Question about Haier CPN11XCJ 11,000 BTU Portable Air Conditioner w/Dehumidifier
I am using the heating unit and water keeps building up in the pan and I have to keep turning it off and draining it
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 37 Answers
Your air and heat maybe coming on together
Posted on Jan 18, 2013
2 Suggested Answers
  • 4736 Answers
SOURCE: 2 years old only used
There are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have a manually
controlled unit.set the knob on maximum.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder
level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I really hope this helps you to troubleshoot and solve the problem.
Posted on Jul 20, 2011
How to keep water from building up in my air conditioning drain pan
this indicates that the drain is blocked by gunk either in the drain tray outlet or in the drain pipe outside
it can be washed out or blown out
it could be the outside hose because things like mud wasps find it a good place to build nests
Sep 01, 2015 | Heating & Cooling
I have a Maytag fridge model # PSB2151GRW without the ice maker , there is a steady build up of ice on the bottom shelf of the freezer and a puddle of water on the floor ...
Ok so here comes the fun part. Unplug the frig! Two people due this much faster. Remove all food and shelves from freezer. Get ya some bath towels place them on the floor and some on the bottom of the freezer. Take 2 coffee cups and heat them for 3 minutes. Remove them and remember they are hot! Pour a cup of hot water where the ice is and let the towel soak up any water. Now fill that up and heat for 2 minutes now. Pour the other cup on the ice and keep rotating until the ice is gone you will see the drain hole which is going to have ice down that tube so keep pouring hot water until the water drains into the drain pan below. If you can't clear the drain tube use compressed air or a turkey baster can help out too. Wipe down the inside of freezer walls to eliminate the condensation now your ready to party... Don't forget to plug the unit back in the outlet!
Sep 26, 2011 | Refrigerators
MY GE REFRIGERATOR MODEL TFHW24RRA HAS ICE BIULD UP ON THE FREEZER COILS
the freezer is not going into the defrost cycle properly. first completely defrost the freezer compartment. to do this you first remove all the food from the freezer compartment then unplug the refrigerator from the wall. next put a large pan of very warm water in to the freezer and close the door. the heat from the hot water should melt the ice off the freezer coils. if the drain is working the water should go down the little drain into the catch pan in the bottom of the unit( way down underneath next to the floor) if it doesn't drain down use towels to soak up the water then find the little hose and drain that go to the bottom and clean it out. if the drain was blocked that could cause the ice build up. If the drain is not blocked then the defrost timer or the defrost coil is not working. the defrost timer is a small unit usually located behind the kick plate at the bottom of the fridge or sometimes at the back behind the paper shroud. this is the manual advance knob and should allow you turn the knob until the defrost position is reached. you should hear a little click as it reaches the defrost position. make a mark on the timer knob with a magic marker and then plug the refrigerator back in. over the next 4 hours you should see the knob turn (like a really slow moving clock). after you plug the refrigerator back in watch for ice build up on the coils. If it starts to build up again you will need to figure out if it is the defrost coil or the defrost timer that is not working. the manual defrost technique will keep the unit in service but is a total pain. eventually you will need to replace the defrost coil or once in a while it is the defrost timer that doesn't work. this is not easy even for the repair man but it can be done. first locate the defrost coil(a long thick wire looking thing) and check for continuity. if you don't have a multi meter and a basic understanding of the repair technique you should get professional help. to keep the refrigerator running and keep the ice off the coils you will need to repeat the defrost procedure from time to time. this is not that easy to do but will keep your refrigerator running.
May 09, 2011 | Refrigerators
Water building up in drain pan.
Is this a split unit? The drain line is probably clogged. If you have a shop vac you can use it on the drain line outside and clear the clog or maybe use something like drano. A little Clorox added to the drain pan every now and then will help keep the drain line from getting clogged. (Just a couple tablespoons)
Sep 01, 2010 | Heating & Cooling
Water is leaking out of bottom of unit
It sounds like you have a defrost drain problem.
