Question about Samsung OM-WF419AAW - OWNERS MANUAL
Where is the drain pump on a samsung wf419aaw front loader
4 Suggested Answers
  • 330 Answers
SOURCE: My samsung front loader washer wont drain. I
there should be a kick plate at the bottom of the front panel if not some of the new models you have to remove the front panel to get to it this is probably the case with your machine alternativley you can follow the drain hose back to the pump lean the machine back and look underneath.
Posted on Jan 13, 2011
  • 6277 Answers
SOURCE: I have a front loader Washer Model P1203J. The
That's a good indication as the drain motor is independant of the main motor and belt.
Quick way to see/confirm- REMOVE POWER FROM THE MACHINE AND HAVE THE BACK REMOVED.
Belts are not expensive- sorry I do not know how much yours would cost- and are easy to be changed by a competent person:-
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
If it turns out not to be the belt but the motor, it is false economy to just have the brushes changed although financially very attractive. Experience of others is that the brushes may only last months unless, that is, the motor is totally refurbished at the same time. It depends on how old the motor is and how much wear the commutator has had. New motors are not cheap, though. Ours for a Bosch cost GBP250- but it's your choice!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Aug 01, 2011
KevinWhite
  • 1902 Answers
SOURCE: where is the drain filter on a samsung front
Hello & Welcome to FixYa
ND error in your Front Load washer indicates no drain issue. To start with check the drain hose for any clogs and try cleaning it, then check restriction in drain pump assembly or loose wire at the pump, located inside the bottom front access panel of the unit. Please get back to me if you have any other questions.
Kevin
Posted on Oct 08, 2011
Cleaning filter on Samsung front loader
Hi! First I'm not a Samsung tech. But I am an equipment tech (retired) but more important I (sorry) WE, have a Samsung front loader too! I was wondering the same question. Where is the filter? We have 5 dogs and 2 cats so I'm pulling a lot of hair from the lower part of the door rubber (there is a small drain hole where stuff collects) But your question prompted me to really look for this filter. The following is from the manual:
* user manual WF45K6500A / WF45K6200A Page 53 (English)
1. Turn off washer, and then unplug power cord.
2. Drain the remaining water inside the drum. See the "Emergency drain" section on page 49
3. Gently press the top area of the filter cover to open (it's located at the lower left front of washer. ukeboy57) C
4. Turn the pump filter knob (A) to the left and drain off remaining water.
5.Clean the pump filter using a soft brush. Make sure the drain pump propeller inside the filter is unclogged.
6. Reinsert the pump filter, and then turn the filter knob to the right.
7. Close the filter cover.
Note; If the pump filter is clogged, the "5C" information code appears on the washer display screen.
* Final; I haven't done this yet though we had this machine for a month now and I suspect it's filthy. Warning though, the emergency draining looks messy so have the pan and towels ready. (and I just got finished tiling the laundry room floor too!)
Aloha, ukeboy57
Jan 04, 2018 | Miscellaneous
My samsung front loader washing machine is not pumping or spinning says "error ND" checked pump all clear still nothing
on my kenmore machine nd means the drain filter is clogged. open the cover, drain water completely, remove and clean the filter, replace filter, tighten and close cover. hope this works for you. if not , at least your drain filter will be cleaned and you can eliminate it as the problem.
Feb 03, 2013 | Washing Machines
bottom right coner under the door remover plastic cover trust me its there
Jan 17, 2013 | Samsung OM-WF419AAW - OWNERS MANUAL
Where is the drain filter on a samsung front loader? I am getting a nd error when I removed the hose from the pump, water came gushing out of the pump. Before I removed the hose, I made sure that the...
Kevin
Oct 04, 2011 | Samsung WF328AA Front Load Washer
Error code is de what can i do?
Means Drainage Error. You need to clear out the drain pump. Depends if its a top loader or front loader. If front then if you should be able to access the pump from the front bottom by unscrewing and removing the filter. If not then you will need to tilt the machine back as far as you can so you can access the underneath. You will see the small drain pump. Have a basin ready to catch any water that comes out when remove the pump which is only held in by 1 or 2 screws and twisted out or pulled out. If it is clear then try removing the pipe that goes from the pump to the base of the tub. Hope this helps
Apr 06, 2011 | Samsung Washing Machines
My samsung front loader washer wont drain. I can't find the drain hole. Is it in the drum?
Jan 13, 2011 | Samsung WF203ANW Front Load Washer
My samsung vrt front loader will not drain or spin and showing nd code
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 28, 2010 | Samsung Washing Machines
Getting error 5e WF7708 samsung front loader. Have cleaned all filters nothing appears to be blocked. But it will not finish a cycle.
A 5E code means that the drain pump is iether clogged, with lint, impeller damage, drain hose clogged, or a loose connection on the pump connectors
Jan 06, 2010 | Samsung Washing Machines
I need a new front loader washer. Which brand do you like? Electrolux EIFLW55HIW Bosch WFV5400UC Samsung WF419AAw Thanks!
These are all very good now, but I still prefer either maytag or LG for long time use without problems and ease of maintenance.
Nov 11, 2009 | Bosch WFMC 6400 Front Load Washer
Samsung OM-WF419AAW - OWNERS MANUAL Logo
52 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
