Question about Refrigerators
Need part number for left and right hinge clip(s).
  • 4 Answers
You just swop the bottom and top hinges,remove the top hinge and install on other side on bottom, do reverse with bottom hinge ,if there is provision for the hinges to be swoped by means of threaded holes on the refrigerator and holes on the otherside of the door (left or right). Before you start see if its possible. Good luck,
Peter (S.A)
Posted on Jan 18, 2013
2 Suggested Answers
  • 59 Answers
SOURCE: do i need special hinges to change this refrigerator from left hand door to right hand door?
NO YOU USE THE SAME HINGES
Posted on Apr 29, 2009
Item comes with right hinged door...I need left hinged door.
On some models you can move the hinges and door pull to the opposite side. On the side without a hinge, you would see plugged holes (plastic plugs covering the holes). You may have to move the top right hinge to the bottom left and bottom right to the top left (opposite of this for a left-hinged refrigerator/freezer).
You may need help to do this, and be careful.
Donald
Jan 27, 2016 | Refrigerators
Model #jb700tok3 how to lift the stove top. heat warning lite will not go off
Hello. REMOVE POWER FROM THE RANGE NOW! Using a headlamp or flashlight, open the range door and look underneath the cooktop at the front. (The door covers the screws when its closed) There should be 3-4 screws depending on the model, usually black, that have to be removed. The cooktop will now lift up from the front. It is hinged(open hinges so be careful because the glass cooktop can be easily dislodged off the hinged area) underneath the control panel on the left and right sides. The elements will be mounted to the bottom of the glass. You will need to identify the defective element temperature sensor using a voltage/ohm meter. Element designation 56, LR and RR, part number WB30T10129, 6-inch size. Element designation 57, LF, 9-inch dual, part number WB30T10133. Element designation 58, RF, 12 inch, part number WB30T10130. If you are going to attempt the repair, take pictures of the wiring AND clips for each element before you start. Mark the new element with an arrow or dot, etc. with the mounting clip location numbers from the old element( see the numbers for each of the positioning holes around the rim. BE EXTREMELY CAREFUL NOT TO TOUCH THE HEATING FOILS AT ALL--THEY ARE VERY DELICATE! Have a friend/helper hold the cooktop up while you work--this will make the job much easier. I hope I helped you!
Aug 10, 2015 | GE Kitchen Ranges
Need to remove the door, but my hinge doesn't look like the illustration in the manual
Open door alittle push down and pull out and up to remove door.. You may have to wiggle it a bit.
Hopes this helps Mike
May 23, 2015 | Thermador Ovens
Oven door keeps open ay ideas about the fault cheers
make this test and fix it. GOD BLESS YOU
Door Hinge
An oven door repair may be needed if the door hinge breaks or is bent out of shape. Oven doors have two door hinges, a left and right. On some ovens the same hinge is used, on other ovens the right hinge and left hinge have different part numbers. The door hinge sometimes is sold with all necessary parts and springs, other times the parts need to be ordered separately. An oven door repair for a door hinge is a relatively easy repair for a do-it-yourselfer.
Enter your model number to see parts for your range/stove/oven.
Help me find my model number
Outer Door Glass
If the outer door glass is broken, it can be replaced. This oven door repair requires that the oven door be removed from the oven and layed down on a sturdy flat surface. The outer door glass is made of tempered glass. Use eye and hand protection when performing this oven door repair.
Nov 04, 2013 | Kitchen Ranges
How do I get top of my washer..Maytag Centennial ...Model # MVWC400VW1...to get to the lid switch?
This model Maytag is actually manufactured by Whirlpool. To access the lid switch on this particular model, all you should have to do is remove the operator console. The console has a retaining clip on each side holding it to the cabinet top. To release these clips, simply take a putty knife and slide it under the left and right front corners of the control panel push straight in towards the back of the washer. The clips will depress, allowing the operator console to be lifted up. The lid switch is mounted next to the left lid hinge. Refer to the "Top and Cabinet" parts illustration, Item 6 at searspartsdirect.com:
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Washer-Parts/Model-MVWC400VW1/3048/0153200?pathTaken=&prst=0&shdMod=MVWC400VW1
Some other websites you may refer to for parts include:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
NOTE: If you model number does not cross reference to these sites, use the part numbers fromthe Sears websites as your search criteria. Often, the model numbers may not be included on some websites (newly added models), but the part numbers will.
