Question about Euro-Pro Shark NV352 Navigator Lift Away - NV352
I can't remove the pet brush attachment on my Shark Navigator Life Away NV35226
I just used it for the first time, and now I can't get it off to use it in floor mode again!
  • Beth Oldfield Jul 01, 2013
    Did you ever figure this out? I'm having the same problem.
  • Euro-Pro Master
  • 18,408 Answers
5 Suggested Answers
SOURCE: shark navigator n22
What I tried and it worked for me is to losen the hose slightly from where it connects to the long plastic tube on the side to allow the little hole to show. What that does is to lessen the suction power a little since the problem is that the suction is too powerful on the carpet and the roller freezes.
Posted on May 22, 2010
heatman101
  • 43501 Answers
SOURCE: Using the Shark steam cleaner on floor with unsealed grout
Yeah it will work fine...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Posted on Sep 24, 2010
  • 360 Answers
SOURCE: Shark SV736R motorized brush won't rotate
The 2 metal pins of the motorized brush are not in contact with the vacuum cleaner. or the Motorized brush is clogged up. You have mentioned that it is cleaned, but still give a thorough inspection. For the metal pins, firmly insert the motorized brush into the air-intake nozzle. This will connect the motorized nozzle to the unit power supply.
Posted on Oct 22, 2011
joan413
SOURCE: my brush won't turn on
I had the same problem, I took out the brush and found that dog hair had worked its way under the gear and around the axle. I had to get a small pair of scissors and cut it out and pull it out with tweezers until it turned freely again.
Posted on Aug 25, 2012
Filter ordered is too small and splits after two uses. What size to order?
Shark Professional Pet Navigator Lift Away Bagless Vacuum
Does it need a the filter since it is Bagless Vacuum??
Dec 06, 2015 | Shark Professional Pet Navigator Lift Away...
Why is the pet hair power brush not spinning?
Amazon.com: Customer Discussions: Shark pet hair & power brush
www.amazon.com/...pet-hair-power-brush/.../1?_...
Amazon.com, Inc.Jun 24, 2012 - I needed the belt and couldn't find one so I used a black heavy ponytail band in its place and it works, I don't know how long it will last, but until I ...
My shark pet hair power brush tool will not spin - Fixya
www.fixya.com/.../t13829250-shark_pet_hair_power_brush_tool_will_n...
Jul 30, 2012 - Posted on Jul 05, 2015.
Sep 21, 2015 | Shark Rocket Professional Self-Propelled...
Ihavea shark nv lift-away pro the brush dont spin an the light dont light up it caught a floor vent wean this started . is ther a reseat if so ware is it
Sounds like you broke the brush belt. Easy to replace and most come with a replacement attached somewhere on the vacuum. The light is probably just burned out from the impact
Nov 29, 2014 | Shark Navigator Lift-Away Professional...
Shark navigator making strange noise. Still have suction, doesn't make noise when beater bar not moving. What could be the problem?
HI, it's Jim from Crucial Vacuum!
If your Shark Navigator vacuum is only making a strange noise when the brush roll is turning then the two things to consider and examine would be the brush roll itself as well as the belt.
First off lets look at the brush roll itself. Right off the bat is there any noticeable debris caught in it? You're mainly looking for long carpet fibers, or even strands of hair? If so try using a scissor to cut the blockage away. Then, manually rotate the brush roll to uncover further clogs. When examining your brush roll take note of the condition of the bristles. Are they loose? If so this would be a good time to change your brush roll entirely. There should be two screws holding the plate onto your Shark Navigator. Use a screw driver to remove these screws to gain access to the brush roll and belt.
The second part to check would be your Shark Navigator's belt. With use the belt will stretch out, lessening the tension on the brush roll. Lesser tension diminishes the brush roller's turn rate and speed. So if your belt feels loose as well replace that. A general rule would be that you're going to want to replace your belt about every 6 months. And if your belt is really loose this could be causing a noise when your brush roll is active.
You can purchase your replacement parts for your Shark Navigator direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=Shark+Navigator&limit=all
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Nov 26, 2014 | Shark Vacuums
Shark navigator uv440 pet brush won't roll
The hair in the bearings. I take pair of needel nose peirs. Its hard,but it only i found
Jul 14, 2014 | Shark Helmet NV22L Shark Navigator Upright...
Shark navigator uv400 - the brush won't move. cleaned out hair, but still doesn't move even when it is off and I try to rotate it manually
Sorry but Shark products fail after a very short life typically and there are no parts for them. They are disposable. Do yourself a favor and don't waste money on another one.
Oct 20, 2013 | Shark Navigator gray canister bagless pet...
Euro-Pro Shark NV352 Navigator Lift Away - NV352 Logo
228 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
