Question about Polaroid PDV-0823A Portable DVD Player
Polaroid DVD player PDV0821T
Does anyone know exactly how to take this thing apart and put it back together ? I need to replace the outer shell on the bottom unit (not the screen) because a small plastic piece broke off and now the top disk cover won't close. Where can I get information about this model ?
  • Tony Harrison Jul 13, 2007
    My post clearly states the reason. Again, it is to replace the shell/case on the bottom part so that the top cover will be able to close again. A small plastic piece broke off and the whole case must be replaced.
    Genius:
  • 2,985 Answers
Taking it apart to do what exactly?
Posted on Jul 12, 2007
  • john ash
    john ash Jul 13, 2007
    The reason you gave I under stand perfectly.
    The problem is replacing with new components.
    Are you sure they/it is obtainable?
    Best to be sure before you delve further.
    However to respond to your quest - does the device have round rubber 'feet' at each Corner?
    If affermative then prizing these off may reveal a screw. If it does not then the answer is it is a snap together clam shell type, with risk of further damage.
    Best way to overcome this problem perhaps tis to fabricate a some thing with glue on Velcrow
    [hook and hair type fastener]
    Obtaining replacement parts is your main problem I would say.
We have a CGN300TQ heater. We took it apart, cleaned it, and had the outer shell powder coated. We put it back together, but now, we have to light the pilot light and the gas burner will not catch.
you might need to adjust the air on the pilot assembly,WARNING!!!,IF THE AIR IS NOT PROPERLY ADJUSTED AND YOU HAVE IT LIT,YOU CAN DIE FROM CARBON MONOXIDE POISONING!!!!!
call someone to adjust it,you may also need this part,
Apr 02, 2015 | Heating & Cooling
DVD Player will not power on. Power Indicator Light flashes repeatedly.
Plug out the device,Open the outer shell or strip the outer shell take a hair dryer heat up the board slightly until it feels slightly warm then plug in and switch on and remove disc.Then put outer shell back and fasten screws that where removed.
Jan 06, 2014 | Sony DVP-CX860 Multi-disc DVD Player
I took the battery apart and I don't know how to put it back together. Is there a diagram or manual to solve this problem?
Download either the user manual or service manual to this set. It will have all details.
If you wish to get the user manual to this device, send your email address to me, and get a copy of it by return mail.
Jun 03, 2012 | Polaroid PDM-0817
I need to put a new door handle on a kitchen aid microwave. It is above the stove, the model number is khms155lss-4
The diagram can be found at
http://c.searspartsdirect.com/lis_png/PLDM/W0601206-00002.png
Open the door all the way and lift it up (press on bottom of door) to lift the hinge pins out, then pull away from the unit (walk backward) to remove it.
Then, the remove the inner plastic shell from the outer plastic shell by prying gently around the outer shell. There are no screws holding it together.
Once apart, you can see the screw (item 8 in the drawing). You can remove the screw and replace the handle. reverse the process to get it together.
Make sure the door is all the way back in tightly and firmly just as it is now or you can have a microwave leak. Work carefull and, if you have a digital camera or a camera phone, take pictures of each step to make sure you know how it goes back together.
cheers.
Jul 15, 2011 | Microwave Ovens
My shaving head came apart and I can not re assemble it, kindly give me instructions
Wife cleaned bathroom shelf dropping the Arcitec. One of 3 heads was not aligned properly, when I tried to re-seat it, this head came apart. To put it back together takes some finesse and patience. Take a coil of stamps, or some other small opening to rest the outer plastic shell head, then insert the metal screen which has notches (2 small, 1 large) and fit it in the plastic shell head. Next put the metal blade assembly on the screen. Next align this on the metal (thin) pivot. When the outer plastic head, and the metal pivot are aligned (small peg holes), you can place the thin inner plastic piece on and gently press your sub assembly and the backing plastic together, It will snap together and hold. Don't FORCE it, the holes must be aligned on the outer plastic, the metal pivot frame, with blades resting on the screen. It does snap together. Work with fairly bright light to see what you are doing. If this fails, invest in a new head assembly for about 15% of the cost of the whole razor.
Jun 10, 2011 | Norelco Arcitec Electric Shaver -...
Khms155lss1
The handle can only be changed by separating the outer and inner shells of the door. You can pull the outer shell off the inner shell by removing the three screws at the end of the door and then using firm force to pull the shells apart. It helps to gently pry along the bottom, top and inside (nearest the hinges) with a thin flathead screwdriver or other very thin metal object. You don't have to get it all the way loose; just a little is fine. You can then use the two clasps on the back of the door (that hold it shut when it's closed) to pull with. I found that inserting a slim screwdriver into the lower clasp and using that as a handle (not a lever!) gives you a better grip. Hold the outer shell of the door with your left hand while pulling the inner shell in the opposite direction. Be carefull not to twist or bend the clasps; they are plastic and will break. The shells will pull apart and then you can access the screws that hold the handle. Change the handle then press the door shells back together. Make sure they are snug all around. Replace the three end screws and you're done.
Jan 08, 2008 | GE JVM1650 1000 Watts Microwave Oven
Main Drum Bearing
Rear Main Bearing is bad, Believe you have replace whole back of the drum, about 200$
May 16, 2007 | Frigidaire GLTF1670A Front Load Washer
Polaroid PDV-0823A Portable DVD Player Logo
131 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
