I need to replace my broken door handle on my machine but i cant find a replacement handle
Balay is a Spanish made machine is there anywhere in england where i could get a spare or are they made under licence
  • Washing Mach... Master
  • 17,130 Answers
Please check this link: Handle
Posted on Jan 18, 2013
SOURCE: Broken front door
you need to buy a new 'handle'. to open the door for the time being, disconnect power and then use a coat hangar to pull the latch towards you, ie. outwards
Posted on Jun 09, 2008
SOURCE: Broken Handle
Contact this person and his company. They have the handle kit for the WD-2100
Darrell Klein National Service Director
Westland Sales /
Splendide Combination Washer Dryers
15650 SE 102nd Ave.
Clackamas, OR 97015
503-210-3914
darrell.klein@westlandsales.com
Posted on Jul 28, 2008
  • 566 Answers
SOURCE: cannot open door as handle broken for indesitw103
hiya easiest way to open is = first unplug power! then turn off water hoses to machine then draw machine out to gain access to pipe connections on rear and disconnect them ? now remove rear panel top screws as these also secure the top panel at rear then lift rear of top panel and pull to rear the panel now can be removed ? you now have access to the latch on front panel inside? if you reach down you can flick latch /hook clear to open door ? at this point after removing washing? you can observe the door inner remove inner panel that surrounds/secures glass? then you can observe how the door handle/lock assy is secured ? easy diy you can browse yellow pages for the replacement handle assy? machine repairs/spares reassembly is reverse to above wish you well this is a common occurance and should not have prob obtaining parts for the MAKE/MODEL NUMBER ? when enquiring for parts best wishes
Posted on Oct 21, 2008
gittos73
  • 244 Answers
SOURCE: Broken door handle for a Thor washing machine
there r 2 ways to get the door open 1)use a normal knife and place in front of the door handle push it in and it should open 2)pull the plug out take the lid off now place your hand down to where the catch goes into the washer using your fingers u should be able to pop it open with a bit off fiddling
Posted on Dec 16, 2008
  • 3 Answers
SOURCE: Broken door handle on Splendid 2100 RV Washer/Dryer Combo
The Splendide distributor in OR sells handles for about $45.
Posted on Jan 28, 2009
My Bosch Vision 300 series washing machine wont start?Why? What has to be done to it?
Michael, the door lock/latch mechanism should be tested, if faulty replace. Have a good repair Tech. check, diagnose and estimate repair. Make sure to at least look at the first link, it tells of a reset procedure that may fix your washers door latch problem. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://baubilt.com/?p=1318
How to replace washing machine door lock on Balay Bosch Neff and Siemens
http://www.repairclinic.com/Shop-For-Parts/a11b129/Bosch-Washing-Machine-Parts
Aug 22, 2016 | Bosch Washing Machines
Balay washing machine door wont open
We were staying in a holiday apartment and couldn't get the Balay washer/dryer door open on dryer cycle. Tried all the previous solutions and none worke. my husband turned the power off to apartment at fuse box and the door clicked open after a couple of minutes.
Feb 18, 2014 | Washing Machines
Back door won,t open on my 02 avalanche
door handle broke depends on what door handle it is.if door cant be open on out side out side door handle broke.if cant open door on inside inside door handle broke.door handle clip that connects to latch rod broken.when you try open door handle not engage to latch rod.door not going open.have to replace door handle with new clip holds latch rod in place.
Jan 09, 2013 | 2002 Chevrolet Avalanche
I have a broken door catch for a Siemens Siwamat XB 1061. Can I get a replacement part
I feel for you because we have exactly the same problem : our door broke, the handle in fact. Everything else works wonder but the screw driver trick is bound to give in one day eventually and we'll be left with no washing machine at all. Has anyone found any infor on the door anywhere? thanks guys
Mar 19, 2011 | Siemens Washing Machines
The handle on my outdoor faucet is broken. I
Have you checked with a plumbing supply hose if it is a square slot you may could use a handle off a boiler drain for a washing machine .
Check it out if it is a metal red or blue metal it may be the same type used on your washing machine cut off valve
Apr 26, 2010 | Danco Clear Faucet Decorator Handles
The door handle has broken off and a piece of the door where the screws for the handle go is broken. Right now, the only way to use the washer is by taping the door shut. Is it possible to replace the...
from your description It seems to me you need frame #8182628 and handle #8181846.
the door comes as separate parts, not an assembly, but they are pretty straightforward to put together
Apr 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
1998 toyota 4 runner back hatch handle broken
get inside the back take door panel off mipulate door latch to open
Jan 14, 2009 | 1998 Toyota 4Runner
Help needed indesit washing machine
well it would help to know brand/model#
Oct 03, 2007 | Washing Machines
Washing Machines Logo
55 people viewed this question
Top Washing Machines Experts
