Question about HP Officejet Pro L7780 All-In-One InkJet Printer
My HP Officejet Pro L7780 faxes off & on. Motor is running w/in ADF, but the pick assembly does not grab paper
When paper is loaded to fax, ADF registers that a document is loaded. I dial the fax number, it dials and attempts to fax. Everything sounds like it is working, but the pick assembly will not grab the document.
    Problem Solver:
  • 14 Answers
Open the top adf cover clean all rubber parts with medical spirit(iso propyl alcohol) let it dry .good luck
Posted on Feb 13, 2015
  • HP Master
  • 2,072 Answers
There should be a textured seperator pad, if that's worn out, replace it. Also check the ADF rollers should not be smooth. You may need to just replaced the ADF maintenance kit. It should include the roller assembly and seperator pad.
Posted on Jan 19, 2013
agnelkj
  • 210 Answers
SOURCE: Will not grab documents
hi,
try this...
> unplug the power chord while the printer is turned on
> press and hold the # and 3 button on the printer at the same time and while holding it, insert the power chord.
> a semifull reset would be done
> after that try to fax.
thanks and regards
agnel
Posted on Mar 17, 2008
SOURCE: HP Officejet v40 - Not Faxing or Receiving
i have hp offecejet v 40 i am receiving an error message off hook. i have checked all the connections and the phone it is connected to is not off the hook_____________thanks shirley
Posted on Oct 21, 2008
frcs68
  • 1605 Answers
SOURCE: need to reset the number of rings before fax pickup on 2 hp offi
default ring is 5.
if need to change the ring, then you will be in maual answer mode.
better choice is to change the ring on the phone and the answer machine.
Posted on Jan 13, 2009
  • 120 Answers
SOURCE: how to remove and replace adf lid and gears for
http://www.precisionroller.com/trays-for-hp-officejet-pro-l7590/details_54680.html for the tray $46
Circuit City has the whole printer for $150.
Posted on Aug 24, 2009
SOURCE: The auto-document feeder on our HP L7780 OfficeJet
I put an elastic band around the black roller as it doesnt seem big enough and it works nearly every time now. Have done this with another L7780 Pro as well which fixed it completely on that one.
Posted on Dec 22, 2009
Partial print on incoming fax
Check your incoming line and settings or try to reinstall the drivers. Also, check the user manual for HP Officejet Pro L7780
Jun 25, 2013 | HP Officejet Pro L7780 All-In-One InkJet...
HP OfficeJet 8500 ADF detects load, but does not detect feed. I have a brand new HP OfficeJet 8500. The ADF detects a document is loaded when I stick a piece of paper in it to be copied/scanned/faxed, but...
Remember that if you start to fiddle you void your guarantee, I know its a pain, but if I were you repack and either contact customer services and obtain a return invoice number if purchased over the internet and return to sellers. If purchased from a shop, return with your prove of purchase.
Mar 19, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Fax machine is not grabbing papers to be fxed
If the ADF (auto document feeder) is not picking up paper, you could try the following HP support doc: (copy and paste the link into the location bar of your browser)
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01110425&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=2512009
Dec 10, 2009 | HP Officejet Pro L7680 All-In-One Printer
The 7780 all in one wont grab the paper in the fax mode
Open the rear door and clean all the rubber rollers with isopropyl alcohol.
Aug 03, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Feeder tray does not feed during fax
Hp help
Automatic Document Feed (ADF) does not pick up paper. Follow each step, problem seems to be in pick assembly. Prcess took less than 5 minutes with a successful outcome.
Apr 28, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
I want to fax using my HP OfficeJet Pro L7780. I
Click here for online manual and setup guides.
Clcik here to view DSL phone line setup instructions
& here for the general fax menu
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 08, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
My HP printer paper get stuck in top feeder whenever I try to fax
Lift the cover to the ADF (Automatic Document Feeder) and remove any paper debris from the rollers. Also, clean the rollers with a very damp cloth and a dab od dish washing detergent.
Also, check to see that the spring loaded lever is in place.
Clear the jam from the automatic document feeder (ADF)
  1. Make sure the product is turned off and the power cord is unplugged.
  2. Grasp the upper edge of the automatic document feeder (ADF) assembly and open it.
  3. Raise the roller assembly.
  4. Gently remove any jammed paper from the ADF.
  5. Lower the roller assembly.
  6. Close the ADF assembly.
  7. Plug the power cord back into the product.
  8. Press the Power button (c01346625.gif ) to turn the product on.
  9. Try the print job again.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 01, 2009 | HP OfficeJet 6110 All-In-One InkJet...
AUTOMATIC ORIGINALS FEEDER
I'm trying to print/fax several pages but the feeder doesn't "grab" the paper--basically nothing happens...BTW, mine is the HP Officejet Pro L7780 All-In-One.
Sep 10, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro L7780 All-In-One InkJet Printer Logo
110 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
