or fan speeds, the board is most likely bad and needs replacement.
Nov 16, 2011 | 2003 Toyota Highlander
How can I get into the cut-on settings of refrigerator
Purchase an appliance thermometer that is specifically made for refrigerators and freezers. These special thermometers were made to withstand cold temperatures and provide an accurate reading when exposed to such temperatures.
2Place the appliance thermometer in a glass of water.
3Set the glass of water with the thermometer in the refrigerator on the middle shelf.
4Check the temperature on the appliance thermometer after 24 hours.
The temperature should register between 37 and 40 degrees Fahrenheit (2 and 4 degrees Celsius) in order to store food safely.
Only barely above freezing -- say 34 degrees Fahrenheit (1 degree Celsius) is even better for food storage at the cost of slightly higher electricity consumption. But check that food is not slowly freezing in any part of the refrigerator, which could make it less palatable.
5Look for the temperature control dial inside the refrigerator if you have to adjust the temperature, and make it warmer or cooler.
If you can't easily see the control dial, check the owner's manual for a diagram that shows the location.
When looking at the refrigerator temperature dial, you may see numbers rather than degrees. The majority of refrigerators use a set of numbers, with the lower numbers representing cooler temperatures and the higher numbers representing warmer temperatures.
6Move the temperature dial in the necessary direction to adjust the temperature up or down. Be sure to move the dial only one number in either direction because it probably will not take much to change the temperature in the refrigerator.
7Adjust the temperature balance control if your refrigerator has such a dial or sliding switch. This allows you to direct more or less cold air to the refrigerator section from the freezer section.
8Wait at least 24 hours, and then check the refrigerator temperature again.
9Observe the amount of frost in the freezer section of the refrigerator if you are unable to properly set the temperature.
10Defrost the freezer if the amount of frost is more than .25 inches (.64 cm) thick.
11Repeat the steps as necessary until the temperature is within the safe range.
12Use a permanent marker to draw a line on the dial after you locate the best setting on the refrigerator temperature dial. This will give you a reference point in case your dial moves and needs to be adjusted in the future.
Hope this help in solving the problem....
May 12, 2011 | Refrigerators
How do I regulate temperature
I hope this will help in solving the problem.......
May 09, 2011 | Samsung RF265AA Bottom Freezer French Door...
How to set up the temp. please
Hope this will help out...
May 07, 2011 | Traulsen Refrigerators
I cannot adjust the fridge/freezer temperature
Hi, there
Hope that helps in solving the problem...
May 07, 2011 | Refrigerators
F 70 is flashing ???
Error code 70 means a Central Control Unit Heartbeat Failure. There is no
communication detected from the Central Control Unit to the
User Interface (the part that you touch in the middle to set cycles).
Possible Causes/Procedure
1. Check for continuity of the User Interface harness.
2. Check wire harness connections to the User Interface and
the Central Control Unit.
Nov 26, 2010 | Whirlpool Washing Machines
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
