Question about Brother IntelliFAX 5750e Laser Fax
Brother intellifax not being found on network
Ever since we bought this fax years ago our network has never been able to find it in the list of available faxes or printers. I have tried searching for it through ip and it will find it that way but I am now having a problem since updating our computers to Mountain Lion where it will keep all jobs in a queue and never send them to the fax machine. I have been looking everywhere for an answer as to why this is occurring but have yet to find an answer anywhere. Any help with this issue would be greatly appreciated.
  • 186 Answers
SOURCE: Brother 1270E won't receive faxes
make sure the phone line is plugged into the port marked "line" not "phone"
Posted on Jun 21, 2007
  • 22 Answers
SOURCE: IntelliFAX 4750E - Printer Busy
The printers memory may be full depending on the type of documents they are printing. The first and most simple step is to unplug the power cord from the back of the unit for 30 seconds, put your finger on the stop key while plugging the unit back up and continue holding the stop key until the time and date are back on the display of the Brother unit.
If that does not work unplug the USB cable from the PC. Unplug the power cord from the unit again. Put your finger on the menu key first and then plug the unit back up. You want to hold the menu key unit the until the LCD says maintanence and all the lights are flashing. Let the menu key go and press the number 82 and will give you an error code. If the error code is 00 then there are no errors. If there is an error code record it and contact brother or check a service manual if you have one. Most laser products all have the same error codes with Brother.
To reset the unit press stop and then 91, this will reset the unit and all faxes or print jobs will be lost. This should clear the issue.
Posted on Jan 02, 2008
SOURCE: brother intellifax 4750e
if the copy comes out black and/or sends black the Contact Image Sensor in the scanner may be needed.
Hope that helps...
Posted on Jun 17, 2008
leroyal
  • 2120 Answers
SOURCE: Brother 4100e Fax Problem - Caller ID won't work with Fax Machine
Usually, fax machines don't have caller ID capability.. If the sender's fax number appears on the faxes you receive, it's just that they have programmed it into their fax machine as a header.
Posted on Sep 12, 2008
  • 9 Answers
SOURCE: able to receive fax but cant send
sleep mode is just a status of the machine when it is in idle mode.you cannot turn this off however you can delay the time before the unit goes into a sleep mode.it has nothing to do when you are sending out faxes.so here are a few things you need to check when sending a fax (1)dial tone by pressing hook/hold button (2) insert the doc into the adf, make sure it will change to "enter fax # and start,or copy press copy (3) dial the number (4) wait for fax tones of the receiving unit before you press start. now if you can hear an operator on the line,that has to be verified with your phone company since brother machine does not restrict incoming and outgoing faxes UNLESS that is restricted from your phone line.
Posted on Nov 19, 2008
How do you get a page count for a brother intlei fax 1270e
On most IntelliFax machines, you can see the page count by printing out a user settings list and looking in the lower right corner of the list. Some list the page count, others don't.
On the IntelliFax 1270, follow these steps to print the user settings list.
- Press Function.
- Press 3.
- Press 6.
- Press Start.
Aug 05, 2011 | Brother IntelliFAX 1270E Plain Paper Fax
Intellifax 770 print transmission verification report for multipl
You can print an activity report by pressing FUNCTION, 7, 2, START. That will give you the last 30 faxes sent and received, It will only show that you dialed though, it will not be a true verification report. In case you need it, you can download the manual for your fax here:
http://pdf.textfiles.com/manuals/FAXMACHINES/Brother%20IntelliFAX%20770%20Home-Office%20Fax%20Machine.pdf
Dec 05, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
Have a brothers intellifax copier - fax about 5
clean laser... if still there change drum.. if still there clean ccd... if still there... contact brothers support and they will walk you through it or send you to a service center for it to be repaired
Oct 07, 2009 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFax 4100 skips
check the paper size settings, that it is set to the same size as the actual paper
~50% chance of being a solution, cant do better
Jun 24, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother Intellifax 2800 replace drum message
the unit that you install the toner cartridge into is actually the drum on this machine.
Jun 24, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFax 4100 sending solid black pages
It sounds like the CIS (scanner) has failed in both machines. Its no generally not a common problem. I would change one every six months if I was lucky.
It may point to something in your environment. I have have seen rust build up on the contacts of the scanner cause this problem. So if you have high moisture or are close to the ocean this maybe a problem.
Feb 14, 2008 | Office Equipment & Supplies
Fax installation
There is no installation CD for this machine. The machine sends, receives and copies. The machine will not connect to a computer and does not need a CD to perform it's functions. Years ago Brother had a 770 which is the father of 775 that connected to a computer by purchasing software and a cable(PCI-1). This software is outdated and does not work well with any of the current windows programs. Most Brother ink-jet and laser products will connect to a computer via an installation CD or down loading the drivers from Brother.com. None of their thermal machines will connect to a computer.
Sep 20, 2007 | Brother IntelliFAX 775 Plain Paper Thermal...
Brother IntelliFAX 5750e Laser Fax Logo
24 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