This refrigerator goes through a defrost cycle every 8 - 10 hours. The water from the defrost cycle is suppose to go down a drain to a pan and evaporate. It sounds like the drain is plugged. Try these steps to fix the problem.
- First turn the refrigerator off or unplug the unit.
- Open the freezer and remove the lower basket and lower shelf there may be ice build up so they are frozen in, you might need to melt the ice with hot water.
- Look in the back bottom of the freezer and you will see a few horizontal slots in the back panel, just below this will be a small hole, it will most likely be ice covered and not visible.
- If the hole for the water is not visible you may need to remove the panel behind the shelves to see it
- Use hot water to melt the ice and towels to clean up the mess.
DO NOT USE ANYTHING SHARP OR "CHISEL". You can damage the coils, use heat and hot water only, if you use a blow dryer or heat be careful not to heat up the side walls as they will melt.
- Once the ice is clear you will see a hole in the bottom pan about the size of a dime. Use the turkey baster and flush hot water in the hole until it flows again.
- While you are doing all this keep towels around the perimeter of the refrigerator to soak up any water that flows out the bottom, leave the towels there for a day or so to make sure you get it all up, a little leak for a few hours after the repair would be normal
- Once the drain tube is clear, you can put it back together and turn it back on
Apr 18, 2010 | GE GSS22SGM Side by Side Refrigerator
Kenmore Fridge: 44103 side by side: I keep finding a
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Sep 15, 2009 | Kenmore 44103 Side by Side Refrigerator
Defrost tube has frozen and clogged. Is there a
You can try a hair drier or warm water. I would use a hair drier first.
Aug 31, 2009 | Refrigerators
Water collecting in freezer bottom
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...If you need any further assistance please feel free to comment again. good luck! P.s Please don't forget to rate my solution thanks! Mike.
Aug 02, 2009 | Jenn-Air Refrigerators
LG Bottom Freezer Frost Issue
It sounds like your defrost controller has gone bad. I have an LFC25760 and had ice build up in the bottom of the freezer such that water would start leaking onto the floor. The ice build up in the bottom of the freezer was due to a failing/bad defrost controller. Behind the back white wall in the freezer compartment exists the cooling fins along with a heating element underneath. Due to moisture that comes into the freezer from opening it, frost/ice builds up on the cooling fins. Thus the defrost controller turns on the heating element to melt the ice/frost off of the fins which then drips into a metal pan which channels the water to a drain hole which drops into the drip pan underneath the fridge next to the fan. The problem is that the defrost controller doesn't keep the heating element on long enough or the cooling cycle comes on too soon thereby freezing the water and plugging up the drain. I had my defrost controller replaced (just outside the warranty period!) and it worked for about 1-month and then same thing happened again. Instead of paying for another defrost controller that would probably not work 100% my serviceman used the old paper-clip trick. He took a paper clip, stretched it out and then wrapped one end around the heating element and placed the other end into the drain hole. Thus when the heating element comes on the paper clip keeps the drain hole warm/hot and prevents the water from freezing. It has been 9 months since this fix and I haven't had any ice pooling in bottom of the freezer.
Jun 22, 2009 | LG LRFD25850 French Door Refrigerator
Very thick ice collects in bottom of freezer
the drain pipe you cleaned out has a p-trap that holds water. after awhile this trap will build up sludge and possibly freeze up. i recomend defrosting the drain pan again and try some way to forcfully flush hot water thru the drain. I use a turkey baster filled with water to do this. if the drain continues to freeze you may need to install a heat trap to keep drain from freezing.
a heat trap is just a piece of 10-12 guage solid copper wire with about 3 inches in the drain and the other end wrapped around the defrost heater which is the BLACK rod attached to the bottom of the evaporator coil in the freezer compartment. if you need any further assistance just let me know Peyton
Jan 27, 2009 | Bosch Freezers
Haier CPN11XCJ 11,000 BTU Portable Air Conditioner w/Dehumidifier Logo
70 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