HINT: In some cases, what may appear to be a bad lid switch, may only be an actuator adjustment. The acutator on these models is the rod attached to the left lid hinge. You can bend the rod slightly to adjust the contact with the lid switch, or it may be tightened as necessary. If the switch toggles (clicks) by hand with the actuator rod removed, the switch typically is not bad.
If you need to remove the entire cabinet to access under the lid, the following link explains how:
http://www.fixya.com/support/r3631789-washer_case_removal_whirlpool_top
If you need further assistance, please post back and let me know. I hope you find this information helpful.
Apr 21, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
Replace key on logitech illuminated keyboard
Since this happened to me accidently a few times and I saw this thread, I thought my 25 cents could help others. I like the keyboard and it is troublesome to send it back for repair for a little thing like this. In my case, I was left with the square black key top and a pair of white hinges detached. You should replace the hinges properly in the base board first and after that press the key top gently and uniformly until you hear a couple of clicks. Make sure you are not irritated when you start this job and do not apply extreme force. It needs a little patience and fiddling. Unless you are lucky or an expert, it takes a number of times until you get it.
The two hinges need to be inserted in the metal clips of the base only after they are put together, not individually. Each hinge has two little rods on the narrow side and two little rods on the wider side. The wider side rods face up and will attach to the key top later. By now, you should be sure which rods of the hinges are up, towards you. Next, the hinges have to be attached to each other in the middle, like a foldable beach stool. You observe that one of them has a middle pin on each side, whereas the other has a corresponding cavity in the middle.
At the time you attach the hinges to each other in the middle, it has to be in such a way that the top part of each of them is smooth, that is, the part that will contact the key top. The side of the hinge that contacts the base has a little tongue between the two narrow rods. This tongue should face down in both hinges. You are now ready to place the little beach stool in the keyboard base.
In my case I inserted the hinge with the open part into the right metal clip and next inserted the rectangular opening to the left metal clip of the base. Whichever you do first is easy, but the second one might need a little help with a tiny screwdriver, or a tool with a similar effect. You might need a few attempts.
Now, your little hinges are attached to the board base and are not flat. They actually look like the legs of an open beach stool. Note which side of the key top is correct, it is annoying to go back to the beginning because you put the character upside down. It is time to press the key top gently and uniformly until you hear a couple of clicks. Unless there was serious damage to the board base or the parts we just mentioned, the key should work as smooth as the other keys.
Apr 09, 2010 | Logitech Wireless Access Duo Optical...
Whirlpool top load washer won't wash after filling
The hinge on the left side activates the lid switch. The hinge will have to be repaired or replaced.
Use a putty knife or a old CD to slide under the control panel on the right and left sides,where the control panel front meets the washer top.
This will release the clips that hold the control panel to the top cabinet.
Fold the cabinet to the rear.
Unplug the lid switch in the top of the cabinet on the left side.
Remove the brass clips holding the cabinet to the rear panel.
The cabinet will come off so that you can access the underside for the hinge and lid switch.
Jan 07, 2010 | Whirlpool Washing Machines
Trying to get the top up on maytag model #mdg7400aww. Need to get some nails out that was left in pocket & dryed. can you help.
For the model washer you have listed, there should be a a couple of retaining clips inside the front seam where the top panel meets the washer front. If you push a putty knife in the seam about 2 inches in from each side, you will be able to depress the retaining clips to release the top panel. With the retaining clips released, the top panel will open up exposing the mounting screws that hold the washer front in place. Remove the mounting screws and the entire washer front can be removed, giving you full access the washer interior. If you have any questions let me know. I hope this helps you.
Nov 27, 2009 | Maytag Dryers
Maytag dryer model mdg5500aww
OPEN THE DOOR AND REMOVE THE TWO SCREWS IN THE MIDDLE OF EACH HINGE. LOOK AT THE OPPOSITE SIDE OF THE OPENING AND REMOVE TWO SCREWS FROM THAT SIDE ALSO. PULL FRONT TOWARD YOU FROM THE TOP. IT IS HINGED AT THE BOTTOM. ONCE THE TOP IS FREE, LIFT THE FRONT OFF THE HINGES. THERE IS A CLIP HOLDING THE TOP TO THE CABINET AT THE FRONT CORNERS. REMOVE THE SCREWS HOLDING THE CLIPS IN PLACE AND SWING THE CLIPS TO THE LEFT AND RIGHT TO REMOVE THEM. THE TOP SHOULD SWING UP AND TO THE BACK AT THIS TIME. IT IS HINGED AT THE BACK.
Mar 24, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
