Question about DeLonghi Magnifica 3300 Espresso Machine
When i press the preground button in my Delonghi Magnifica 3300 ,the brew group move up and just when start to make coffee -the ligt for dregdraw full blinking?
Then trow the preground coffee and remain to blink lamp for dregdraw full and lamp for peground coffee. After that when press button for preground coffee it stop blinking ,even and for dregdraw and can make normal coffee wich is grind by machine.. Any advices,please???
  • nikolay nikolov Jan 18, 2013
    sorry timbo984, but this doesn't work. I did this voperation with lubricant,but steel give me red lamp for used coffee full! The normal coffee by coffee beans is no problem-it's happen aways!
    that's the situation when try to make preground coffee and when the operation end. Then it stay like this red light,and when press preground button again-then i can make ground coffee! :)
3 Suggested Answers
  • 3 Answers
SOURCE: need to replace steam valve on delonghi magnifica coffee machine
the steam valve will pop off it comes straight out
Posted on Dec 05, 2009
SOURCE: delonghi magnifica coffee machine...infuser jammed
Remove base plate and turn pulley clockwise (probably for several minutes) until infuser arm returns to vertical position and the infuser itself drops to the low position. You should here a click when it reaches this point. The infuser can then be removed as normal.
Posted on May 03, 2010
Squeaking delonghi magnifica
Take it apart and clean it properly plug use sileco to lubricate for a longer use water heat coffee all of these make machine to fail
Keep service as importance
Jul 09, 2014 | DeLonghi Magnifica 3300 Espresso Machine
Delonghi Magnifica 3300 doesn't make coffee, only wet grounds and water in the grounds container, everything else seems normal
Hi JB, not sure if you've junked your 3300 machine by now or had the problem fixed already. Nevertheless, allow me to share with owners of DeLonghi Magnifica Espresso machines who encounter similar problem to yours. Incidentally, mine is a Delonghi Magnifica 3200 which is very much the same as the 3300. Firstly, try to ascertain if the pump is working normally. When the machine is ready to brew coffee, turn ON the steam/hot water knob and see if it pumps normally and for more than 30secs at least. My machine could pump for short durations between 5secs to 20secs max before the water light came on. I checked the flow meter connection but is all seemed well. I noticed signs of water leak (dried up chalky water stains) where the steam wand exits the control panel. Upon opening up the control panel, I noticed a larger patch of dried up water stains on the wand valve assembly. Bought a set of steam wand assembly replacement and to replace the leaking one. It's been some six month now and I'm enjoying my daily cuppa again. Btw, my Delonghi Magnifica 3200 has been serving me well for 10 years! Apart from the steam wand replacement and a faulty micro-switch, I only had to carry out the usual descaling and replacing worn out O-rings.
Feb 10, 2013 | DeLonghi Magnifica 3300 Espresso Machine
I have a Magnifica. The descale red flashing light won't reset after going through the descaling procceedure.
I have the same problem with my Delonghi Magnifica, so maybe there is a glitch in the machine..
Aug 20, 2011 | DeLonghi Magnifica 3300 Espresso Machine
The brew group is stuck and will not come out
I hope one of this two solutions solve your problem.
1- The brew group is out of place. Turn the machine on. Close the service door.
The brew group is automatically placed in the correct position.
2-Coffee grounds drawer is inserted. Remove the dregdrawer first, then the brew
group.
Jan 15, 2011 | Saeco Odea Giro Plus Coffee Maker
Descaling coffee makes esam4200
100ml of descaler per tank of water. then they say 1 rinse, but I have to rinse 5 times to not taste the descaler anymore.
Jul 21, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
DeLonghi Magnifica 3300 Espresso Machine Logo
104 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
