Question about Xerox Office Equipment & Supplies
Keep getting Beep sound after installing a compatible toner while printing as normal
    Problem Solver:
  • 6 Answers
Its normal, the printer only recognises branded ones.
Posted on Jan 17, 2013
2 Suggested Answers
  • 628 Answers
SOURCE: hp2820 noise when printing
Try substituting a new imaging drum. The problem may be a bad bearing.
Posted on Oct 10, 2008
Why does my 6280 separate one image into two and print it?
Poor fusing of the toner onto the paper is caused by
1. Poor quality compatible/remanufactured toner cartridges that have the wrong toner in them. - Use OEM, or better quality independent toners (and complain to your current supplier about the ones you have)
2. Damp media - high moisture content in the paper prevents correct fusing. You'll probably see the paper 'steaming' as it comes out if this is the case. - Keep your paper dry, only load as much as you need.
3. Thicker than normal media. The thicker the paper, the longer/more heat it takes to fuse the toner. - Make sure you have the correct paper type set in the printer driver at print time.
4. Faulty fuser. Normally the printer will report if the fuser is not reaching the correct temperature, but there are instances when this does not happen. Also it is possible for the fuser heat lamp to blacken partially, resulting in an area of the fuser that does not reach the correct temperature. This problem will affect an area of the page which consistently (same place, and all the way down the page) shows poor fusing. - Replace the fuser.
May 18, 2014 | Xerox Phaser 6280N Color Laser Printer
Out of Toner / Change Toner - Canon image CLASS MF4370dn
The percentage-of-available-toner is based on calculations made by the printer's internal software -- quite different from putting a measuring-stick into an above-ground oil-tank to determine the ACTUAL level.
So, while the calculations say "zero percent left", there still is some toner inside the toner-cartridge, and so it still prints.
Buy a replacement cartridge. When you finally do run-out of toner, install the new cartridge.
Compare it to buying a new quart of milk, and then using the last 1/8 of the quart of the milk currently inside your refrigerator -- use the "old" milk until it is 100% gone, and then switch to the "new" milk.
Mar 11, 2014 | Canon imageCLASS MF4370dn...
I have an AL1000. I replaced the toner cart with a compatible unit. when I press print, I get a crunching sound in the back side like the teeth on a gear aren't meshing properly. This has been a w
The waste toner reservoir is full, empty before they damage your gear.
If not correct the fault with that, you have to check the toner cartridge and fuser
good luck
Apr 30, 2012 | Sharp Office Equipment & Supplies
I get black streaks on the pages I am printing
It sounds like you need a new drum, look here for some pricing. To replace the drum follow this guide on Brothers website.
Mar 05, 2011 | Brother HL-2040 Laser Printer
After installing an off brand cartridge for a Gestetner copy/fax machine, it only printed half pages and the printing was poor. They said the brand name cartridge was no longer available. please...
There are many different companies that sell compatible toner, and the quality varies greatly. You should try getting your money back from the company you bought that toner from, and find a new supplier if you can't get it from Gestetner. Premier is a company that sells compatible toner for many different machines, and they usually get pretty good reviews.
Aug 05, 2010 | Gestetner DSm620d All-In-One Laser Printer
I have a canon pc6re copier. I used a compatable \...
I'm guessing you used a compatable toner/drum cartridge. It sounds like you have a bad cartridge. If its a refilled drum cartridge its bad, either the drum blade is bad or charging is bad. Take it, or send it back and get another one. I recommend genuine "Canon" products. All toners and units are not made to the same standard as the Canon products.
May 18, 2010 | Office Equipment & Supplies
New toner cartridge but will not print
To get exact error. Please install samsung Smart panel software.
The error may not be from toner . May be toner or Compatibility issue.
Best Regards
Nov 27, 2009 | Samsung CLP 300 Laser Printer
Toner Problem.
Is this a remanufactured/ compatible unit? I suspect that the toner reset lever on the cartridge has either not been installed or not properly set. return for another one
Apr 24, 2009 | Brother DCP-7030 Digital All-in-One Laser...
Faint vertical lines on Samsung ML-2010
Was the toner remanufactured/ compatible?
Sounds to me like the doctor blade in the cartridge is 'gummed' up and not allowing the toner to flow evenly across the Developer roller......try another cartridge
Apr 10, 2009 | Samsung ML 2010 Laser Printer
Hp2820 noise when printing
Oct 09, 2008 | HP LaserJet 2820 Printer
22 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
