Question about Ovens
I have a siemens hb 13 m.50b double oven, when i turn on the main oven the light on the oven comes on but the temperature light does not light up and the oven does not warm up
  • 6 Answers
SOURCE: Main oven not heating.
Hi, Is this your fan oven element that is not getting heating up? If so we have a guide on our site which may be of assistance: http://www.ransomspares.co.uk/fan_element_article.html
Posted on Mar 01, 2007
SOURCE: just brought belling xou594 double
BELLING XOU252 WHEN IT IS SWITCHED ON IT TRIPS THE MAINS ALL WIRES SEEM TO BE GOING TO EARTH.
THANKS
MEL
Posted on Aug 16, 2008
aborcass
  • 2651 Answers
SOURCE: Ovens do not come up to set temperature
most common issue wsith these gas wall ovens is faulty ignitors, i would reccomnd replaing the ignitor(s). that being said i wouuld also reccomned a servicer with experience on this model for they can be a more tricky then ohter ranges out there, and the possiblity of "shorting out" adddiont al parts is higher on this model! and no one is currently producing a double self cleaning, full sized gas wall oven, so id hate to see you ruin this one!!!
Posted on Feb 16, 2009
SOURCE: Cannon Cambridge Double Oven. Main oven not heating up
Problem solved, Turned out to be the flame fail device. Next problem was sourcing part. Turns out that allegedly Cannon is now owned by Hotpoint so sourced part through them
Posted on Nov 26, 2009
SOURCE: Hotpoint BU62 double oven, no grill functioning
keep turning the oven/grill selector past the temperature settings, it feels like it won't go any further but it does!
Posted on Feb 07, 2010
I need to purchase a temperature selector for the main oven (siemens) double oven - HB13M50B. Can you help me with this? Thanks
If your model # is in searspartsdirect.com database, you can find parts list and diagram there v
Nov 13, 2017 | Ovens
Main Oven does not reach required temperature
check gas pressure and burner if ok bad temp sensor
May 19, 2017 | Electrolux EOD5330 Ultrafan Electric...
I have an aeg d2100-4-m oven. main lower oven not getting hot. Have replaced element, to no avail.Fan and light in oven both come on, but have noticed that the temperature dial light is not illuminating....
Hi .
Sounds like the oven thermostat is faulty.,
This gives a supply to the element .
The temp indicator should be lit, if it is not, then I would suggest repl;acing the oven thermostat.
Sep 28, 2011 | AEG D2100-4 Electric Double Oven
I can't get my Siemens oven self cleaning feature to work. I first set the dial to the cleaning position. I then try and set the temperature dial. As soon as I turn the dial the beeper sounds with the...
You have to take everything out your oven all the removables , then turn knob to pyrolyse and the other knob to 1 for mild cleaning 2 for medium and 3 for heavy cleaning
Jan 10, 2011 | Siemens Ovens
The top oven of our double oven will not heat up. However the fan still comes on...could this have to do with the elements or is it something else?
Hi.
Did you notice whether the mains circuit breaker tripped while you were cooking last?
Howvever if your temperature light comes on and also the fan then the most likely cause is a fan element.
Should you need any help with obtaining a replacement part please email me on: aardvark.repairs@btinternet.com
regards
Aardvark repairs
Nov 17, 2009 | Frigidaire 27" Built-In Double Electric...
My hotpoint ew61 double oven doesnt come up to
If it is heating, but not getting hot enough, then it is possible the thermostat is cutting the element off too soon, in this event, you will need to replace the thermostat.
If it is not heating at all , then the element is probably faulty.
Please rate my solution.
Thanks.
Nov 14, 2009 | Ovens
Siemens oven tripping RCD
We need wiring diagram for HB905 Siemens double oven, to start with it kept tripping, element ok. Now we have no heat coming from the main oven.
May 02, 2009 | Siemens Ovens
Duco4ss main oven not heating on fan setting
put test bulb on the two wires going to fan heating element,that will tell all,if bulb lights,its the fan element that needs to be replaced!good luck!!
Dec 17, 2007 | Ovens
Ovens Logo
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
