Question about Intel Fortran Composer Xe 2013 for Linux - Complete package 1 Year Support - 1 developer - Edu - DVD - Linux
Option '-w95' is deprecated
I Installed Intel Fortran Composer Xe 2013 for Linux to run a program but when i use 'make' command for installing it this error appears: ifort: command line remark #10010: option '-w95' is deprecated and will be removed in a future release. See '-help deprecated'
4 Suggested Answers
Witchunter
  • 98 Answers
SOURCE: I have no sound from Intel DG31GL motherboard.
Have you tried these drivers? They are for Microsoft Windows XP.
Posted on Jan 16, 2009
jomabug76
  • 1148 Answers
SOURCE: hi i have intel dg31pr board
search intel and internet for new lan drivers
Posted on Nov 03, 2010
Ezrahite
  • 2632 Answers
SOURCE: Newly installed Intel d525MW gives
Welcome to Fixya. May i know if the operating system is already installed on the hard drive if you set the hard drive to the first boot priority and the operating system is installed on it, it will not ask the floopy drive for the bootable device. If there is no bootable device found on the system, the system will attempt to boot from the next defined drive
Thanks
Posted on Apr 10, 2011
System Commander 9 fails setup
Have you tried loading System Commander 9 without Linux? the reason I ask is when you run a dual operational systems there tends to be issues that come up with certain programs, there have been to many problems with this type of settup.
Apr 17, 2012 | Computers & Internet
I have installed compaq visual fortran 6.6 on my Laptop with the OS Win7 64bit Ultimate, but it doesnt work properly. The error message is: Microsoft (R) Developer Studio has stopped working.
I have successfully installed PGI visual fortran on my Laptop with the OS Win7 64bit Ultimate,and finally I have found how to build and execute programe on it.You can try PGI visual fortran. v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} p\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} v\:textbox {display:none;}
Aug 16, 2010 | Compaq Visual Fortran Professional Edition...
Drive no longer visible on desktop
If your drive is displayed when you use the
lsusb
or
lsusb -v | less
commands from the command-line, then you might have a problem with the filesystem instead of USB.
Try viewing the boot log with
dmesg | less
looking for clues.
Another thought -- does your device show up in the Disk Utility?
System > Administration > Disk Utility
If it does, then you might need to use
fsck on the particular device named in there that corresponds to your 30 GB drive.
Mar 31, 2010 | NexxTech 1 Bay USB 2.0 External Drive...
How to run digital fortran 6 on windows vista
Here is what I did. Open the DVD (right click and select Open), and then open the X86 folder. Run the Setup.exe file from there and it should install and work fine. I had an error during install near the end, but it seems to have done no harm. I compiled one of my old Fortran apps and it works fine.
Dec 15, 2009 | Compaq Digital Visual Fortran Professional...
Fsck error HELP! HELP ! HELP!
fsck is a file system error check command. Try the root password of nothing, (just the enter key), when ask for the password. Then use the fsck command to repair the file system before rebooting.
fsck - check and repair a Linux file system Try fsck with no options.
SYNOPSIS fsck [ -sACVRTNP ] [ -t fstype ] [filesys ... ] [--] [ fs-specific-options ]
DESCRIPTION fsck is used to check and optionally repair one or more Linux file systems. filesys can be a device name (e.g. /dev/hdc1, /dev/sdb2), a mount point (e.g. /, /usr, /home), or an ext2 label or UUID specifier (e.g. UUID=8868abf6-88c5-4a83-98b8-bfc24057f7bd or LABEL=root). Normally, the fsck program will try to run filesystems on different physical disk drives in parallel to reduce total amount time to check all of the filesystems.
If no filesystems are specified on the command line, and the -A option is not specified, fsck will default to checking filesystems in /etc/fstab serial. This is equivalent to the -As options.
May 27, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Reinstallation problem
Same error here. Compaq Visual Fortran 6.5/6.6.
I think is a problem related to Windows XP SP3.
- Solution:
Re-install Windows XP SP3 (integrated).
Right after installation (no reboot) run the CVF installer. It will work.
Then do normall installation stuff.
If you have Windows XP SP2 you won't have any problem.
Hope it helps.
Couldn't find ANY solution with SP3 installed before CVF installation.
Mar 21, 2009 | Compaq Visual Fortran Professional Edition...
Fatal error LNK1104: cannot open file "console.lib"
I've found these two articles online for you that I thought would help fix your problem.
The most important part from these blogs is this-->that he had placed the Fortran library path in the C++ library path.  Doing so corrected the linker problems I had but I needed to use the $(IFORT_COMPILE11) environmental variable as opposed to the default environmental variable that was used.  So I added:$(IFORT_COMPILER11)libia32
$(IFORT_COMPILER11)libIntel64
to the C++ library paths for the 32 bit and 64 bit configurations respectively.
http://software.intel.com/en-us/forums/intel-visual-fortran-compiler-for-windows/topic/62473/
http://software.intel.com/en-us/forums/intel-visual-fortran-compiler-for-windows/topic/42071/
Please let me know if this helps.
Thank You, Raph30
Jan 23, 2009 | Compaq Visual Fortran Professional Edition...
Problem with Compaq Fortran & Vista
I found the solution fortunately:
It's enough to do a right click on the bottom: "Developer Studio" instead of double click, and select: "Run as Administrator" , then select: "Allow" and so on..
Try it, it works!
Aug 06, 2008 | Compaq Visual Fortran Professional Edition...
Compiling and linking in vista
Vista's not my favorite yet, either.
There could be a million reasons why it won't run, many of which you won't be able to do anything about.
That said, perhaps turning off the UAC security, defining another user as an administrator, and trying to run Fortran might help. At least you won't be running into the whole "run as administrator" nightmare.
But, here's another thought...
If you're machine is powerful enough, maybe you could use Virtual PC or VMWare to build an XP machine where it will run.
(I cut my programming teeth on Fortran, a looong time ago!)
Jun 05, 2008 | Compaq Visual Fortran Professional Edition...
Intel PRO/Wireless 2200BG Network adapter not recognized
Hi
Check Intel PRO/Wireless 2200BG Downloads - http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=1637
Select Linux from and click on go
You can download Intel PRO/Wireless 2200BG version 1.2.0 or 1.1.0
Installing/updating Intel PRO/Wireless version 1.2.0 driver for Linux
- To extract the archive file, type from a console: tar xzvf ipw2200_linux_1_2_0.tgz
- To install the driver the following is needed:
1. Linux with a 2.6.8+ kernel. See README.ipw2200 for information on
specific options required to be enabled in the kernel.
2. Wireless Extensions (v16) and Tools (v27-pre23) if not included in
your distribution
3. The driver (ipw2200-1.2.0.tgz)
4. The binary firmware image (ipw2200-fw-3.0.tgz)
5. For instructions on how to build and use the driver, please see the INSTALL document in the ./intel_ipw2200_120/ directory.
More info http://ipw2200.sourceforge.net
Regards
Mike
Oct 01, 2007 | Intel PRO/Wireless 2200BG 802.11g/b
Intel Fortran Composer Xe 2013 for Linux - Complete package 1 Year Support - 1 developer - Edu - DVD - Linux Logo
73 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
