Question about HP OfficeJet 6110 All-In-One InkJet Printer
Hp officejet pro 8500a
It is giving constant failed alignment, we have doen everything we have read online, from cleaning linefeed, pushing padding underneath the printheads, changing printheads and cartridges, but it still fails to align and every time we want to print something, it prints but right after, starts aligning (which take along time) and says failed alignmnet. Please help. Is there a sensor inside that needs to be changed or any alignmnet that needs to be doen as the printer is not aligning. Please repsond ASAP.
SOURCE: Printer keeps showing : Press
PRESS SET UP & OPTIONS AT THE SAME TIME. WILL CLEAR MESSAGE.
Posted on Oct 22, 2008
SOURCE: HP psc 2110 Printer keeps
Press the cancel button. Then press the "setup" and top "copy option" buttons together to enter maintenance. Use the right arrow (right copy option) button to scroll through the options if you like, but then hit the cancel button to skip the alignment.
Posted on Jan 28, 2009
  • 25 Answers
SOURCE: HP OfficeJet 6110 xi Self Test "Align Cartridge" Failure
Hello there,
Try cleaning print cartridges from HP toolbox
or reset process
Please see note at bottom re: powering on and off
1) If you know you are going through the re-set process. Ensure there is nothing in your printer que already when you want to power on again.
2) Plug printer/scanner directly into the wall, not a power bar or UPS... Read at one point, it has something to do with the electricity (KW or Voltage or Amps) factor and power requirements to the printer/scanner. However was very technical and don't remember enough details to explain properly, sorry... Anyhow, directly into the wall.
This is what has worked for me. Got original re-set process of solution from sillygirl.
3) Disconnect all cables from printer.
4) Clean the glass on top with alcohol and cotton swabs.
5) Then go through the reset process (press # 6 while plugging the power back into the printer).
6) If you have the CD for your printer it doesn't hurt to put it in your CD carriage in case your printer is looking for files or drivers. If CD starts to go to a un-install or full re-install just cancel and leave in carriage.
7) Sometimes helps if you first plug printer in.
8) Re-boot pc before powering on printer. Once re-boot has started and PC will start to look for printer.
9) Power on printer (press # 6 while plugging the power back into the printer to re-set).
10) Watch for point where your printer icon usually appears and plug the USB into the PC.
_____________________________________
11) If this does not work then take the printer apart and clean the underside of the glass as well. Unfortunately need to go through re-set process again. May need to buy a set of screw drivers for removing the glass. They are different. (Torx)
12) In another solution it states - you must clean all the mirrors inside the scanner assembly q-tips work well (black box closed with two locks) also the lens and the delicate spaghetti-like lamp. Generally this works... Not everyone has done this part but worth a try when the printer is already open.
13) There is a black and white strip at that end of the scanner. Check to ensure the strip is there, in tact and placed correctly. This is what the scanner carriage aligns itself with.
Just so people know. I have posted solutions to this before that have worked for me. However, I really do think this comes down to a driver issue (do we all have XP, mine is actually XP Home Edition). Since HP no longer updates these printers not sure if we will ever see a driver that works perfectly. Once you get it going again it will all work great. The problem lies in powering on and off. Once you get it going without the scanner carriage jamming, leave it on! Even in the case of a power out I usually have to re-set again but can get it going, eventually (it can be very frustrating). Sometimes need to re-boot PC and plug USB into the PC while booting up and just about to look for your printer. This is to ensure it finds the printer/scanner. Also, when really desperate uninstall and re-install the hardware. Sometimes can try for quite some time to get it working again and eventually have to just leave it off for a few days then can get going again afterwards. Not sure if this has something to do with memory.
Posted on Feb 28, 2009
POCBM
  • 121 Answers
SOURCE: hp officejet 6110
If machine does not print the colors it cannot align. Try changing the color and try again
Posted on Apr 03, 2009
  • 214 Answers
SOURCE: printer Align keeps failing after I chnaged the color cartridge
Are all the inks printing? If not you need to get all colours working before correct align can take place Have you tried cleaning the gold cartridge contacts? Wth a little distilled water, cotton bud and then let dry before reinstalling
Posted on May 29, 2009
Hp officejet pro 8500a shows cleaning print head/alining print head
that might be your printing settings and laptop file formate
Mar 17, 2016 | HP Office Equipment & Supplies
White Lines HP Officejet Pro L7780
Have you replaced the ink? Perhaps one color is low or one of the pin-heads is broken. If the pins on the printer have broken you will need a repair technician or just buy a new printer.
Feb 07, 2014 | Lexmark X5470 All-In-One InkJet Printer
Officejet pro 8500a plus adf broken
I work for an authorized HP dealer and I just checked HP parts and they do not appear to have any parts for the ADF on this model. You could check Ebay for a used unit or one being sold as is that has a working ADF.
Aug 06, 2012 | HP Officejet Pro 8500A Plus Wireless...
HP Officejet Pro 8500 has a line on scanned copies. How do I get rid of the line
check the scanner glass, run your nail over it as you may not see it as they may be a small amount of tipex on the scanner glass
Mar 23, 2012 | HP Officejet Pro 8500 Wireless All-In-One...
Hp 8500a has new print heads and new ink and now cyan has stopped printing
Hi I have two split pipes in my Hp 8500A printer where can I get replacement parts as it is not printing correctly.
Feb 08, 2012 | HP Officejet Pro 8500 Wireless All-In-One...
How do i download a user manual for hp officejet pro 8500a
Hi
get online and google HP ,this will take you to HPs web site where you can type in your model and it will come up withh a list of things you can download , or just type in HP on your search eng. and it will take you right to HP Goodluck Roy
Jul 20, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
How i can print in I pad2 with wireless printer
you can only print from an ipad using the airprint app if you have one of these printers read more about it here http://www.apple.com/ipad/features/airprint.html
    May 02, 2011 | Apple iPad 64 GB 3G Tablet PC
    How do you print labels on a HP Office Jet Pro 8500A Plus and align the labes on the sheet???
    Depending which publisher you use look for mailings or envelopes it all in there.
    Good luck
    Peter.
    Mar 07, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
    Need HP officejet pro 8500 Service Manual
    You can find one here: http://downloadfreemanuals.com/officejet-pro-8500a-manual/
    Jan 20, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
    HP OfficeJet 6110 All-In-One InkJet Printer Logo
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
