Question about Kenmore Washing Machines
I have a Kenmore Advantage Washer, model # 110.92582100 that will not turn on. I have checked the plug and the house fuse breaker. The knob is turned to the start of the cycle. Any ideas?
  • Kenmore Master
  • 17,130 Answers
If there is power to the timer and still it does not move on, check the door switch . If not there is fault in the program controller timer unit. Please check the cost and estimate.
Posted on Jan 18, 2013
canbruce75
  • 1776 Answers
SOURCE: Kenmore Washer, Loose Timer Knob
There should be a spring clip that holds the timer knob on. It or the timer knob may need replaced. Here is a picture of the timer knob and the spring clip. Sure hope this helps and best wishes.
Posted on Jul 24, 2009
SOURCE: Kenmore model 417.441525400 rinse cylce problem
http://www.applianceaid.com/frigidaire_frontload_washer5.html
I cannot guarantee that this will help, but I was able to fix my front loading Kenmore Model 417.44052401 only because of helpful people in internet forums.
First of all, there is an extremely helpful troubleshooting guide on applianceaide.com. It describes Frigidaire Washers, but Kenmore is made by Frigidaire, so it will work. You can find it here:
Anyway, here's my story:
Wife washed some clothes, but when it was time to drain and spin, nothing but a buzzing sound came from the machine. She got worried that something would burn up, and cancelled the wash cycle. She had to take the wet soapy clothes to her mom's to rewash.
I drained all the water in the tub out with a small cup.
Then I got on the internet and found the aforementioned help guide on applianceaid.com. I ran the diagnostic, and it indicated Error 31, which was the pressure sensor reporting that there wasn't enough pressure.
I had also read on another forum where, someone had a very similar problem, and he found something crazy like a superhero arm in the impeller in his pump. He removed the rubber boot that connects several of the hoses to the pump, and voila, he found said object and some loose change.
Earlier, my Wife had told me that she thought the underwire from a bra must be stuck in the machine somewhere because one of them came out torn and missing the underwire.
So, I disconnected the rubber boot, just as the other guy had done, and sure enough, there was the metal underwire, and about 10 dimes & pennies. Apparently, the underwire was stuck in the impeller and would not allow it to spin so that it could **** the water into the pump and send it down the drain.
Disassembling it was the easy part.
It took my wife and I about an hour and a half just to get the "boot" hooked back up to two hoses and a tube. My big clumsy hands could not get the job done, but my wife's small hands were able to get the hoses reconnected while I held the hose clamps open with a pair of vice grips.
It was not a complicated job at all in theory, but it was hard to reconnect everything. But, we got it done and didn't have to spend a dime. In fact, we found about 35 cents or so. LOL. It cost me about 4 hours of my time, but it was well worth it.
After everything was reconnected and reassembled, I ran the diagnostics again, and this time, at stage 9, where it had previously failed, it passed with flying colors! Yay!
I just finished washing a load of towels that we dirtied when we opened the "boot" and all the water I could not scoop out earlier came rushing out. Worked with no problems.
Hope this helps someone.
Posted on Aug 21, 2009
  • 1937 Answers
SOURCE: Kenmore Elite Washer Does Not Spin
This a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.20992991
and you'll see a list of major sub-components with diagrams and parts.
The brake on these washers is driven by the clutch on top of the transmission.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
This is a Whirlpool PDF on how these washers operate. It has a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
If the washer drains the problem is likely in the transmission.
We had the same problem:
If you lift the lid, put it down again or stopping and starting the cycle knob, and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
Apparently, by opening and closing the lid, or stopping and starting the washer torque from the motor starting throws the cams into the right gears so that the washer will spin.
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Posted on Nov 16, 2009
SOURCE: Model 417.43042200 Kenmore Washer
I HAVE A KENMORE FRONT LOADER WASHER. MODEL 41743042200 AND IT MAKES A NOISE WHEN IN THE SPIN CYCLE, THIS ONLY HAPPENS WHEN SPINNING. CAN SOMEONE HELP
Posted on May 26, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore tumble action washer problem
It appears your timer has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
My kenmore front load HE2 plus wont turn on.
Check that it is plugged in.
Check that the breaker is on on the breaker box or that the fuse is still good.
See if there is a seperate circuit control switch for the washer outlet.
Make sure the door is fully closed.
Check the door close sensor or switch is operational.
Aug 16, 2010 | Kenmore HE2 Plus Front Load Washer
My washer stopped in the middle- and wont turn back on- full of water right before the spin cycle! I have checked the breaker, unplugged it, pulled the knob and tried to recycle it- NOTHING! it is only 7...
It doesn't work at all If your washer doesn't seem to work at all, check these: No power Lid switch No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Jan 19, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a older model heavy duty kenmore washer after it filled up with water it just stopped on its own no nosy no smell I pulled on the nob to restart it but no luck I then unplugged the unit
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Without knowing the model number etc. I can only offer a couple of suggestions.
1. Try to set the knob to another position such as spin and re-start.
If it starts to spin and / or drain, the problem could be with the timer not advancing.
2. Is it possible that the washer isn't getting power? Check the house fuse box / circuit breaker to be sure, or plug a lamp into the outlet.
moz-screenshot.pngmoz-screenshot-1.pngmoz-screenshot-2.pngMost of the other Whirlpool / Kenmore troubleshooting answers for the motor not running point to the motor or its' connections itself.
Oct 13, 2009 | Kenmore Washing Machines
Washer won't turn on
Jun 19, 2009 | Kenmore 43142 Front Load Washer
Washer will not turn on. The knob moves but nothing happens when I turn it on. I've checked the breaker, the water, the plug/outlet, and hoses. Everything looks fine. But nothing happens.
No power
Lid switch
May 05, 2009 | Whirlpool LSR9434PQ Top Load Washer
Kenmore Elite HE3 front load dryer no power
Yes. Remove the kickplate and check the continuity of the thermal fuse located on the blower housing.
Feb 23, 2009 | Kenmore Dryers
Kenmore front load washer won't start
bad start switch, sometimes the contacts in the start switch will arc and burn causing starting up problems.
Feb 10, 2009 | Kenmore 43142 Front Load Washer
Kenmore 60 series washer
Dec 07, 2007 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
Sal De
fordexpert
Whirlpool
Whirlpool
