Question about HP Compaq ProLiant ML350 G5 Server
Smart array 5300 PCI-X 64Bit/66MHz in ML350 G5 server.
The system ECC rom reports that this card is unsupported in ML350 G5 Proliant Server. ... I just bought heavy U320-disk-enclosure and i cannot use it? The fug?
I tried to install the card another slot, but no deal. It wont accept it. All others it will. AArgh. Except i dont have any other raid-controllers using old U320 scsi :(
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 181 Answers
It will be a controller card problem / SA5300 is 100% compitable
Posted on Oct 20, 2013
Yazz226
  • 497 Answers
SOURCE: Trying to install Windows 2003 on to ML350 G3 server
http://www.downloadatoz.com/driver/item_199703.html
try this
Have a nice day!
tc
Posted on Jun 13, 2008
  • 48 Answers
SOURCE: HP Proliant ML350 G5 wont boot ,just spining.
The G5 Series is fairly new, if you're within warranty, call 1800-okCompaq.
Could be a bad cable, a bad monitor, or bad computer hardware. Any display at all or any beep codes?
On the back, the ml350 G5 will likely have an additional Network interface jack-- this may be labeled ILO. The ILO network connect allows you to use another PC on the same network to access this system (like a remote control via VNC or RDP) even if it won't power up--literally. Inside the ILO page, (you'll need the IP address of the ILO, the default account is administrator, and the default password is listed ona paper tag attached in the rear or on a sticker. If you can get into ILO via web browser: https://ipddress of ilo, you can check the Integrated log, which can shed some light on any failures.
Posted on Mar 20, 2009
ted1430
  • 339 Answers
SOURCE: hp proliant ml350 g5 vga drivers for windows 2000 professional
Download the latest Proliant Support Pack from HP's web site. This will update the drivers for everything on the server at once.
Just go to hp.com and click the link for "Support & Drivers" at the top, then click the radio button to download drivers and enter ML350 into the text box. Select the G5 from the list and then select your OS. The PSP will be near the bottom of the page. The display driver will be close to the top if you just want to update it.
Posted on Jul 12, 2009
ted1430
  • 339 Answers
SOURCE: Prolinat ML350 G2 WONT BOOT UP
You have apparently attempted to attach a tape drive or other similar device to a SCSI RAID controller. You will need to get a separate SE SCSI HBA instead. These are pretty cheap, usually just over $100 list from HP.
If you haven't attached anything new, then you should check your cables first and if that doesn't help I would suspect a bad RAID controller.
  • 42 Answers
SOURCE: Dell RAID controller in HP server?
This particular device will require drivers for the Operating System to use. Also the hard disk drives will have to be installed an initialized outside the Operating System first before use. This is usually during startup after the system BIOS.
The exact steps can be found on the RAID card manufacturer's web site.
Posted on Feb 23, 2010
Ml350 g5
Most current high-performance graphics cards (GPUs) are PCI Express (PCIe) cards. The others use the "legacy" standard known as AGP.
ML350 G5 has PCIe slots, but they are x4 or at most x8 variety: most high-performance GPUs require a PCIe x16 slot. Of course, PCIe cards are supposed to work with lower-bandwidth slots too, but that limits the performance of the card. I would not expect high-performance GPU manufacturers to do much testing with limited-performance configurations, so you would easily find yourself in the land of "unsupported".
PCI-X is a faster/wider version of PCI for servers: I don't know of any common high-performance graphics card that would use a PCI-X slot.
PCI-X is backwards compatible with plain old PCI, but I would not call any PCI graphics card "high performance" today.
Most high-performance GPUs also require more current than a standard PCIe slot can supply. That necessitates an extra power feed from the PSU to the card, but such a power feed is not often available in server-style machines.
Trying to convert a rack-mount server into a graphics monster machine is like trying to adapt a Formula-1 car for a gravel-road rally: different roles call for different designs.
Jan 23, 2014 | Computers & Internet
I need Network card (LAN) driver for HP Proliant ML350 5G server.
Go the website of HP, chose for the support and drivers - lookout for drivers and software - enter your product name i.e HP Proliant ML350 5G Server and click on search.
You will get the list, select your product. Select the operating system you are using on your server - then choose the driver type - click suitable, from the list of drivers and download it.
Apr 23, 2013 | HP ProLiant ML350 G5 Server
Server won't start HP ML350 G5
Reseat the drives, but DO NOT swap slots. Keep exact, in case of RAID configuration.
Use the Smartstart disc. It may show you the current array config.
Oct 23, 2012 | HP ProLiant ML150 G5 Server
Server won't start
I would first try reseating (removing and putting back) the SCSI card. If it is not able to reseat (built into the motherboard) you can always try to get into the BIOS diagnostic and run a system diag on the machine.
regards,
Mike
Oct 23, 2012 | HP Compaq ProLiant ML350 G5 Server
My HP ProLiant ML350 G5 failed to boot to Windows. After showing Windows 2003 Server, blank screen comes up
There was a critical HP ProLiant ML350 G5 ROM BIO upgrade dated on 17 Aug 2010.
Please bookmark the bio update link HERE for reference.
Check your monitor Hz and display resolution setting.
Did you change any video driver or resolution before reboot?
If all else fail then swap in a simple S-VGA card and let Windows 2003 to sort out the 640X480 display mode.
Jan 05, 2011 | HP Compaq ProLiant ML350 G5 Server
I want to install windows 2003 on compaq proliant ML350 G3,but I have not a disk called server guide.please help me.
1. turn the server on, when you see the smart array controller posting
hit f8 to enter the controller settings, here create the array (1, 5,0)
2. insert the windows cd and follow the normal installation procedure
or download the smart start cd from here for a guided installation
with SSCD just insert the cd and follow the directions
Aug 30, 2010 | HP Compaq ProLiant ML350 G3 Server
Install an operating system (Windows Server 2008) on a used HP
Hi, Have you checked the BIOS? Check the Backup ROM option (change to Backup ROM)
If you haven't change the Boot Order: Go into RSBU and change the Order.
Note: If you have Scsi you do not need to do any additional things rather than this. If your product has a Smart Array Controller, during the POST, press F8 during the Smart Array controller ID to access the configuration utility, delete and re-create the disk array to wipe out whatever might be on the disks.
Feel free to contact again. Let me know what happened.
Thanks for contacting Fixya! (Please rate the answer as well)
Jun 25, 2010 | HP Compaq ProLiant ML350 G3 Server
Problem with harddrive
It could be because the disk is not a part of any array. Log into the server and go to the array controller utility from HP and check for any unassigned disks. It will be displayed there rather than the diskmanagement window.
Feb 01, 2010 | HP Compaq ProLiant ML350 G3 Server
I can´t use a serial ata disk in a proliant 350
I know ATA disks are cheaper , but they don't last as long or are less reliable.
I do not recommend mixing SCSI and ATA .
Use one or the other , not both.
Do not try , unless your server is non critical.
If it is non critical , why bother with server , a PC will do as well.
Thanks
David
May 14, 2008 | HP Compaq ProLiant DL380 G4 Server
HP Compaq ProLiant ML350 G5 Server Logo
145 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
