Question about Refrigerators
My refridgerator isn't cooling I changed the starter relay(thought that was problem) but it still isn't running. I check compressor gets warm but not running
I've checked what I can but can't seem to figure it out
Unfortunately it sounds like your compressor is on its way out. In some cases you can get what's called a "hard start kit" or a "3-1" (same thing) to help force it to run, that does sometimes get you more life out of the compressor. MY GUTT FEELING: The reason it is warm is because it is trying to run but can't, do to a broken winding inside the motor or a piston or valve is jammed or bent. The reason forcing it works sometimes is because it actually breaks pieces off when it is forced so hard. The divit or scratch left behind may continue to break down over time resulting in blockage and seezing, or it may just break a small piece loose and run for years. It is a gamble though. Good luck with it
Posted on Jan 17, 2013
Master_Tech
  • 770 Answers
SOURCE: not cooling
The clicking you are hearing is your overload on your start system sounds like your compresser start ststem is out..or your compresser is locked up the only way to tell is to ohm out the compresser idf you dont have a meter you can install a start kit like a Supco Pro41 or a RCO410 or a factory replacement and see if it starts up the compresser.. Have you cleaned the condenser at all ??? although this will not fix the compresser it can be a cause of overheating..The part Number you need is a 2188831 for the factory replacemenet ($22.56)the supco parts part number SU RCO410 ($15.00) the Pro41 is part #
SU PRO41 ($17.97) you can get them at your local parts house they are all easy to change or if you dont have a parts house close you can oder it on the web at www.apdepot.com Hope this fixes ya
Posted on Feb 17, 2008
22yooper
  • 828 Answers
SOURCE: Kitchenaid Superba compressor
The compressor relay is located on the compressor under a cover. Before you go to the compressor I would check for other problems that you can see and hear. If the compressor is running there is nothing wrong with its relay.
1. Check the condenser and make sure it is clear and free of dust.
2. If the compressor is cool or cold check for a bad temperature control.
3. Check the freezer compartment for frost on back wall.
Posted on May 30, 2008
dididsaythat
  • 291 Answers
SOURCE: frigerator not cooling not cooling at all
make and model # was there frost on the evap.?
Posted on Sep 12, 2007
  • 163 Answers
SOURCE: GE refrigerator TDX11SNYAWH.
check your defrost timer and see if it is stuck in defrost.
Posted on Mar 07, 2009
jumptrout51
  • 3361 Answers
SOURCE: Kitchen Aid Superba side-by-side not cooling
Replace the compressor start relay.
Posted on Mar 10, 2009
My GE bottom Freezer Fridge model pfse5njwdss not cooling at all. both fridge and freezer are not cooling, the lights are on and a very low sound exists, but not cooling. As if its not on.
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. The relay is a small usually black cube shaped electrical part plugged into the compressor or wired to it nearby. It may appear burnt or rattle when shaken if it's bad. The two connections should show continuity with an amp meter. If it's good then it's most likely the compressor causing the problem.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Aug 30, 2011 | GE Refrigerators
Freezer and refridgerator are warm. Fans are running but compressor is not.
Is the compressor hot? Do you hear a clicking sound every minute or so? If affirmative, you probably need a new starting relay. It sits in a little box welded to the compressor. If the compressor is cold, you need to check if you have 120 V going to it. There is also a thermal switch (overload) near the relay; that could be open. Sometimes the thermal switch (when old) fails to reset (make contact) when the compressor cools down. Another thing to check is the control board which is located in the rear of the refrigerator. You need to remove a cover to get to it. If you take the board out, and you see one of the solder joints melted, that would be your answer. It can be fixed by cleaning and resoldering it. I always run a little wire from that point to the compressor terminal joint to keep the path cool. Look at it close and you'll see what I am talking about.
Aug 10, 2011 | GE Profile Arctica Stainless Steel Top...
Refridgerator Compressor running does not cool! Freeser fan not blowing warm air!
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 26, 2011 | Westinghouse Refrigerators
Refridgerator cycles on then off and not cooling. is it the relay or the motherboard?
heatman101
Jul 16, 2011 | Refrigerators
My Whirlpool Imperial refrigerator isn't getting cold enough. I thought I should clean the coils, but there aren't any on the back. I did clean the vent in the front and haven't seen any change...
heatman101
Freezer and refrigerator not cooling, compressor not running, temperatures rising
Is the light coming on when you open the door? If it isn't you might ned to replace a fuse or reset the circuit breaker. If the light comes on you probably have a bad starter relay.
Jun 08, 2011 | GE PSS26SGPSS Side by Side Refrigerator
Kenmore Elite 596.75523400, the refridgerator is working but the freezer isn't. The freezer defrosted but the freezer fan is working. Thanks
heatman101
May 07, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
2003 refridgerator
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Dec 18, 2009 | Refrigerators
Not cooling, no compressor sounds
How to check stuff>
Oct 01, 2009 | Refrigerators
The refridgerator runs but does not cool or freeze anything. There is a clicking noise everytime it tries to cool.
sounds like the compressor has seized and the click is the relay starter to get it going. if it is running and getting very hot the likelyhood is that there is a refridgerant leak.
Mar 13, 2009 | Whirlpool 21.7 cu. ft. Side-by-Side...
Refrigerators Logo
81 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
